Tailspring mod
Legeorgen
Tailspring mod
Post by Legeorgen » Fri Feb 17, 2012 11:26 pm
Wayne,
About the laminated sheets... what a great explanation! I appreciate your
commence sense and engineering knowledge. I'll take that and your real world
experience any day.
Bruce G 357 R
Tailspring mod
Post by Wayne G. O'Shea » Fri Feb 17, 2012 11:26 pm
Your following message has been delivered to the 166 members of
the list murphy-rebel@dcsol.com at 23:33:35 on 3 Oct 2000.
THANKS! Can I sell you some swamp land?!?!?!?!? Comes complete with 5
Trumpeter swans!
Sent: Tuesday, October 03, 2000 11:26 PM
Subject: Re: Tailspring mod
Wayne,
world
experience any day.
Bruce G 357 R
rebelair
Tailspring mod
Post by rebelair » Fri Feb 17, 2012 11:26 pm
Hi Folks
Can anyone please put the tail post AD from MAM on this site? My email
password at MAM is longer working. I would appreciate it if you could post
it for me.
Brian #328R
Sent: Monday, October 02, 2000 9:32 PM
To: (Murphy Rebel Builders List)
I have done the tail post fix, as per MAM's bulletin, but haven't done this
doubler fix
yet. As I understand it, this protects against hard landings and rough tail
wheel
handling. What if you are on floats? Is this doubler mod still necessary? My
apologies if
this has already been answered.
"Wayne G. O'Shea" wrote:
The doubler sounds great Joel! This will really help strengthen the tail
spring area!
Sent: Monday, October 02, 2000 11:07 AM
Sent: Sunday, October 01, 2000 5:48 PM
Yes, I would still do the .032 doubler between the post and the spring
attach bulkhead, as we "Ontarians" have been doing for some time (8
years
I got my tailwrap doubler fitted over the weekend. For the trim line I
fastened a felt tip marker to a piece of string. I held the marker at
top of the tailwrap at the fin spar and held the string at the bottom
corner
of the tailwrap. I drew an 90 degree arc that ended about 8" forward
from
the bottom rear corner.
The doubler catches the bottom 2/3rds of the bathtub fitting and
extends
about 2" in front of the tailspring bolt. Does this sound like I did it
right? I don't have any good pictures of a Rebel with this doubler on
it.
Joel
Drew and Jan
Tailspring mod
Post by Drew and Jan » Fri Feb 17, 2012 11:26 pm
Sent: Tuesday, October 03, 2000 10:05 PM
I have to disagree with you on this Ken rolled aluminum definatly has a
grain and is stronger in one direction. I can tear .020 with my hands
along
the grain. try it. Drew Dalgleish
How do you remove the blood stains after attempting this? ;)
Joel
I just bathe in MEK. It gives mev a nice cool tingly feeling :}
drew
Click here for Free Video!!
http://www.gohip.com/freevideo/
Joel Jacobs
Tailspring mod
Post by Joel Jacobs » Fri Feb 17, 2012 11:26 pm
along
Joel
Wray Thompson
Tailspring mod
Post by Wray Thompson » Fri Feb 17, 2012 11:26 pm
It's available on my site under safety bulletins.
http://webhome.idirect.com/~wrayt/bulletin.html
rebelair wrote:
Hi Folks
it for me.
Brian #328R
Wray Thompson ...Rebel 306 ...home page http://webhome.idirect.com/~wrayt/
My ICQ number is 29764664
klehman
Tailspring mod
Post by klehman » Fri Feb 17, 2012 11:26 pm
Hi Drew
Neat (but scary) experiment. It seems to tear easilly with or against
the grain for me. (started the cut with the shears and then tried
tearing it).
Sure illustrates why nicks and scratches are not a good thing.
A good point though, aluminum sheet certainly has a grain and as such it
should be easier to tear or fatigue it parallel to the grain. Generally
metal does fail along the weaker grain boundaries. That is a failure
mode that may have to be allowed for in some applications. If you bend
the metal to its yield point, such as when we intentionally bend a
bracket, it certainly makes sense to do it at right angles to the grain
where possible.
