[rebel-builders] First Report
Keith Leitch
Post by Keith Leitch » Sun Feb 19, 2012 11:55 pm
Craig,
Thanks for the report. Sounds like you are having a blast with your new toy. Your fuel burn does seem higher that what I have usually heard from guys but then with the power available when you may need it is a nice side benefit. COngrats on constructing such a nice plane. The O-360 was on my possible list of engines for my Rebel....that is is I ever get back to the work bench and get it done.
Keith R661
--- On Thu, 9/22/11, craig walls <snowyriver@ak.net> wrote:
Subject: [rebel-builders] First Report
Date: Thursday, September 22, 2011, 1:00 AM
Hi All,
I have almost 15 hrs on the plane now and several people have asked about numbers.
Jay Yau
Post by Jay Yau » Sun Feb 19, 2012 11:55 pm
Hi Craig,
I'm still home sick for Alaska, would like to visit Alaska again in 2012 with my newly built airplane.
I got 7 hours on my new plane/new engine now, still breaking in the Engine, the CHT/EGT run hot in Southern California.
My Engine is 0-360 A1A, when run at 25" MP/2500 RPM/mixture full rich @ 4500 feet, the fuel flow exceeds 20 gal/hour, I'm new to this fuel flow gauge, does it sound normal in this configuration? I have Dynon Skyview duel screen EFIS.
So glad you are flying, we are pretty much on the same flight test stage.
Jay Yau
949-878-8153
Date: Wed, 21 Sep 2011 22:00:52 -0800
Hi All,
I have almost 15 hrs on the plane now and several people have asked about numbers. As far as temps, not sure how much good the numbers would do you because it's so cool up here but....I've been flying in the 55-60 degree range. In a long climb (2 min) about 85% power my oil temp was 225 once. I have an oil cooler with a air shut-off and it was closed. Generally the oil temp's been running about 210-215. CHT's are in the mid 300's and they stay there. I can't seem to reduce temps enough to worry about shock cooling during descents. Today I was flying at 90 mph at 3500' and had it leaned to 7.9 gpm with EGTS at 1380ish. If I don't lean, the 0360 drinks lots of fuel! Except for T offs and landings I plan on leaning early and often!
If you noticed, my cowl is modified and has larger air inlets than the stock speed cowl. I haven't really tried anything full performance yet...being cautious and a little nervous. I have seen 1800 fpm with power to spare and I find my self not using full throttle on take offs because it's just not necessary, Probably a bad idea. I have to trim a lot. The electric trim is slow to act and I over trim. Stalls are at 46 mph no flaps, power off and 43 with two notches. I only built it with two notches but I'm planning on adding a third. I haven't put the VG's on yet...I want to see what difference they make once I'm used to the plane as it is.
The fastest I've flown so far is 115 mph. In the pattern I have to reduce rpms to about 1250-1300 to get it to start losing altitude--not the 1500 or so I was used to to. Once it gets to about 55-60 with 2 notches it has a fast sink rate! I've found myself behind the power curve several times during base and final and luckily the 180 horses easily fixes that. Still learning.
It's an incredible feeling flying something I've built. Can't really put it to words. Everyone, keep it up! Craig
BTW, Deb and I were at the Reno air races and near as I can tell from the videos and photos we were sitting approximately 75' from the place where the P51 hit. We were in the stands and had watched every race and decided to leave early that day to beat the crowds. Makes you think!
Post by Walter Klatt » Sun Feb 19, 2012 11:55 pm
A stock parallel valve 360 should flow at around 16 - 18 gph at full
throttle. I think you need to calibrate your fuel flow gauge if it is
showing 20 gph at only 2500 and 25", and at 4500' Would only expect about 15
gph at those numbers.
Mine flows about 16 gph at 2600 rpm about 500 MSL on climb out. Highest I've
seen is 18 during initial climb and lowering the nose a bit to get the rpm
to 2700.
If your EGTs and CHTs are too hot on climb out, you should check your carb
main jet spec. You will want the 10-4164-1 version. If you have the 10-3878,
or other, you could be running too lean at full throttle.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jay
Yau
Sent: Thursday, September 22, 2011 2:00 PM
Subject: RE: [rebel-builders] First Report
Hi Craig,
screen EFIS.
Jay Yau
949-878-8153
Hi All,
learning.
Jay Yau
Walter,
I got the 10-4164-1 carb.
Jay
Date: Thu, 22 Sep 2011 14:48:38 -0700
to 2700.
Yau
Hi Craig,
screen EFIS.
Jay Yau
949-878-8153
Hi All,
learning.
Jay Yau
Walter,
Thank you so much for the test data, I have flown another hour this afternoon, re-confirmed the 25"x 2500RPM @ full rich, it's still exceeding 20 gph, I will check the Dynon fuel flow setting (if it can be calibrated) and verify the carb main jet version.
I also have another problem, the fuel leaked out from the bottom of the carb, this is the picture I took (see attachment), is that something normal for brand new engine? now I got 8.5 hours on the brand new engine.
Jay
to 2700.
Yau
Hi Craig,
screen EFIS.
Jay Yau
949-878-8153
Hi All,
learning.
I don't see any attachment. You would have to send private email for that.
But if you are leaking at the carb, that is not good. If it is a new engine
and carb, would have to assume they have all the latest AD's applied with
the float, etc.
Are you sure your primer is properly closed and seated, and not leaking fuel
into the cylinders and back down the intakes?
Yau
Sent: Monday, September 26, 2011 10:36 PM
Walter,
Jay
15
I've
to 2700.
10-3878,
Yau
Hi Craig,
Engine,
duel
screen EFIS.
Jay Yau
949-878-8153
Hi All,
about
oil
stay
fuel!
flaps,
I'm
reduce
or
learning.
elist
Post by elist » Sun Feb 19, 2012 11:55 pm
As Walter notes, this could happen with a primer leak. It did for me. All
new parts, engine, primer, etc. Pulled carb apart to check float. Minor
adjustment, still leaking. Yep, primer leak was letting fuel dribble by, out
carb and onto hangar floor. But not noticeable under power and flight.
Eric N645E
Klatt
Sent: Tuesday, September 27, 2011 8:29 AM
the float, etc.
Yau
Walter,
Jay
15
I've
to 2700.
10-3878,
Yau
Hi Craig,
Engine,
duel
screen EFIS.
Jay Yau
949-878-8153
Hi All,
about
oil
stay
fuel!
flaps,
I'm
reduce
or
learning.
