[rebel-builders] Spring Gear on Murphy Rebel
Garry Wright
Post by Garry Wright » Sun Feb 19, 2012 9:24 pm
Wally,
I had this problem with my gear. It turned out that Murphy had two lengths
of drag strut - 7/8" different in length. Check them for length. Mine was
very difficult to handle until I found this problem and after was a pussy
cat. Prior to fixing it a 25' wide paved strip would be scary to say the
least. Afterward, no problem at all. I have reason to believe that years ago
one of the struts was replaced after a ground loop or something and because
it was normally on floats, the problem was never tracked down. Most
discussions on this subject suggest neutral on toe in. The camber argument
is probably a red herring because it changes with loading and I have never
had a problem with that. Good luck.
Garry
On Tue, Jun 15, 2010 at 11:25 AM, Wallace Wogenstahl <
rwogenstahl1@cinci.rr.com> wrote:
hellow guys need some help.we are working with a Rebel built in 2003 it
has spring gear and Lyc. 235 It is much more squirley than my Rebel on
bungee gear.some AI,s told us the camber and toe in was wrong . So I need to
know what is the correct specs.for this airplane . any help would be
appreciated Wally.
