Rebel Axle -- which is which?
Ben Ransom
Post by Ben Ransom » Mon Feb 20, 2012 2:36 am
One thing I've put off doing is an axle replacement for one side. The holes for attach to the leg gussets were not drilled on centerline, so when I put them on my gear legs, I get too much down angle on the wheel.
I don't know which axle to order. My plane came from the original owner with spring gear (cessna style), which I sold to someone else and he also gave me the remains of wrecked bungee gear. Although I'm told the axles are different between those two, the axles that I received with the wrecked bungee gear are the same as the axles that had been with the spring gear I sold
