Resending this bc don't think the original went
through...
Hi all,
Need to trim the fiberglass fairing for the hor. stab.
for my SR. I have never worked with fiberglass before.
What's the best way to cut and trim fiberglass? I was
thinking of using a dremel tool with a cut off wheen
and then filing to the line. That ok? Do's and don'ts?
-jason
Jason Beall
Super Rebel No. 131
Aberdeen, Scotland, UK
super_rebel131@yahoo.com
Do You Yahoo!?
Make international calls for as low as $.04/minute with Yahoo! Messenger
http://phonecard.yahoo.com/
cutting and trimming fiberglass
LisaFly99
In a message dated 8/2/01 3:43:29 PM Central Daylight Time,
super_rebel131@yahoo.com writes:
JASON
If it's not to thick you can use you're aviation snips. For long cuts or
flatter surfaces use you're bull snips. Then sand to final with a palm
sander. ALWAYS wear a mask so you don't breath the dust, the rosin or the
glass for that matter doesn't do the body any good.
Phil&Lisa Smith #460R N414D
JASON
I used a Dremel with a cut-off wheel and it worked excellent for me. Very
quick and easy. Wear a mask though. Lot's of fiberglass dust in the air.
SR#044
Jason Beall
Sent: Thursday, August 02, 2001 12:43 PM
Subject: cutting and trimming fiberglass
through...
Hi all,
-jason
Jason Beall
Super Rebel No. 131
Do You Yahoo!?
murphy-rebel mailing list.
SR#044
Jason Beall
through...
Hi all,
-jason
Jason Beall
Super Rebel No. 131
Do You Yahoo!?
