[rebel-builders] control column mount
Post by Wayne G. O'Shea » Sun Feb 19, 2012 9:03 pm
?? Double end bracket ?? I just drill and tap the holes, for AN3 bolts, for
the right side... so that it's removable.
Sent: Saturday, February 06, 2010 12:18 AM
Subject: [rebel-builders] control column mount
There's been mention a few times of using a double end bracket to allow
removal of the control column for under panel maintenance, etc., but I'm
having a hard time visualizing how that's supposed to be done. Does anyone
have a photo or sketch of that design? Or perhaps just further explanation
suitable for the Dept. of Dunce?
254R
http://n254mr.com
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 9:03 pm
Thanks, Wayne. That would be possible in new construction, but when I got
the project the holes were already drilled for 3/16" rivets, so there's
nothing left to tap, at least for 10/32 threads. With no stop nut or
equivalent, have you seen any problems with the bolts loosening?
The only solutions I've come up with is to either drill and tap for AN4 or
use rivnuts for AN3, although the grip length needed is borderline for the
max grip AN3 rivnuts I've found so far. Absent some other solution, I'm
inclined to drll & tap for AN4, installed with some Loctite. That would
leave the option of drilling to a full 1/4" insertion hole the AN3 rivnuts
need later on if necessary.
On Sat, Feb 6, 2010 at 7:00 AM, Wayne G. O'Shea <oifa@irishfield.on.ca>wrote:
Post by Ken » Sun Feb 19, 2012 9:03 pm
Another way for guys with cut in half carry throughs or moved firewalls
is to cut off the bracket bottom flanges. Rivet angles to the floor and
bolt the bracket to the angles.
To be honest though, despite installing and modifying several pieces of
electronics, I've yet to remove the control column despite hanging
upside down on the seats several times per year. Makes me think this is
not worth very much extra effort if you can't quickly do it Wayne's way.
254R
http://n254mr.com
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 9:03 pm
I drilled and riveted in plate nuts. It will take a little rework but in
your case maybe you could build the right side bearing holder like Roger
Hoffman did. Check out his website on the Rebel list.
Charlie
Sent: Saturday, February 06, 2010 11:56 AM
Subject: Re: [rebel-builders] control column mount
for
Ron Shannon
Using separate angle brackets is quite an appealing idea. As for the
desirability of movability to begin with, I may have more stuff crammed in
and behind that panel than any other Rebel to date. It's relatively
organized, but still quite a thicket. After spending the better part of a
year under there, my back hurts just thinking about lying flat, much less
draped over seats and/or control column. I'm guessing you must do a lot of
yoga. :-) As I should, no doubt.
Thanks.
Ron Shannon
Good reminder, Charlie. I've gotten so many great ideas from Roger's work I
don't know why I haven't thought to look there yet on this issue.
On Sat, Feb 6, 2010 at 10:13 AM, Charlie Eubanks <charlie@troyairpark.com>wrote:
Charlie
Ron Shannon
For others interested in this topic, here's a link to a photo of Roger
Hoffman's installation, where he used separate floor mounted angles for
attaching the control column mounting brackets, much as Ken suggested. *
http://tinyurl.com/ydfsxnp* Looks like the way to go.
Charlie
I'm having email issues right now .. and not getting stuff from the list..
but I just read the archives.
In Roger's pictures he has the delrin hat bearings in backwards. I've seen
this done on a few.. and it does make it so you can remove the bearing and
get the column out of the way. It isn't however how the column was intended
to run on the delrin for a bearing surface. Idea was for the large aluminum
washer to run on the wide face of the "hat"... not the small face of the
bushing wall.
Probably not a huge deal.. but thought I better throw it out there for
debate! lol
254R
http://n254mr.com
Post by Drew Dalgleish » Sun Feb 19, 2012 9:03 pm
My column got premenantly mounted before I started on the panel so I've
spent lots of time on my back on top of the column. I found that a thick
cushion off an old couch made laying under the panel reasonably comfortable
and it had the added bonus of raising my shoulders up high enough that I
was in a good working position.
for
254R
http://n254mr.com
David A. Ricker
Post by David A. Ricker » Sun Feb 19, 2012 9:03 pm
Ron, Guys
If you already have drilled holes to deal with like Ron then you could
put Key Lock Inserts onto the structure for the threaded hole.
http://www.mcmaster.com/#key-locking-inserts/=5pd9b3. I'm assuming
there is enough thickness to accept the insert of course.
For those who haven't seen them, Key Locks are basically a bushing with
external and internal threads that can be used for repair of stripped
threads or to give a stronger receptacle in materials like aluminum
which are not great when tapped. The insert gives you a stronger
connection in the parent material for your smaller size fastener. The
inserts are threaded in place and the locking pins are driven between
the parent material and the insert locking them in place. We use them
at work in designing custom aluminum cranes.
These aren't to be confused with Helicoils, different beast.
Checked by AVG - www.avg.com
Version: 8.5.435 / Virus Database: 271.1.1/2671 - Release Date: 02/06/10 07:35:00
Ron Shannon
Thanks, Dave. Looks like a good fastener for many applications. I wasn't
familiar with these and am glad to know about them. However, personally I
think I'm going to go with the floor mounted angles because A) I have the
materials already, B) I won't have to drill larger holes into the carry
through (looks like the thin Key Locks with internal 10-32 thread need an
"I" drill (~0.267") hole for their 5/16" external thread), and C) I'll have
"above ground" lock nuts that I can see.
