Plastic to Brass/alum fitting sealer?
Dave-Sandra
Wayne ,
A local fellow here in Terrace BC uses a plastic welding process ( uses heat
and a filler rod )to repair plastic tanks and to attach fittings that he
gets from his supplier. I can find out more if you are interested
Dave Bjorkman
(future Moose Builder and avid forum lurker )
Sent: Tuesday, May 20, 2003 4:31 PM
Subject: Plastic to Brass/alum fitting sealer?
My turn to ask a question from all you well rounded knowledgeable people!
Having a problem with a customers Pegastol (read shitbox from K'beck!!) that
has terrible rotomoulded plastic wing & main tanks. It's been an ongoing
battle to try and seal his outlets and drains to keep them from dripping or
weeping. Have tried numerous sealers over the last year + and even the fuel
proof stuff seems to let go with his Esso premium car gas. Seal All, Goop,
Permatex hardening etc all let the fuel get by.
Tomorrows attempt is going to be proseal, but thought I would throw my hands
up in case someone has a better solution as I'm not sure if Proseal is going
to bit into the plastic either.
Tanks are a slippery white polyethylene (I beleive) and some fittings are
plastic, some brass, some alum.
THANKS!
Wayne O'Shea
oifa@irishfield.on.ca
Dave Bjorkman
THANKS!
Wayne O'Shea
Dave-Sandra
Wayne , I'll try to get ahold of him tonite but it will probably be tomorrow
morning as it is after five pm now
Dave Bjorkman
Sent: Tuesday, May 20, 2003 4:51 PM
Subject: Re: Plastic to Brass/alum fitting sealer?
Dave, If you don't mind looking into it for me I'd much appreciate if there
is a secret to this for leak free fittings. Hate to rush free advise but
time is a waste'n, as I have to have this thing ready to go back in the air
for next Friday and if I go the Proseal route I need a week for that to
cure.
Sent: Tuesday, May 20, 2003 7:47 PM
Subject: RE: Plastic to Brass/alum fitting sealer?
Dave Bjorkman
cure.
heatWayne ,
thatand a filler rod )to repair plastic tanks and to attach fittings that he
Dave Bjorkman
orhas terrible rotomoulded plastic wing & main tanks. It's been an ongoing
fuelweeping. Have tried numerous sealers over the last year + and even the
handsproof stuff seems to let go with his Esso premium car gas. Seal All, Goop,
goingup in case someone has a better solution as I'm not sure if Proseal is
*-------------------------------------------------------------------------*to bit into the plastic either.
THANKS!
Wayne O'Shea
THANKS!
Wayne O'Shea
THANKS!
Wayne O'Shea
cure.
cure.
heatWayne ,
Dave Bjorkman
THANKS!
Wayne O'Shea
Okay, thanks!!
I have to go into our plastics plant (that makes you wonder aye! - that I
can't seal stuff to it!!) to do the payroll in the morning, so it will be
LATE afternoon before I will be attempting anything so hopefully you can
send me anything you learn before then.
Thanks again,
Sent: Tuesday, May 20, 2003 8:03 PM
Thanks again,
tomorrowWayne , I'll try to get ahold of him tonite but it will probably be
theremorning as it is after five pm now
Dave Bjorkman
airis a secret to this for leak free fittings. Hate to rush free advise but
people!for next Friday and if I go the Proseal route I need a week for that to
cure.
heatWayne ,
A local fellow here in Terrace BC uses a plastic welding process ( usesand a filler rod )to repair plastic tanks and to attach fittings that he
Dave Bjorkman
Goop,thatHaving a problem with a customers Pegastol (read shitbox from K'beck!!)orhas terrible rotomoulded plastic wing & main tanks. It's been an ongoing
battle to try and seal his outlets and drains to keep them from drippingfuelweeping. Have tried numerous sealers over the last year + and even theproof stuff seems to let go with his Esso premium car gas. Seal All,
arehandsPermatex hardening etc all let the fuel get by.
Tomorrows attempt is going to be proseal, but thought I would throw mygoingup in case someone has a better solution as I'm not sure if Proseal isto bit into the plastic either.
Okay, thanks!!
Thanks again,
Thanks again,
uses----- Original Message -----
tomorrowWayne , I'll try to get ahold of him tonite but it will probably betheremorning as it is after five pm now
Dave Bjorkman
Dave, If you don't mind looking into it for me I'd much appreciate ifairis a secret to this for leak free fittings. Hate to rush free advise but
time is a waste'n, as I have to have this thing ready to go back in thefor next Friday and if I go the Proseal route I need a week for that to
cure.
Wayne ,
heheatand a filler rod )to repair plastic tanks and to attach fittings that
K'beck!!)people!gets from his supplier. I can find out more if you are interested
Dave Bjorkman
My turn to ask a question from all you well rounded knowledgeableHaving a problem with a customers Pegastol (read shitbox from
ongoingthathas terrible rotomoulded plastic wing & main tanks. It's been an
drippingbattle to try and seal his outlets and drains to keep them from
*-------------------------------------------------------------------------*Goop,orfuelweeping. Have tried numerous sealers over the last year + and even theproof stuff seems to let go with his Esso premium car gas. Seal All,arehandsPermatex hardening etc all let the fuel get by.
