Wing Install
David R. Greaton
Wing Install
Post by David R. Greaton » Sun Feb 19, 2012 8:54 pm
Hi All,
I'm getting ready to install my wings.
I'm confused. In the manual it says to drill to the final size on the main spar attach 1/2". My main spar on the wing is already drilled to 3/4". What's up???
Thanks in advance,
Dave Greaton
SR/Moose 189
David R. Greaton
Wing Install
Post by David R. Greaton » Sun Feb 19, 2012 8:58 pm
When installing the wings do you use the hole in the rear fuselage wing attach as a guide or do you have to set an angle of incidence then drill to fit. I can't find anything in the manual.
Dave Greaton
Moose 189 Maine