254R
On Sat, Feb 6, 2010 at 2:14 PM, David A. Ricker <daricker@ns.sympatico.ca>wrote:
Ron, Guys
schaumr
Post by schaumr » Sun Feb 19, 2012 9:03 pm
I have yet to drill 3/16 holes into FUS05 for the right or left side, so Wayne's
idea of tapping for AN3s is still totally doable for me. Wouldn't it be nice
though, to have some really sturdy threads you'd never have to worry about
stripping?
This then got me thinking about Ron's ubiquitous clickbond nutplates.....could
one "fish" some of these through the gear attach holes on either side of the
FUS05s?
You would have to:
1) Stick some stiff wire through the intended 3/16 holes for the control column
2) fish the wire inside FUS05 over to either side and out the gear attach hole
3) thread or wrap it around the silicone "jig" that goes through the nutplate
(with adhesive applied)
4) pull it through.
5) repeat for each AN3 nut (4 per FUS05 tube)
My floor is still not attached so the last center 3/16 holes that go through the
floor skin are easy.
Sounds complicated, but the only thing to really watch is the edge clearance
between the nutplates and the FUS05 tube vertical walls.
I'll bet Wayne is now screaming at his computer "...JUST TAP"EM AND GET ON
WITH IT!" :)
Cheers!
Rob
Rebel 786
On 2/6/2010 2:04 PM, rshannon@cruzcom.com wrote to rebel-builders:
-> Thanks, Dave. Looks like a good fastener for many applications. I wasn't
-> familiar with these and am glad to know about them. However, personally I
-> think I'm going to go with the floor mounted angles because A) I have the
-> materials already, B) I won't have to drill larger holes into the carry
-> through (looks like the thin Key Locks with internal 10-32 thread need an
-> "I" drill (~0.267") hole for their 5/16" external thread), and C) I'll have
-> "above ground" lock nuts that I can see.
-> Ron
-> 254R
-> On Sat, Feb 6, 2010 at 2:14 PM, David A. Ricker
-> > Ron, Guys
-> > If you already have drilled holes to deal with like Ron then you could
-> > put Key Lock Inserts onto the structure for the threaded hole.
-> > http://www.mcmaster.com/#key-locking-inserts/=5pd9b3. I'm assuming
-> > there is enough thickness to accept the insert of course.
-> > For those who haven't seen them, Key Locks are basically a bushing with
-> > external and internal threads that can be used for repair of stripped
-> > threads or to give a stronger receptacle in materials like aluminum
-> > which are not great when tapped. The insert gives you a stronger
-> > connection in the parent material for your smaller size fastener. The
-> > inserts are threaded in place and the locking pins are driven between
-> > the parent material and the insert locking them in place. We use them
-> > at work in designing custom aluminum cranes.
-> > These aren't to be confused with Helicoils, different beast.
-> > Dave
Charlie Eubanks
I agree... I wasn't suggestion putting the bearings in backwards. The way
MAM designed them is the right way it gives the best bearing contact. There
would be no reason to install them backwards if you could easily un screw
the base and remove the column.
Charlie E. 802R
Sent: Saturday, February 06, 2010 1:22 PM
intended
aluminum
bushing wall.
debate! lol
anyone
explanation
254R
http://n254mr.com
snowyrvr@mtaonline.net
Post by snowyrvr@mtaonline.net » Sun Feb 19, 2012 9:03 pm
Well, tapping is a good plan...or riveting bases in and bolting to them (my
choice). Click-Bonds are great (I truly believe Ron gets a kickback from
the company evrytime he mentions them :) ) but be careful with the
preparation. The surface they go on has to be very clean or they won't
stick or stay stuck. I'm not sure you could do a good job from outside the
area.
Original Message:
Date: Sun, 07 Feb 2010 01:42:14 -0900
Wayne's
nice
stripping?
nutplates.....could
FUS05s?
You would have to:
column
hole
nutplate
4) pull it through.
through the
clearance
WITH IT!" :)
Cheers!
Rob
Rebel 786
have
-> Ron
-> 254R
-> > Ron, Guys
-> > Dave
mail2web.com
Ron Shannon
It would be difficult to do a proper Click Bond installation there, due to
both the surface prep and application issues. If I were trying it, I would
probably transition from stiff wire to fishing line as the pull wire,
because the silicone nipple fixture would need to bend a bit getting into
the hole, and once started up into the hole, you'd have to pull the snake
line through before pulling the fixture up tight. For eighteen holes, it
would take a lot of patience. Among other things, the epoxy does set up
rapidly, and if there's significant delay while attempting to snake one into
place, the epoxy batch will kick off. So you might end up having to use
several batches. In any case, I would practice the snake routine with a dry
nutplate a few times first.
The Click Bonds are super -- one hole, auto centering, etc. -- but there are
a few places they either won't work (FWF) or are just too hard to apply.
[Bummer. That'll be the end of the kickbacks, right there.]
254R
On Sun, Feb 7, 2010 at 9:47 AM, snowyrvr@mtaonline.net <
area.
