WD prop
Rick and Cathy Ford
WD prop
Post by Rick and Cathy Ford » Fri Feb 17, 2012 11:46 pm
Hi Guys.
My prop has just started de-laminating.
A piece of aluminum at the base has come off.
It's a triangle piece 90 degrees of the circle, and about 3/4" at one end to a point at the other.
I have it mounted on a 150 hp O-320.
I've talked to Darryl at WD and will be sending it back.
He also suggested using the dampener.
Does anyone have a good lead on these little babies.
I'm hoping to have the new blades back in 2-3 weeks, so I've got that long to located, purchase and assemble a dampener.
I'd appreciate any help (WAYNE or Bobp) on this.
Thanks guys.
BTW - all you guys out there with 150HP O-320 and no damper better check your installations.
Rick Ford
436R
apat
WD prop
Post by apat » Fri Feb 17, 2012 11:46 pm
Received: from smtp.interlog.com ([154.11.89.176])
by dcsol.com (wcSMTP v5.4.449.1)
with SMTP id 133422750; Thu, 22 Feb 2001 12:00:13 -0900
Received: (qmail 4216 invoked from network); 22 Feb 2001 21:00:07 -0000
Received: from unknown (HELO ip55.toronto77.dialup.canada.psi.net) (154.20.71.55)
by bretweir.total.net with SMTP; 22 Feb 2001 21:00:07 -0000
Mime-Version: 1.0
To: <MURPHY-REBEL@dcsol.com>
Subject: Re: WD prop
Hi Rick !
Thanks for the update - sounds like everybody will have problems
eventually !! :-( Definitely worth checking !
The dampeners people have been using come from Mark Landaul -
I think he's in Michigan, but it's in the archives at :
www.dcsol.com/murphy-rebel under mail lists/archives
Sometime in the last couple of months, someone gave the
address & tel. number for Mark - good luck !
....bobp
---------------------------------orig.------------------------------------
At 03:45 PM 2/22/01 -0500, you wrote:
Hi Guys.
Thanks guys.
your installations.
Rick Ford
436R
<HTML><HEAD>
<META content="text/html; charset=iso-8859-1" http-equiv=Content-Type>
<META content="MSHTML 5.00.2614.3500" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT face=Arial size=2>Hi Guys.</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=Arial size=2>My prop has just started
de-laminating.</FONT></DIV>
<DIV><FONT face=Arial size=2>A piece of aluminum at the base has come
off.</FONT></DIV>
<DIV><FONT face=Arial size=2>It's a triangle piece 90 degrees of the
circle, and
about 3/4" at one end to a point at the other.</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=Arial size=2>I have it mounted on a 150 hp O-320.</FONT></DIV>
<DIV><FONT face=Arial size=2>I've talked to Darryl at WD and will be
sending it
back.</FONT></DIV>
<DIV><FONT face=Arial size=2>He also suggested using the dampener.</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=Arial size=2>Does anyone have a good lead on these little
babies.</FONT></DIV>
<DIV><FONT face=Arial size=2>I'm hoping to have the new blades back in 2-3
<DIV>&nbsp;</DIV>
<DIV><FONT face=Arial size=2>I'd appreciate any help (WAYNE or Bobp) on&nbsp;
this.</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=Arial size=2>Thanks guys.</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=Arial size=2>BTW - all you guys out there with 150HP O-320 and
no damper better check your installations.</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=Arial size=2>Rick Ford</FONT></DIV>
<DIV><FONT face=Arial size=2>436R</FONT></DIV></BODY></HTML>
hibbs
WD prop
Post by hibbs » Fri Feb 17, 2012 11:46 pm
Rick, what would it take to get you to photograph the delamination and
upload it here on the site? I have a WD and would love to see what
everyone is talking about.
Mike, is it possible to simply reply to postings via my browser? I can
chose Next or Prev but can't select Reply or Forward.
Best Regards,
Scott Hibbs
hibbs@pacifier.com
WD prop
Post by Mike Davis » Fri Feb 17, 2012 11:46 pm
It should work now. I want to point out though, that when you post a
message to the list this way, it will be from the account you are logged
into the system with, not from your normal e-mail address. This is not a
problem, it will just appear differently in the archives. Also, this wont
work using the default rebel/builder login, it will only work if you create
your own login.
Sent: Thursday, February 22, 2001 5:13 PM
Subject: WD prop
Best Regards,
Scott Hibbs
hibbs@pacifier.com
rebel300r
WD prop
Post by rebel300r » Fri Feb 17, 2012 11:46 pm
Great Mike, it works perfectly now.
Scott Hibbs
your own login.
