[rebel-builders] Drilling through steel leaf springs: work-h
schaumr
[rebel-builders] Drilling through steel leaf springs: work-hardenin
Post by schaumr » Sun Feb 19, 2012 9:31 pm
Actually, I did start small (#30) and it went fine initially. Once I got to 9/32
though, halfway through the hole, it just stopped moving and started grinding.
Rob
On 8/30/2010 8:55 AM, rwampach@att.net wrote to rebel-builders:
-> Oh, Oh! So did you try to drill a big hole all in one pass? Try a small
-> diameter carbide # 40 or so, slow turning, heavy pressure, cutting oil, &
-> don't side load the bit to break it. Good luck
-> Dick Wampach SR-108 N331RW
-> -----Original Message-----
-> schaumr@dcsol.com
-> Sent: Monday, August 30, 2010 9:19 AM
-> Subject: [rebel-builders] Drilling through steel leaf springs:
-> work-hardening
-> Hi All,
-> Tried to drill through my steel tail spring this morning but managed to
-> render
-> half the hole "work-hardened" (not enough lube and/or cooling). What do
-> do now? Carbide tipped bits? Other bits?
-> Hope someone can help me avoid buying a new tail spring!!
-> Rob
-> Rebel 786
-> List archives located at: https://mail.dcsol.com/login username "rebel"
-> password "builder"
