The blue stuff IS translucent, and will work ... but it eventually
discolours too ... Should be good for a year or 2 though...
You haven't been running car gas have you ??? That's a no-no
for at least a few hundred hours ... and bad gas can discolour
tubing within a few DAYS !!!
I've tried Tygon, and several others - Canadian Tire stuff for
windshield wipers worked !! Just the luck of the draw - keep trying !!
THAT'S why I recommend installing a small shut-off valve at the
bottom of the sight guages - makes it a LOT easier to change
the tubing .... no need to run a tank dry !! ;-)
Glad to hear you are progressing so well - keep going ....
it's a looonnnnngggg winter !! ;-( Your insurance will drop
a whole bunch once you pass 100 hours solo !!! :-)
Maybe you need a trip to Sun 'n Fun in March !!! ;-)
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
De-fenestrate now ! Linux is the answer !
responsibility of the reader.
http://www.danasoft.com/sig/pssignTux.jpg
On Tuesday 27 September 2011 14:07:07 Rebecca Brownell wrote:
hello .could i trouble a few to let me know what they have used for clear
fuel sight tubes.whatever i have used so far has hardened over just a
couple months and started to seep at the fittings.has anyone used that
bing fuel line from aircraft spruce?it says its blue in color,doesn't say
if it is translucent.any words of wisdon greatly appreciated as always.
thanks so much
jason
817R
27hrs on the plane now!finished float rating yesterday!sweet
