Aurele, type A aux.heater (HXWxD) 5 1/4"X7 1/4"X3 1/2") catalog no. 424007US
$ 61.99
Fan switch 4210027 (2 speed) US $ 5.49
Fan knob 4240020 US $ .99 The heater is 3425 BTU and is the smallest they
carry.
Their USA toll free order no. is 1-888-460-7989 They were out of stock for
at least four months, hopefully they made up enough to fill future orders.
Good luck, Geert Frank PS bobp put me on to this heater and maybe after the
dust settles after the last Sunday meeting he will come up with an answer to
my questions.
Rebel heater
Rebel heater
*-----------------------------------------------------------------------------------*Hi Geert !!
Sorry, I'm temporarily out of action with a horrible flu bug !
It started on Friday, and I wasn't in good shape for the Builders
Meeting, but it really got bad yesterday - lots of it going around !
The heater can mount right under the panel - just add a bracket
to the support tubes & hook up the plumbing ! Wayne's right - it's
just a single speed/ on-off motor, and you can regulate heat with a
water valve. Might be handy to have that valve on the panel, too.
You're having more luck than us - haven't seen ANY of those
heaters here in over a year !
I don't think it would be a good idea to try using Elite
bellcranks - the whole setup is a bit different, but the Rebel
bellcranks have changed several times over the years. You might
want to get the dimensions for the current parts & compare.
Of course, the best solution is just to go back to the
flapperons, which work just great !! ;-) No problem with
gusty 25 Kt. crosswinds ... :-)
Heading back to bed ....
....bobp
---------------------------orig.--------------------------------------
At , you wrote:----------*At 10:26 AM 11/14/00 -0500, you wrote:----------*
