Pitot installation.
Mnleber
Pitot installation.
Post by Mnleber » Fri Feb 17, 2012 11:47 pm
Regarding the use of nylon. Have you tried teflon. You can get it in 1/4", 3/8" OD which is compatible with all compression and push on fittings. It is good to 150-250 psi depending on wall thickness and type and it does not react to chemicals and UV which ny
lon does. For an airplane, if you want to bury it in a wing it is probably ideal. The downside is it is a little pricey. I used it as a fuel gauge as well. Works good if you use clear teflon. I used it on my Zenair and figured it was cheaper than worrying abo
ut failure down the road or the time and aggravation of having to replace it once a year as reccomended with nylon or PE.
Mike Le Ber R683
AGT
Pitot installation.
Post by AGT » Fri Feb 17, 2012 11:47 pm
I didn't know that the nylon stuff has such a short life. CLearly, if what
you say is true, despite the cost, teflon would be the way to go. And I
believe teflon tubing and fittings are available at my local hardware store!
Mnleber@aol.com
Sent: Sunday, March 04, 2001 11:50 PM
Subject: Pitot installation.
Mike Le Ber R683
murphy-rebel mailing list.
klehman
Pitot installation.
Post by klehman » Fri Feb 17, 2012 11:47 pm
Hi Mike
Do you know where teflon tube can be purchased in small quantity?
ny
