Hello David,
I'll send you a copy of the 3500 mods "chapter 3 Fuselage Front Spar Attach
Fitting" document to your individual email address. FUS-712 is shown as
2"x2"x.120-128Wall 6061-T6.
Ted Waltman
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of davids
Sent: Wednesday, July 20, 2011 2:44 AM
Subject: [rebel-builders] Wing attach hole size - Moose
Hello
I am normally a lurker on this site, but have come upon a
problem and seek advice. In fitting the wing to the front
attach point, the manual calls for a 1/2" reamed hole, the
modification manual calls for a 1/2" hole and a bushing part
number W-712. Does anyone have final size dimensions and
materials spec for this bushing as there weren't any
bushings in the materials that I received. Holes were
previously drilled to 3/4" which makes sense for a bushing
and a 1/2" bolt, but of course there is ever present lack of
direction in the manuals.
Thanks & regards,
David Sproule
rhuzzey
Hi Ted
Could you send me that document as well.
I am never quite sure what I will run into building my Yukon as the manual was not completed.
Would be good to have infomation.
Reid
Sent from my iPad
Reid
Sent from my iPad
Hello David,
Ted Waltman
Hello
Thanks & regards,
David Sproule
David Sproule
Thank you Ted, this is very much appreciated.
Best regards,
David Sproule
Waltman
Sent: July-20-11 11:45 AM
Subject: RE: [rebel-builders] Wing attach hole size - Moose
Hello David,
Ted Waltman
Hello
Thanks & regards,
David Sproule
Best regards,
David Sproule
Waltman
Hello David,
Ted Waltman
Hello
Thanks & regards,
David Sproule