LisaFly99
In a message dated 5/20/03 9:18:39 PM Central Daylight Time,
oifa@irishfield.on.ca writes:
I have a plastic welder I bought from Harbor Freight. Auto body shops and
used car dealers use them to repair the plastic body parts, bumper covers,
ground effect panels ects. Using it is an art in itself. First make sure you
have the right rod for the material. And practice a lot before you do
anything important. You can burn through right now if you aren't careful. And
a thumbs up for Dave's friend in BC for being proficient at it, because it's
not as easy as it looks.
PS. make sure the air is on before you plug one in because they burn up in
about one second if there's no air flowing through the system. Don't ask how
I know, it's kind of self explanatory.
Phil&Lisa Smith
#460R
N414D
WAYNEWayne ,usesheheat
Phil&Lisa Smith
#460R
N414D
Dave-Sandra
Wayne I talked to my friend here in Terrace and he told me thatit is
possible to weld a flange/bushing on to the PE tanks . Problem is that
unless you have the proper flange and filler rod and similar materials to
practice on then you are better off trying to seal a bulkhead fitting . I
kind of like the Devcon idea I have used it to seal leaks on high voltage
transfomers containing mineral oil with good sucess.Although like David
Ricker I am not sure of its compatability with PE.
Sorry I couln't be of more help.
Another thought do you
have any local PE water tank or septic tank supliers could be they know
someone who is good at plastic welding .Good luck!!!!!
Dave Bjorkman
Sent: Wednesday, May 21, 2003 4:53 PM
Thanks Dave!
I'm going to tackle it somehow tomorrow and if they still leak I'm going to
rip the tank lids off the wings and build him some real aluminum tanks out
of my own "pocket"....... as in the long run it will cost me less!!
Thanks again everyone,
Sent: Wednesday, May 21, 2003 7:48 PM
Dave Bjorkman
Thanks Dave!
ideasWayne
I don't know about being knowledgable but I might as well toss out a few
veryin case it makes someone think of a solution.
On the adhesives I'm not sure if there is anything that will stick to PE
adhesives? Iwell but here are a couple of ideas. Given any though to hot melt
woulddon't know of any particular one but there might be a formulation that
see iftake to the PE tanks. Give your local industrial adhesive rep. a call &
theyou can get a sample & a gun to apply it. I was looking at using one of
was"Engineering" grades on a project a while back and the rep for Amisol (?)
Flexane 80.helpful.
Another idea would be one of the castable polyurethanes like Devcon
aroundCast it around the leaky fitting in a bump covering it and spreading out
whichthe fitting. We used to make isolation mounts for electronic enclosures
tankwere immersed in mineral & silicone oils and that worked well in that
application. After cure it is about 80 durometer so it can flex with the
adhereif need be. We cast right to the aluminum but I can't say how it would
as ato the PE, maybe the Devcon rep can answer that.
You might want to try and put a bulkhead fitting in the tank and use that
similar)via for the fuel line (see US Plastics, usplastic.com, P/N 16421 or
(exceptthey use a gasket which is compressed against the side of the tank.
Outside of that, the plastic welding sounds like as good an ideas as any
onmaybe an aircraft bladder....), perhaps you could weld some robust flanges
bookletwhere the tubes have to pass through and thread fittings into the flange.
US Plastics sell the plastic welding guns (like P/N 41066) and a how to
though.(I have it, seems to make sense). They say you need nitrogen to weld PE
people!Well hope this is useful, be nice to be able to help you for a change!
Dave R.
Goop,proof stuff seems to let go with his Esso premium car gas. Seal All,
areto bit into the plastic either.
Mike Davis
This may seem like a bailing wire fix, but I thought I'd share it anyway. I
bought a snow machine 3 years ago with a split/leaking plastic fuel tank...
I took a wire brush to the crack to rough things up, then worked 30 minute
epoxy into the crack and spread it out on the surrounding "roughed up" area.
3 years later and many hours of bouncing down the trails at -30F, and it's
still holding.
Sounds to simple... but if it works, why not!
Sent: Wednesday, May 21, 2003 3:53 PM
still holding.
toThanks Dave!
Thanks Dave!
ideasWayne
Flexane 80.helpful.
Dave R.
Thanks, the "poop" tank dealer brings thoughts of a chapter member! Will try
him tonight!
I already have a threaded reinforced area in the tank that on the last
attempt I drilled out and retapped to have clean 3/8NPT threads and it still
leaked, so just a matter of finding something that will hold back the fuel
flow.
Maybe a heavy lip of proseal (up inside the tank threaded area)before I
thread in the fitting, then coat the end of the fitting so they stick
together as well as coating the fitting, thread in, let cure and clean out
the drain area so fuel can get to the quick drain!
