That's a very nice looking Rebel Rick! Sure wish I was still in South
Australia where I spent 5 years flying my Murphy Renegade Spirit all over
the place, including the Australian version of Oshkosh in Victoria. Now I
can't remember the name of the airport or the event. Where you able to
attend anytime between 1991 and 1996? I was there one year with my blue and
white Renegade Spirit, and another year with a 1948 Stinson Voyager.
SR#044
Rebel Questions
Rick Harper
Rebel Questions
Sent: Monday, 2 July 2001 11:29
Subject: RE: Rebel Questions
G'DAY MIKE !
(AND SORRY TO EVERYONE ELSE....I DIDN'T MEAN TO SEND ALL THOSE
PIC'S TO THE CHAT PAGE....I'M NOT VERY GOOD AT THIS KOMPUTTER
STUFF :-)
THANKS !
Where you able to
OUR TRIKE (POWERED HANG GLIDER)....WE CAUSED QUITE A STIR
WHEN WE ARRIVED DUE TO THE AMOUNT OF LUGGAGE AND CAMPING
GEAR WE HAD STRAPPED TO THE SIDE OF IT ! (AND UNDER, AND STUFFED
INTO THE WING CAVITIES ETC, ETC )
I DON'T REMEMBER A BLUE RENEGADE....BUT I DO REMEMBER AN OLD
RED STINSON...AND TALKING TO THE PILOT AND PASSENGER AT THE
TIME !!! (I THINK THAT WAS ABOUT 95-96 ISH )
FROM MEMORY ONE OR BOTH GUYS WERE WHITE HAIRED...BUT I'M NOT
100% SURE....WAS THAT YOU ?
RICK & WENDY
541R
G'DAY MIKE !
STUFF :-)
THANKS !
YOU MEAN TO "MANGALORE" .....Australia where I spent 5 years flying my Murphy Renegade Spirit all over
Where you able to
andattend anytime between 1991 and 1996? I was there one year with my blue
WENDY AND I FIRST WENT / FLEW TO MANGALORE IN ABOUT '94 INwhite Renegade Spirit, and another year with a 1948 Stinson Voyager.
RICK & WENDY
541R
Rebflyer
Rebel Questions
Hi Brian
I can't remember if you were asked these questions or not so here goes again. Have you tested the gage? Where are you picking up the temp? From a probe style thermo couple ala original equip or an under the plug style? The under the plug style is a plus 40
deg on the bottom and a -40 under the top plug compaired to the screw in probe style.
I too have the speed cowl and the temps on mine are ok. Good luck the answer is there somewhere. Curt N97MR
Rebel Questions
Hi Brian !
Yes, I always use full flapperon for takeoff and landing.
That's what it was designed for ! This is NOT a Cessna, it's a
real airplane ! The flapperons alter the shape of the whole airfoil,
to provide more lift - unlike the barn doors on a Cessna that are
designed for drag.
I always used flapperon on takeoff on floats, too - it just
hops off the water.
The standard cowl from Murphy is $285 USD. It has a fiberglass
nosebowl and aluminum sides, and can be modified to be very accessible.
Your speed cowl can be made to work better, though -
if you add the cowl flap at the bottom, you should get better cooling.
This is a copy of the bottom channel made of aluminum, hinged at the
carb., so it can swing down at the back - Glen Cook's is working very
well. Also, rounding off the lip at the bottom of the firewall should
help.
Note Curt's words of wisdom on the type and position of CHT
sensor - the spark-plug type will read 40 degrees lower on the top
plug than the bottom !!
------------------------------------orig.-------------------------------
designed for drag.
hops off the water.
help.
Bob, are you saying you use FULL flaperons on takeoff? I have only about 8
takeoffs so far and havew found that no flaps seems to work as good as 10 or
20 degrees. The Rebel just leaps off with no flaps. What kind of performance
do you get when you use full flaps? I know most Cessnas recommend only 10
degrees at takeoff. I would have thought there would be wy to much drag at
full flaps. Mine is amphibious and I wonder what I will use on
floats.....Thanks....Brian
Also, I have gotten the engine to come down to 430 Fahrenheit, but I have
tried everything I can think of and can't get it to go lower. My spinner is
1/4 inch in front of my cowl and I have tried all kinds of exits and cut the
top of the inlet 1 inch and niothing seems to be working. I was thinking I
should build the other cowl as I have the SPEED COWL. Please tell me what it
costs....Thanks again....Brian
_________________________________________________________________From: Bob Patterson <bob.patterson@canrem.com>
Subject: Re: Rebel Questions
Date: Sat, 16 Jun 2001 20:28:29 -0400
Hi Rick !
Glad you're back in the air again !!!
