[rebel-builders] Baffle touching the cowling
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 8:33 pm
Yes, that is the corner where you need to cut down your baffles as much as you can to prevent contact. When I did my 360, I noticed a vibration on my panel and in the cockpit under high power when I was climbing out. It was fine at cruise, though, and had me "baffled" for a while. Turns out that the engine has enough torque twist at high power with the dyna focal mounts to require a little extra space on the right side of the baffles.
As far as how much exactly, it was basically trial and error. I kept trimming it down until the vibration went away.
Date: Wednesday, September 23, 2009 11:00 am
Subject: [rebel-builders] Baffle touching the cowling
[quote]
My Rebel engine baffle has put a mark on the cowling fiber glass
cover, I noticed a chipped paint came off the cowling, the
location is near the corner of #3 cylinder where baffle bent 90
degree. Any one knows waht's the baffle to cowling clearance
should be? I think it was cuased during Engine start, otherwise
it would be worse, my prop dynamic test was better than normal.
Jay/N654JM
Bing
Michael Kraus
Post by Michael Kraus » Sun Feb 19, 2012 8:33 pm
On my RV-10 Vans recommends 3/8"-1/2" clearance to the cowl...
-Mike Kraus
Sent from my iPhone
cover, I noticed a chipped paint came off the cowling, the location
is near the corner of #3 cylinder where baffle bent 90 degree. Any
one knows waht's the baffle to cowling clearance should be? I think
it was cuased during Engine start, otherwise it would be worse, my
Jay/N654JM
Bingâ„¢ brings you maps, menus, and reviews organized in one place.
Try it now.
http://www.bing.com/search?q=restaurant ... _local_1x1
