thin bead, do you circle each rivet?
David, did you make that landing light setup from scratch or buy something
to start with?
Mike Betti
771 Elite
Sent: Monday, February 28, 2005 7:13 PM
Subject: Re: Tank Sealants
theKen
The caulking tube really is the hot tip, check my web site for the link to
gramssupplier, look under wings.
Jean Poirier wrote:
Hello
I have buy a mail balance at Office Depot for $49.95. It make both
yogourtand once. Easier in gram! I mix the /$?%&/%" stuff in empty small
Ipot and use it with a popsicle stick for small batch. For biggest job,
workhave buy empty caulking tube, I cut them to +/- 4" long before fill.
lotwell if anything could work well with that "/$?%&/%/ stuff!
Jean
Rebel 747R
Sent: Monday, February 28, 2005 2:00 PM
I've never heard of a nitrogen purge for an end user and I dug up a
forof info on proseal.
Seal it and put it in the deep freeze if you have one and it is good
Aa long time. Warm it before opening so it doesn't condense moisture.
Yes the B2 grade is what MAM ships.
I used a triple beam balance which is good for 0.1 gm to measure mine.
uplot of the affordable electronic scales don't really have the the
accuracy/resolution for small batches. I think some folks have rigged
capa simple homemade 10:1 balance beam.
Mike Betti wrote:
store it
too
for
arrives?
stuff?
David A. Ricker
Fall River, Nova Scotia
Canada