Wow ! You've got the furthest forward C of G of ANY flying
Rebel I know - sounds like a few pounds in the back might be a good
idea. (I usually carry a tool kit in the baggage area - solves the
weight problem, and the tools come in handy ! ;-) )
(My CofG is at 8.1" aft of datum - these days, MAM suggests 12")
This is one reason several builders have chosen to use the Scott 3200
tailwheel - it adds a few pounds 'way back there. ;-)
You're absolutely right - it IS impossible to load the Rebel
outside of limits without bumping into gross !!! Isn't that a really
NEAT feature !!??? How many airplanes can claim THAT ??!!!
The weight in back will help the flair. FWIW - I <ALWAYS>
take off AND land with FULL flapperons. The Rebel was designed to
use the flapperons to reduce stall speed and improve performance
on BOTH ends of the flight - so I USE them !! Bleed down to
second notch of flapperon after climbing to about 50 ft. or so -
this gives best climb. Play with yours - one notch <might> work
better ...
To use the full position safely, I approach at about 75+ mph,
which gives a very steep approach, cutting through wind gradients
without any risk, then break the glide at about 20 feet, eventually
levelling out about a foot above the ground. I let it float there
while I get to the "right" attitude for touchdown. The speed bleeds
off VERY quickly once level, so get the tail DOWN. Do not try to
approach below 65 mph until you are VERY familiar with the Rebel -
it will develop a very high sink rate, while still having full
control. This often fools people into thinking they are flairing,
when they are really descending over 1,500 feet/min. !!! This usually
results in a bent bird ! :-(
The O-235-L2C really LIKES to rev. - cruise should be at
about 2,450 or more, so it sounds like you need to back off a bit
on the pitch. Your engine is "new", so you don't want to lug it
while breaking in - normall procedure is full throttle until the
rings seat (about 2 hours or so ...) Peak RPM on some L2C's I've
flown was 2,700 ! If you get over 120 hp., you should add another
notch of negative flapperon - it will pull it. With one notch neg.,
you should get about 112-115 mph, and the second notch will give
another 3 mph, and a smoother ride in turbulence ! Always use
negative for cruise - it unloads the wing, making it more gust-
resistant.
Glad you're enjoying the Rebel - welcome to the club !!!
We're the guys with the BIG smiles !!! ;-)
Keep building guys - it REALLY <IS> worth it !!!
------------------------------orig.-------------------------------------
At 09:39 AM 6/17/01 +1000, you wrote:hours under our wings.G'day to All from sunny but COLD OZ!
I'm a happy vegemite again.....we're back in the air, with a few more:-)I fitted Wayne's firewall mods and have the new oil cooler in placehelp us out with.I have a few questions which I'm hoping some of you long time flyers canonWe have an 0-235 Lycoming with a standard firewall...IE: NOT shortened.
I also took good notice of Bob and Wayne and we have 28' of UP elevator
tap.Line.The C of G range as advised by MAM is 276 mm to 459 mm aft of the DatumofOur EMPTY C of G is 197 mm ( nearly 8 " ) aft of the datum line (front
the wing / gear leg)virtually impossible to getAfter doing several loading charts...I came to the realisation that it isbeing the all up MTOW ofthe Rebel out of its C of G range...the only real limiting factor heretank1650 Lbs (750 Kgs)........do you guys agree with this ?
With just "little ol' me" , 130 Kgs (just under 290 lbs) and a half a
of gas ..120 Lts / 30 US gallons (we went out one more rib with the tank
have 240 litres space !)...I seem to run outjust under 40 knots ..of FLARE ...SUDDENLY.......at the last second !?!....(which is probablymywith no flaps)
Is this normal Rebel stuff ?...........
or should I perhaps stick 5 to 10 lbs of weight down in the tail to move
empty C of Gseconds of roundout / flare )back a bit ?................( I'm thinking this might help the last fewthings :
Also, could someone out there offer some advice on the engine side ofmarine engineer )As I said before , we have an 0-235 Lycoming ..which I rebuilt myself (..."cleaned up" the ports aI fitted new "J" model pistons ( the 9.7:1 variety )...and cylindersfullyfair bit (got rid of the dags and misalignments in the castings etc ,
balanced the enginecrossoverthroughout..propeller extension as well , made up a 2" stainless
exhaust systemignition systems...whichand replaced one magneto with one of Klaus Xavier's LSE crank firedI'mis supposed to give a 4% boost to the power as well........all in all,
expecting this suckerandto put out 130 H.P. without having done any major mod's.
