passengers position their feet with the seat fairly far back.
mikeh@dcsol.com wrote:
Hi all,
I've been watching with interest, and there are some good ideas
circulating. For what its worth, I've decided to fit the bearings reversed
and rivet the mounts. That gives me easy removal of the column, easy
replacement of the bearings and thrust washers, and saves the weight of 6
or 9 bolts, washers and nutplates.
By the way, has anyone ever substituted chrome moly steel tubing for
the FUS 5 as a beef up for the spring gear? This might give a stronger
thread to bolt the control column bearing bases as well. Maybe the tapped
aluminium threads are strong enough anyway?
I know none of this is any help if you have drilled the holes already,
and the weight of a steel FUS 5 makes the weight of a few little bolts
insignificant!
Cheers Mike