Thanks again,
Sent: Wednesday, May 21, 2003 8:36 PM
him tonight!
flow.
Thanks again,
toWayne I talked to my friend here in Terrace and he told me thatit is
Dave Bjorkman
Thanks Dave!
(?)rip the tank lids off the wings and build him some real aluminum tanks out
ideasWayne
I don't know about being knowledgable but I might as well toss out a fewveryin case it makes someone think of a solution.
On the adhesives I'm not sure if there is anything that will stick to PEadhesives? Iwell but here are a couple of ideas. Given any though to hot meltwoulddon't know of any particular one but there might be a formulation thatsee iftake to the PE tanks. Give your local industrial adhesive rep. a call &theyou can get a sample & a gun to apply it. I was looking at using one of"Engineering" grades on a project a while back and the rep for Amisol
thewasFlexane 80.helpful.
Another idea would be one of the castable polyurethanes like DevconaroundCast it around the leaky fitting in a bump covering it and spreading outwhichthe fitting. We used to make isolation mounts for electronic enclosureswere immersed in mineral & silicone oils and that worked well in that
thattankadhereif need be. We cast right to the aluminum but I can't say how it wouldto the PE, maybe the Devcon rep can answer that.
flangesas asimilar)via for the fuel line (see US Plastics, usplastic.com, P/N 16421 or(exceptthey use a gasket which is compressed against the side of the tank.
Outside of that, the plastic welding sounds like as good an ideas as anymaybe an aircraft bladder....), perhaps you could weld some robust
flange.onwhere the tubes have to pass through and thread fittings into the
K'beck!!)bookletUS Plastics sell the plastic welding guns (like P/N 41066) and a how tothough.(I have it, seems to make sense). They say you need nitrogen to weld PEpeople!Well hope this is useful, be nice to be able to help you for a change!
Dave R.
*-------------------------------------------------------------------------*orfuelweeping. Have tried numerous sealers over the last year + and even theGoop,proof stuff seems to let go with his Esso premium car gas. Seal All,handsPermatex hardening etc all let the fuel get by.
Tomorrows attempt is going to be proseal, but thought I would throw mygoingup in case someone has a better solution as I'm not sure if Proseal isareto bit into the plastic either.
David Ricker
I don't know about being knowledgable but I might as well toss out a few ideas
On the adhesives I'm not sure if there is anything that will stick to PE very
well but here are a couple of ideas. Given any though to hot melt adhesives? I
don't know of any particular one but there might be a formulation that would
take to the PE tanks. Give your local industrial adhesive rep. a call & see if
you can get a sample & a gun to apply it. I was looking at using one of the
"Engineering" grades on a project a while back and the rep for Amisol (?) was
helpful.
Another idea would be one of the castable polyurethanes like Devcon Flexane 80.
Cast it around the leaky fitting in a bump covering it and spreading out around
the fitting. We used to make isolation mounts for electronic enclosures which
application. After cure it is about 80 durometer so it can flex with the tank
if need be. We cast right to the aluminum but I can't say how it would adhere
You might want to try and put a bulkhead fitting in the tank and use that as a
via for the fuel line (see US Plastics, usplastic.com, P/N 16421 or similar)
Outside of that, the plastic welding sounds like as good an ideas as any (except
maybe an aircraft bladder....), perhaps you could weld some robust flanges on
US Plastics sell the plastic welding guns (like P/N 41066) and a how to booklet
(I have it, seems to make sense). They say you need nitrogen to weld PE though.
Dave R.
helpful.
Dave R.
THANKS!
Wayne O'Shea
rebel
Wayne,
Some info on welding poly e
http://www.urethanesupply.com/fenderwelder.html
Rick D.
Rick D.
I read a 2 part epoxy package the other day and it stated "does not stick to
any plastics"! Guess you proved them wrong aye!!!!
Sent: Thursday, May 22, 2003 2:06 AM
IThis may seem like a bailing wire fix, but I thought I'd share it anyway.
tank...bought a snow machine 3 years ago with a split/leaking plastic fuel
area.I took a wire brush to the crack to rough things up, then worked 30 minute
out3 years later and many hours of bouncing down the trails at -30F, and it's
still holding.
toThanks Dave!
I'm going to tackle it somehow tomorrow and if they still leak I'm goingrip the tank lids off the wings and build him some real aluminum tanks
*-------------------------------------------------------------------------*of my own "pocket"....... as in the long run it will cost me less!!
Mike Davis
The stuff I used is the same thing I use when building remote control model
airplanes... nothing special about it. I've found that as long as there is
some texture to hold onto... it will hold.
Sent: Thursday, May 22, 2003 4:38 AM
toI read a 2 part epoxy package the other day and it stated "does not stick
anyway.any plastics"! Guess you proved them wrong aye!!!!
minuteItank...bought a snow machine 3 years ago with a split/leaking plastic fuelI took a wire brush to the crack to rough things up, then worked 30
it'sarea.epoxy into the crack and spread it out on the surrounding "roughed up"3 years later and many hours of bouncing down the trails at -30F, and
still holding.