I'm getting 2200 - 2300 STATIC full power RPM and flat out in straight
level flight shearoundhits 2500ish RPM.....and with no reflex on the flaperons is hitting
100 knots .....every(it's rather hard to tell at this point as its been BLOODY WINDY here
day since we'verepitchingbeen back in the air)
Do these figures sound about right to you guys...or should I be
the Warp Driveup the list of peopleto get more RPM ?....
The plane flys beautifully and is an absolute joy.....can't wait to takeOZ! on my "waiting list" :-)
Rick & Wendy Harper
541 R....FLYING !
<HTML><HEAD>
<META content="text/html; charset=iso-8859-1" http-equiv=Content-Type>
<META content="MSHTML 5.00.2314.1000" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT size=2><EM>G'day to All from sunny but COLDagain.....we're </EM></FONT></DIV>
<DIV> </DIV>
<DIV><EM><FONT size=2> I'm a happy vegemitenew oilback in the air, with a few more hours under our wings.</FONT></EM></DIV>
<DIV><FONT size=2><EM> I fitted Wayne's firewall mods and have thelongcooler in place :-)</EM></FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=2><EM>I have a few questions which I'm hoping some of youfirewall...IE:time flyers can help us out with.</EM></FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=2><EM>We have an 0-235 Lycoming with a standardweNOT shortened.</EM></FONT></DIV>
<DIV><FONT size=2><EM>I also took good notice of Bob and Wayne and
haveto28' of UP elevator on tap.</EM></FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=2><EM>The C of G range as advised by MAM is 276 mm
459nearlymm aft of the Datum Line.</EM></FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=2><EM>Our<STRONG> EMPTY </STRONG>C of G is 197 mm (leg</EM></FONT><FONT8 " ) aft of the datum line (front of the wing / gearit issize=2><EM>)</EM></FONT></DIV>
<DIV> </DIV>
<DIV>After doing several loading charts...I came to the realisation thatherevirtually impossible to get</DIV>
<DIV>the Rebel out of its C of G range...the only real limiting factorabeing the all up MTOW of </DIV>
<DIV>1650 Lbs (750 Kgs)........do you guys agree with this ?</DIV>
<DIV> </DIV>
<DIV>With just "little ol' me" , 130 Kgs (just under 290 lbs) and a half
tankandof gas ..120 Lts / 30 US gallons (we went out one more rib with the tankprobablyhave 240 litres space !)...I seem to run out </DIV>
<DIV>of FLARE ...SUDDENLY.......at the last second !?!....(which ismove myjust under 40 knots ..</DIV>
<DIV>with no flaps)</DIV>
<DIV> </DIV>
<DIV>Is this normal Rebel stuff ?...........</DIV>
<DIV>or should I perhaps stick 5 to 10 lbs of weight down in the tail tohelp theempty C of G </DIV>
<DIV>back a bit ?................( I'm thinking this mightoflast few seconds of roundout / flare )</DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV>Also, could someone out there offer some advice on the engine sidemyself (things :</DIV>
<DIV> </DIV>
<DIV>As I said before , we have an 0-235 Lycoming ..which I rebuiltetc ,marine engineer )</DIV>
<DIV>I fitted new "J" model pistons ( the 9.7:1 variety )...and
cylinders ..."cleaned up" the ports a </DIV>
<DIV>fair bit (got rid of the dags and misalignments in the castingscrossoverfully balanced the engine</DIV>
<DIV>throughout..propeller extension as well , made up a 2" stainlessall,exhaust system</DIV>
<DIV>and replaced one magneto with one of Klaus Xavier's LSE crank fired
ignition systems...which</DIV>
<DIV>is supposed to give a 4% boost to the power as well........all in
I'mstraightexpecting this sucker</DIV>
<DIV>to put out 130 H.P. without having done any major mod's.</DIV>
<DIV> </DIV>
<DIV>I'm getting 2200 - 2300 STATIC full power RPM and flat out in
andaroundlevel flight she</DIV>
<DIV>hits 2500ish RPM.....and with no reflex on the flaperons is hittinghere100 knots .....</DIV>
<DIV>(it's rather hard to tell at this point as its been BLOODY WINDY
everyrepitchingday since we've </DIV>
<DIV>been back in the air)</DIV>
<DIV> </DIV>
<DIV>Do these figures sound about right to you guys...or should I bewait tothe Warp Drive</DIV>
<DIV>to get more RPM ?....</DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV>The plane flys beautifully and is an absolute joy.....can't*-------------------------------------------------------------------------*take up the list of people</DIV>
<DIV>on my "waiting list" :-)</DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV>Rick & Wendy Harper</DIV>
<DIV>541 R....FLYING !</DIV></FONT></EM></DIV></BODY></HTML>
murphy-rebel mailing list.
Get your FREE download of MSN Explorer at http://explorer.msn.com
