tires and wheels
bob.patterson
tires and wheels
Post by bob.patterson » Fri Feb 17, 2012 11:55 pm
Received: from bretweir.total.net ([154.11.89.176])
by dcsol.com (wcSMTP v5.4.449.4)
with SMTP id 60006234; Fri, 20 Apr 2001 18:17:00 -0800
Received: (qmail 22800 invoked from network); 21 Apr 2001 02:15:12 -0000
Received: from unknown (HELO ip174.toronto78.dialup.canada.psi.net) (154.20.72.174)
by bretweir.total.net with SMTP; 21 Apr 2001 02:15:12 -0000
Mime-Version: 1.0
Subject: Re: tires and wheels
Hi Rick !
While the silver Matco's will work, you would be MUCH better
off with a set of the Murphy wheels & brakes.
Several builders here had the same problem with the Matco's -
it seems the wheels have too steep a slope on the sides of the rims.
(Although they usually deny responsibility ...) They weren't
consistent - some were fine, others were impossible. That's the major
reason that Murphy felt compelled to develop their own wheels &
brakes...
Some folks have machined the wheels down a bit near the edges,
and that solved the problem. Some used bar soap for lube, then
washed it out with water after fitting - not sure about that lube
you used. You sure don't want the tire to spin after it is seated -
it'll pull the valve stem out !!
--------------------------------orig.-------------------------------
At 09:05 PM 4/20/01 -0700, you wrote:
Hello,
Has anyone had trouble getting the bead to fully seat using the silver
MATCO (M62) wheels and the DICO turf tires used on the standard rebel? I
cannot get the bead to fully seat on the rim, I also used the real
slippery rubber lube in an effort to get this to work. MAC suggested
that I call MATCO. I called MATCO and to experiment they tried to mount
a similar tire to the M62 rim and they could not get it to fully seat
even at 40 psi. They tried a McCreary tire with a stiffer sidewall and
it seated fine. They feel that the sidewalls of the DICO tire are too
thin thereby bulging out and just ballooning out without seating. MATCO
has given me the dimension of the wheel diameter to check just in case
there was a manufacturing mistake on the wheel set that I have. I will
ckeck that tomorrow. One suggestion is to clamp a couple of plates to
the sides of the tires in order to contain the bulging. This would also
require the outer diameter to be constrained with a strap to keep it
from bulging also. Hell, I don't want to do that. If I have to fix a
flat, I would need those plates and straps to seat the bead.
I guess it will be back to MAC on Monday to see what they can do.
Any and all comments will be appreciated,
Rick D.
murphy-rebel mailing list.
Rick DeCiero
tires and wheels
Post by Rick DeCiero » Fri Feb 17, 2012 11:55 pm
Hello,
Rick D.
Rick and Cathy Ford
tires and wheels
Post by Rick and Cathy Ford » Fri Feb 17, 2012 11:55 pm
Rick
You're not the only one with that problem.
My Matco tires never and still aren't seated right.
I'm just gonna use the bloody things till they wear out and NEVER get those
bargain basement parts again.
Yup, sometimes it feels like I'm trotting on a horse down Bravo taxi-way.
A mechanical horse with people inside - what a novelty.
Rick
Sent: Saturday, April 21, 2001 12:05 AM
Subject: tires and wheels
Hello,
Rick D.
