Plastic to Brass/alum fitting sealer?
Dave-Sandra
Post by Dave-Sandra » Sat Feb 18, 2012 2:02 am
Wayne ,
A local fellow here in Terrace BC uses a plastic welding process ( uses heat
and a filler rod )to repair plastic tanks and to attach fittings that he
gets from his supplier. I can find out more if you are interested
Dave Bjorkman
(future Moose Builder and avid forum lurker )
Sent: Tuesday, May 20, 2003 4:31 PM
Subject: Plastic to Brass/alum fitting sealer?
My turn to ask a question from all you well rounded knowledgeable people!
Having a problem with a customers Pegastol (read shitbox from K'beck!!) that
has terrible rotomoulded plastic wing & main tanks. It's been an ongoing
battle to try and seal his outlets and drains to keep them from dripping or
weeping. Have tried numerous sealers over the last year + and even the fuel
proof stuff seems to let go with his Esso premium car gas. Seal All, Goop,
Permatex hardening etc all let the fuel get by.
Tomorrows attempt is going to be proseal, but thought I would throw my hands
up in case someone has a better solution as I'm not sure if Proseal is going
to bit into the plastic either.
Tanks are a slippery white polyethylene (I beleive) and some fittings are
plastic, some brass, some alum.
THANKS!
Wayne O'Shea
oifa@irishfield.on.ca
Dave-Sandra
Wayne , I'll try to get ahold of him tonite but it will probably be tomorrow
morning as it is after five pm now
Dave Bjorkman
Sent: Tuesday, May 20, 2003 4:51 PM
Subject: Re: Plastic to Brass/alum fitting sealer?
Dave, If you don't mind looking into it for me I'd much appreciate if there
is a secret to this for leak free fittings. Hate to rush free advise but
time is a waste'n, as I have to have this thing ready to go back in the air
for next Friday and if I go the Proseal route I need a week for that to
cure.
Sent: Tuesday, May 20, 2003 7:47 PM
Subject: RE: Plastic to Brass/alum fitting sealer?
Wayne ,
heat
Dave Bjorkman
that
or
fuel
hands
going
THANKS!
Wayne O'Shea
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:02 am
THANKS!
Wayne O'Shea
cure.
Wayne ,
heat
Dave Bjorkman
that
or
fuel
hands
going
THANKS!
Wayne O'Shea
Okay, thanks!!
I have to go into our plastics plant (that makes you wonder aye! - that I
can't seal stuff to it!!) to do the payroll in the morning, so it will be
LATE afternoon before I will be attempting anything so hopefully you can
send me anything you learn before then.
Thanks again,
Sent: Tuesday, May 20, 2003 8:03 PM
tomorrow
Dave Bjorkman
there
air
cure.
Wayne ,
heat
Dave Bjorkman
people!
that
or
fuel
Goop,
hands
going
are
THANKS!
Wayne O'Shea
Okay, thanks!!
Thanks again,
tomorrow
Dave Bjorkman
there
air
cure.
Wayne ,
uses
heat
he
Dave Bjorkman
people!
K'beck!!)
that
ongoing
dripping
or
fuel
Goop,
hands
going
are
THANKS!
Wayne O'Shea
LisaFly99
Post by LisaFly99 » Sat Feb 18, 2012 2:02 am
In a message dated 5/20/03 9:18:39 PM Central Daylight Time,
oifa@irishfield.on.ca writes:
Wayne ,
uses
heat
he
WAYNE
I have a plastic welder I bought from Harbor Freight. Auto body shops and
used car dealers use them to repair the plastic body parts, bumper covers,
ground effect panels ects. Using it is an art in itself. First make sure you
have the right rod for the material. And practice a lot before you do
anything important. You can burn through right now if you aren't careful. And
a thumbs up for Dave's friend in BC for being proficient at it, because it's
not as easy as it looks.
PS. make sure the air is on before you plug one in because they burn up in
about one second if there's no air flowing through the system. Don't ask how
I know, it's kind of self explanatory.
Phil&Lisa Smith
#460R
N414D
Dave-Sandra
Wayne I talked to my friend here in Terrace and he told me thatit is
possible to weld a flange/bushing on to the PE tanks . Problem is that
unless you have the proper flange and filler rod and similar materials to
practice on then you are better off trying to seal a bulkhead fitting . I
kind of like the Devcon idea I have used it to seal leaks on high voltage
transfomers containing mineral oil with good sucess.Although like David
Ricker I am not sure of its compatability with PE.
Sorry I couln't be of more help.
Another thought do you
have any local PE water tank or septic tank supliers could be they know
someone who is good at plastic welding .Good luck!!!!!
Dave Bjorkman
Sent: Wednesday, May 21, 2003 4:53 PM
Thanks Dave!
I'm going to tackle it somehow tomorrow and if they still leak I'm going to
rip the tank lids off the wings and build him some real aluminum tanks out
of my own "pocket"....... as in the long run it will cost me less!!
Thanks again everyone,
Sent: Wednesday, May 21, 2003 7:48 PM
I don't know about being knowledgable but I might as well toss out a few
ideas
in case it makes someone think of a solution.
On the adhesives I'm not sure if there is anything that will stick to PE
very
well but here are a couple of ideas. Given any though to hot melt
adhesives? I
don't know of any particular one but there might be a formulation that
would
take to the PE tanks. Give your local industrial adhesive rep. a call &
see if
you can get a sample & a gun to apply it. I was looking at using one of
"Engineering" grades on a project a while back and the rep for Amisol (?)
was
helpful.
