What I read is quite clear.......... It's not a "warning", but it does make
a special "note" of spar (W-117) position........... W119 is the Front Spar
Fitting.
*10.7 Front Spar*
2) Lay out a Front Spar (W-117) as in Figure 10.7.1.
I can email you the chapter on this directly if you like. Like many things
in this build manual, the "details" can be easily overlooked.
Jeff
PS: Hopefully you can still use your front spar.
On Tue, Nov 10, 2009 at 7:58 PM, Ron Stahla <rmstahla@hotmail.com> wrote:
To all those who are building the wing,
The front spar for the left and right wing is the same part number (W119),
but is not a symetrical part ie.you can not turn it over and use it with the
root end for the front spar fitting attach holes at the root end of both
wings. There is a top and a bottom to the spar ( the bends on the top and
the bottom are different) . There is no warning in the plans about this .
Ron
Find the right PC with Windows 7 and Windows Live.
http://www.microsoft.com/Windows/pc-sco ... en2:112009
