[rebel-builders] Float spray rails
Post by Wayne G. O'Shea » Mon Feb 20, 2012 2:37 am
They are "air rails" not spray rails. They help get some turbulence under
the floats and allow the floats to break the water surface quicker with them
on. I cut the outboard one down by an inch before installing...but yes they
can be a PITA on some docks!
Sent: Saturday, January 28, 2012 5:43 PM
Subject: [rebel-builders] Float spray rails
Hi~~Does anyone know why MAM 1800 amphibs would have an outboard spray
board? I have a set built in the Philippines. I just started flying them
and after busting my shins a couple of times, I realized they would not
dock without tearing them up. Before I take the sawzall to them, I figured
I'd like some input. ~~Thanks, Bill Foster 630E
Post by Walter Klatt » Mon Feb 20, 2012 2:37 am
Been flying with mine for 10+ years, and dock with them all the time,
without interference or damage. That's what tires and dock bumpers are for.
They are well below the water line, too, so not usually in a position where
they would contact a dock side.
Also, I believe they help with water take-offs, by providing some extra lift
at the step. Can't say that for sure, but that is a theory I have heard. I
do know that one of the local guys here does not have them, and his water
performance is not as good. However, he may have other issues, too, that
cause that.
I will agree, however, that you have to be careful around them in the
hangar, or you will cut your shins. Usually that only happens once or twice,
before you learn.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Bill
Sent: Saturday, January 28, 2012 2:44 PM
board? I have a set built in the Philippines. I just started flying them and
after busting my shins a couple of times, I realized they would not dock
without tearing them up. Before I take the sawzall to them, I figured I'd
password "builder"
drewjan
Post by drewjan » Mon Feb 20, 2012 2:37 am
I haven't bent mine on the floating dock yet but they are hard on shins if you're not careful. I used a file to make sure the edges were rounded off as much as possible.
Sender: mike.davis@dcsol.com
Date: Sat, 28 Jan 2012 17:43:50
Hi~~Does anyone know why MAM 1800 amphibs would have an outboard spray board? I have a set built in the Philippines. I just started flying them and after busting my shins a couple of times, I realized they would not dock without tearing them up. Before I take the sawzall to them, I figured I'd like some input. ~~Thanks, Bill Foster 630E
Garry Wright
Post by Garry Wright » Mon Feb 20, 2012 2:37 am
In 2007 the ramblers visited the factory and Daryl had changed the form of
the spray rails from a custom formed compound curve style to a straight
piece and IIRC eliminated the outside rails. I was in the midst of
repairing mine so eliminated the outside one and replicated the new inside
ones. I'm not skilled enough to be sure it makes no real difference but
that is the sense I get, and no shin scars.
Garry
