EAA has a good video on safetying turnbuckles under the 'Hints for Homebuilders' video section. See if this link works:
http://www.eaa.org/video/homebuilders.h ... 9739778001
If not, it's torward the bottom of the videos on the 'General' tab.
Regards,
-Jason
--- On Mon, 1/17/11, Jesse Jenks <jessejenks@hotmail.com> wrote:
-----------------------------------------------------------------From: Jesse Jenks <jessejenks@hotmail.com>
Subject: RE: [rebel-builders] Cable tensions - Was:control cable turnbuckles
To: "Builders list" <rebel-builders@dcsol.com>
Date: Monday, January 17, 2011, 10:47 AM
I just set up my cables too and I set the turnbuckles up to
have 4 turns inside the barrel (max for initial set up per
ac 4313) this leaves a good amount of adjustment either way.
I also made tangs for the pedal/cable attachment with 3
holes 1/2" apart. So far I don't think I will have to use
any of the built in adjustability, but we'll see. Now all I
have to do is figure out how to safety wire those
turnbuckles.
Was:control cable turnbucklesFrom: rshannon@cruzcom.com
Date: Mon, 17 Jan 2011 09:05:21 -0800
Subject: Re: [rebel-builders] Cable tensions -(if you can find one)want to fly in it.and the plane... and I'm guessing I probably wouldn'tside before you handProbably best to not leave more than 3 threads on eachwhen you come totighten the cable for the front Nicopress, becausereturn spring tension,balancing or fine tuning everything, including thepedals even with eachyou may actually want to loosen one side to keep bothhave to make anotherother and the rudder centered. Next thing you know youthe hard work andone. Been there.
Hang in there. As I've said before, it turns out allwhich comes back withdelayed gratification really is ecstasy in the bank,sometimes!geometrically compounded interest.
Ron
254R
On Mon, Jan 17, 2011 at 8:09 AM, Jason Beall <super_rebel131@yahoo.com>wrote:
.... I think I am over analyizing things...
