[rebel-builders] Amphib Hydraulic level
Post by Wayne G. O'Shea » Sun Feb 19, 2012 9:23 pm
..so if you fill with the gear up, to the level you want, it will never be
an issue!
Sent: Monday, June 07, 2010 5:31 PM
Subject: Re: [rebel-builders] Fuel Leak
It varies about 3/4" Nigel (of course depending on which container you
have).. because the rod side of the cylinders (gear up) has less internal
volume than the gear down side.
Sent: Monday, June 07, 2010 3:35 PM
Should stay level as return same. As outflow.
------Original Message------
Sender: mike.davis@dcsol.com
ReplyTo: rebel-builders@dcsol.com
Subject: RE: [rebel-builders] Fuel Leak
Sent: Jun 7, 2010 11:41
Hi All
With the Murphy 1800 amphib's and the supplied hydraulic reservoir for
gear system, would anyone know how much the level changes in the
reservoir
as the gear is pumped up and down ?
Just trying to avoid overfilling and it leaking all over the floor while
I'm
merrily pumping away :-)
Nig
745E
N.Smith
Post by N.Smith » Sun Feb 19, 2012 9:23 pm
Thanks Wayne and all
Nig
745E
G. O'Shea
Sent: 08 June 2010 01:25
Subject: Re: [rebel-builders] Amphib Hydraulic level
an issue!
Hi All
reservoir
I'm
Nig
745E
