Received: from MMoreho699@aol.com
by imo14.mx.aol.com (IMOv14_b1.1) id WNFAa13455;
Fri, 19 Jun 1998 02:26:51 -0400 (EDT)
Message-ID: <5cecfec7.358a04ac@aol.com>
Date: Fri, 19 Jun 1998 02:26:51 EDT
To: murtech@murphyair.com, murphy-rebel@dcsol.com
Mime-Version: 1.0
Subject: crimped enough?
X-Mailer: AOL 3.0 for Mac sub 84
Hi!
I crimped the fuselage root rib flanges with Malco's C5 Pipe Crimper and
still
had a pretty good sized warp. I called the company and they said the C1,
which
is being replaced by the C4, crimps deeper. So I ordered it through one of
aviation supply catalogs.
In the meantime I made the two cabin top bulkheads (G and H) and fit things
together on the cage and bulhead F. It straightens out fairly well, putting
little tension on one cabin bulkhead and a little compression on the other.
I'd say the forces generated are one or two pounds. Once I get the roof on
think things will be okay. Do I need to get the fuselage root rib any
better?
Dan
R280
crimped enough?
crimped enough?
Received: from default (1Cust209.tnt2.krk1.da.uu.net [153.37.252.209])
by smtp1.mailsrvcs.net with SMTP id KAA10738
for <murphy-rebel@dcsol.com>; Sat, 20 Jun 1998 10:04:19 -0500 (CDT)
Reply-To: "Charles Bailey" <baileyca@gte.net>
Subject: Re: crimped enough?
Date: Sat, 20 Jun 1998 08:05:21 -0700
Message-ID: <01bd9c5c$d854c3c0$d1fc2599@default>
MIME-Version: 1.0
Content-Type: text/plain;
charset="iso-8859-1"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.71.1712.3
X-MimeOLE: Produced By Microsoft MimeOLE V4.71.1712.3
To: murtech@murphyair.com <murtech@murphyair.com>; murphy-rebel@dcsol.com
Date: Thursday, June 18, 1998 11:47 PM
Dan,
As I recall that is about how mine fit after straightring the best I could.
Check when fitting the window as you may have to trim a little of the nose.
(I did) You don't want to put a pressure point on the window.
Chuck 176R
At least 200hrs. to go
_______________________________________
MIME-Version: 1.0
X-Priority: 3
Dan,
Chuck 176R
IHi!
--snip--
It straightens out fairly well, putting a
better?think things will be okay. Do I need to get the fuselage root rib any
Dan
R280
crimped enough?
by imo30.mx.aol.com (IMOv14_b1.1) id DAPIa26166;
Sun, 21 Jun 1998 19:47:10 -0400 (EDT)
Message-ID: <a99b63e3.358d9b7f@aol.com>
Date: Sun, 21 Jun 1998 19:47:10 EDT
To: baileyca@gte.net, murphy-rebel@dcsol.com
Mime-Version: 1.0
Subject: Re: Re: crimped enough?
Thanks, Chuck!
Dan
R280
Mime-Version: 1.0
Thanks, Chuck!
Dan
R280
