FUS 33 install
mikeh
FUS 33 install
Post by mikeh » Sun Feb 19, 2012 8:58 pm
Hi Roland,
I seem to remember having plenty of material to trim off after
drilling. I drew a 5/16 line on one side and drilled through the skin, and
drilled through the other skin where it suited. I had a friend holding Fus
33 in place while I drilled just to make sure it was hard against the
bulkheads. Your skins must be in the right place if they fit on the
bulkheads so I'm wondering if your Fus 33 is the right size? Let me know if
you need and I'll measure mine.
Cheers Mike 818R
