Received: from MMoreho699@aol.com
by imo19.mx.aol.com (IMOv14_b1.1) id ERAPa14533
for <murphy-rebel@dcsol.com>; Thu, 28 May 1998 20:41:45 +2000 (EDT)
Message-ID: <1beffe60.356e044a@aol.com>
Date: Thu, 28 May 1998 20:41:45 EDT
Mime-Version: 1.0
Subject: Bulkhead F and Bottom skins again
X-Mailer: AOL 2.7 for Mac sub 3
Howdy!
I just called Dennis at MAM to figure some things out about my flying
machine
to be. I was perhaps more confused afterwards and sent him a note with some
pics of my problem. I don't know if he'll get the JPEG attachments, so I
would
appreciate anyone's help here.
So I'm writing down a verbal description, then posting 3 JPEG attachments in
separate post so you won't have to download them if you don't want to.
In building Bulkhead F, I used two round bulkhead 2A's and riveted them
together so it spans 44" side to side on the outside. This corresponds to
fig.
62a of my 03/14/95 Rebel 280 manuel pg. 13-71
When I do this, the distance between the predrilled holes in the straight
part
of the flanges right next to the corner tabs is 31".
I already have fus 39 (bottom skin) layed out flat on the table. Each side
has
predrilled holes one inch apart. I align the predrilled hole in the end of
the straight part of the flange of bulkhead A over the first of these holes
in
the bottom skin.
Then I slide the other side of the bottom skin under the other side of
bulkhead A and align the two similar holes on the other side. This went
well.
Then I take Bulkhead F, reverse it with the flanges facing backwards, and
cleco through the predrilled hole of it's straight part of the flange (next
the corner), through the predrilled hole in the bottom skin onto the table.
But when I go to align the opposite ends of Bulkhead F and the bottom skin,
Bulkhead F's hole is 3/4" too short to reach the predrilled bottom skin
hole.
So, question 1) Why are bulkhead F's holes 3/4" to short when the outside
dimensions of the uprights are 44" and when bulkhead A aligned fine?
Question 2) After solving this puzzle, where do I locate bulkhead F on the
bottom skin? Seems like all one has to do is count how many 1" spaced
rivets
there are between bulkheads A and F.
Remember, confusion gives clarity of mind it's brilliant luster!
Dan
Received: from FLYBOY.MSCOMM.COM (annex517.mscomm.com [205.227.95.37])
by victor1.mscomm.com (8.8.8/8.8.5) with SMTP id HAA02411
for <murphy-rebel@dcsol.com>; Fri, 29 May 1998 07:40:56 -0700 (PDT)
Message-ID: <356EC738.1842@mscomm.com>
Date: Fri, 29 May 1998 07:33:28 -0700
Reply-To: flyboy@mscomm.com
X-Mailer: Mozilla 3.04Gold (Win95; I)
MIME-Version: 1.0
Subject: Re: Bulkhead F and Bottom skins again
References: <1beffe60.356e044a@aol.com>
MMoreho699@aol.com wrote:
Congratulations I think you have been "Mam'ed". I too had problems with
serial#287 a couple of years ago. It seems like back in the dark ages
Mam made up a bunch of bad skins, rather than going through stock and
removing them they just waited for builders to find themand call for new
ones. If my memory is correct(doubtful) the bottom skin should not have
the bulkhead holes pre drilled.
Rich Bartman
MIME-Version: 1.0
machineHowdy!
someto be. I was perhaps more confused afterwards and sent him a note with
wouldpics of my problem. I don't know if he'll get the JPEG attachments, so I
in aappreciate anyone's help here.
fig.separate post so you won't have to download them if you don't want to.
part62a of my 03/14/95 Rebel 280 manuel pg. 13-71
hasof the flanges right next to the corner tabs is 31".
ofpredrilled holes one inch apart. I align the predrilled hole in the end
holes inthe straight part of the flange of bulkhead A over the first of these
well.the bottom skin.
(next toThen I take Bulkhead F, reverse it with the flanges facing backwards, and
table.the corner), through the predrilled hole in the bottom skin onto the
skin,But when I go to align the opposite ends of Bulkhead F and the bottom
hole.Bulkhead F's hole is 3/4" too short to reach the predrilled bottom skin
rivetsSo, question 1) Why are bulkhead F's holes 3/4" to short when the outside
Danthere are between bulkheads A and F.
Dan
Rich Bartman