But we are trying to operate our airframe in the lower stress region
below the yield point (where the metal is permanently bent). In this
region the aluminum generally has the same strength in all directions as
I understand it.
I'm curious if anyone has ever seen a recommendation to not parallel the
grain when fabricating a doubler?? I never have but I'm not too old to
learn a new trick if someone else has.
grain and is stronger in one direction. I can tear .020 with my hands along
Tailspring mod
the list murphy-rebel@dcsol.com at 17:05:49 on 4 Oct 2000.
The great joys of a Democratic Society!!! We can all take as much as we
"cared" to absorb from those personal one sided (not neccessarily correct)
views that our Professors and Teachers rammed down our throats in "Strength
of Materials" lectures and combine this <little> retained engineering
knowledge with (in my case) 20 years of practical, hands on experience with
4 years in glass blow moulding (plant electro-mechanical engineer -
Consumers Glass - Milton), 16 years (and more every day) in plastic
injection moulding (owned corporation) and of course the last 7 years
working with aluminum (40 to 60 hours per week), and come up with <our> own
views as to what is a correct answer! I'm definitely not saying that I have
all (or any of) the correct answers, just stating it's the way <I> "care" to
decifered the Engineering aspects and knowledge gained from the 38 years
I've been alive!
Keep at it guys, your keeping my old engineering books dust free anyways!!!!
Regards to all,
Wayne G.O'Shea
At 01:36 PM 10/3/00 -0400, you wrote:
Another opinion FWIW...
I can not agree that two 0.020 laminated sheets are stronger than one
0.040 sheet. In some modes such as bending they will generally be weaker
due to stress concentrations at rivets, but admittedly that is not a
mode that is usually significant for us. Aluminum is not generally
stronger in one plane or direction than another,
along
rebelair
Tailspring mod
Hi Ken
Thanks very much for sending me the AD on the tail. I will try the MAM site
as you mentioned.
Best Regards
Brian
From: klehman@albedo.net [mailto:klehman@albedo.net]
Sent: Wednesday, October 04, 2000 9:03 AM
Hope you don't get a dozen copies - Ken
ps.- lately if you go to the MAM home page and click on SUPPORT it seems
to work without a password.
rebelair wrote:
Hi Folks
post
it for me.
Brian #328R
this
doubler fix
tail
wheel
My
apologies if
spring area!
spring
years
corner
from
extends
it
it.
Joel
rebelair
Tailspring mod
Hi Wray
Thanks very much for directions to the AD on your site. I will have a look.
Happy Building
Brian
rebelair
Tailspring mod
Hi There
I bet that when you get MEK into a cut after attempting to bare handedly rip
0.020" aluminium along the grain, you get more than a cool tingly feeling.
Downright painful in my experience!
Brian #328R
Sent: Wednesday, October 04, 2000 5:20 AM
along
Joel
drew
Legeorgen
Tailspring mod
In a message dated 10/4/00 8:36:40 AM Pacific Daylight Time,
wrayt@idirect.com writes:
Wray,
Great job on your web page. I used it extensively when I first was pursuing a
Rebel purchase. Thanks.
Bruce G 357R
Joel Jacobs
Tailspring mod
Sometimes when I get cut I'll glue the wound shut with super glue. After
all it says right on the tube "bonds skin on contact" No kidding!
Joel
Sent: Wednesday, October 04, 2000 11:43 PM
Subject: RE: Tailspring mod
Hi There
rip
Brian #328R
along
Joel
drew
Terry McClary
Tailspring mod
Post by Terry McClary » Fri Feb 17, 2012 11:26 pm
I read somewhere that Super Glue was a war development effort to be used
in closing wounds. Faster than stitching and I guess more sterile for
the wound.
Terry
On Thu, 5 Oct 2000 11:04:40 -0400 "Joel Jacobs" <jj@netexp.net> writes:
After
Joel
Hi There
handedly
rip
feeling.
Brian #328R
definatly has a
hands
along How do you remove the blood stains after attempting this? ;)
Joel
drew
Guest
Post by Guest » Fri Feb 17, 2012 11:50 pm