Another idea would be one of the castable polyurethanes like Devcon
Flexane 80.
Cast it around the leaky fitting in a bump covering it and spreading out
around
the fitting. We used to make isolation mounts for electronic enclosures
which
were immersed in mineral & silicone oils and that worked well in that
application. After cure it is about 80 durometer so it can flex with the
tank
if need be. We cast right to the aluminum but I can't say how it would
adhere
to the PE, maybe the Devcon rep can answer that.
You might want to try and put a bulkhead fitting in the tank and use that
as a
via for the fuel line (see US Plastics, usplastic.com, P/N 16421 or
similar)
they use a gasket which is compressed against the side of the tank.
Outside of that, the plastic welding sounds like as good an ideas as any
(except
maybe an aircraft bladder....), perhaps you could weld some robust flanges
on
where the tubes have to pass through and thread fittings into the flange.
US Plastics sell the plastic welding guns (like P/N 41066) and a how to
booklet
(I have it, seems to make sense). They say you need nitrogen to weld PE
though.
Well hope this is useful, be nice to be able to help you for a change!
Dave R.
people!
that
or
fuel
Goop,
hands
going
are
THANKS!
Wayne O'Shea
Mike Davis
Post by Mike Davis » Sat Feb 18, 2012 2:02 am
This may seem like a bailing wire fix, but I thought I'd share it anyway. I
bought a snow machine 3 years ago with a split/leaking plastic fuel tank...
I took a wire brush to the crack to rough things up, then worked 30 minute
epoxy into the crack and spread it out on the surrounding "roughed up" area.
3 years later and many hours of bouncing down the trails at -30F, and it's
still holding.
Sounds to simple... but if it works, why not!
Sent: Wednesday, May 21, 2003 3:53 PM
Thanks Dave!
Thanks Dave!
ideas
very
adhesives? I
would
see if
was
helpful.
Flexane 80.
around
which
tank
adhere
as a
similar)
(except
on
booklet
though.
Dave R.
people!
that
or
fuel
Goop,
hands
going
are
THANKS!
Wayne O'Shea
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:08 am
Thanks, the "poop" tank dealer brings thoughts of a chapter member! Will try
him tonight!
I already have a threaded reinforced area in the tank that on the last
attempt I drilled out and retapped to have clean 3/8NPT threads and it still
leaked, so just a matter of finding something that will hold back the fuel
flow.
Maybe a heavy lip of proseal (up inside the tank threaded area)before I
thread in the fitting, then coat the end of the fitting so they stick
together as well as coating the fitting, thread in, let cure and clean out
the drain area so fuel can get to the quick drain!
Thanks again,
Sent: Wednesday, May 21, 2003 8:36 PM
Dave Bjorkman
Thanks Dave!
ideas
very
adhesives? I
would
see if
was
helpful.
Flexane 80.
around
which
tank
adhere
that
as a
similar)
(except
flanges
on
flange.
booklet
though.
Dave R.
people!
K'beck!!)
that
ongoing
dripping
or
fuel
Goop,
hands
going
are
THANKS!
Wayne O'Shea
David Ricker
Post by David Ricker » Sat Feb 18, 2012 2:08 am
I don't know about being knowledgable but I might as well toss out a few ideas
On the adhesives I'm not sure if there is anything that will stick to PE very
well but here are a couple of ideas. Given any though to hot melt adhesives? I
don't know of any particular one but there might be a formulation that would
take to the PE tanks. Give your local industrial adhesive rep. a call & see if
you can get a sample & a gun to apply it. I was looking at using one of the
"Engineering" grades on a project a while back and the rep for Amisol (?) was
helpful.
Another idea would be one of the castable polyurethanes like Devcon Flexane 80.
Cast it around the leaky fitting in a bump covering it and spreading out around
the fitting. We used to make isolation mounts for electronic enclosures which
application. After cure it is about 80 durometer so it can flex with the tank
if need be. We cast right to the aluminum but I can't say how it would adhere
You might want to try and put a bulkhead fitting in the tank and use that as a
via for the fuel line (see US Plastics, usplastic.com, P/N 16421 or similar)
Outside of that, the plastic welding sounds like as good an ideas as any (except
maybe an aircraft bladder....), perhaps you could weld some robust flanges on
US Plastics sell the plastic welding guns (like P/N 41066) and a how to booklet
(I have it, seems to make sense). They say you need nitrogen to weld PE though.
Dave R.
THANKS!
Wayne O'Shea
rebel
Post by rebel » Sat Feb 18, 2012 2:08 am
Wayne,
Some info on welding poly e
http://www.urethanesupply.com/fenderwelder.html
Rick D.
I read a 2 part epoxy package the other day and it stated "does not stick to
any plastics"! Guess you proved them wrong aye!!!!
Sent: Thursday, May 22, 2003 2:06 AM
tank...
area.
still holding.
Thanks Dave!
out
Mike Davis
Post by Mike Davis » Sat Feb 18, 2012 2:08 am
The stuff I used is the same thing I use when building remote control model
airplanes... nothing special about it. I've found that as long as there is
some texture to hold onto... it will hold.
Sent: Thursday, May 22, 2003 4:38 AM
anyway.
tank...
minute
area.
it's
still holding.
