You are quite welcome, Rob. If I helped it's probably the first time I've
helped anyone on this list. I'm generally on the begging for answers side!
That said, you did do it wrong if you found a problem BEFORE you drilled
holes and finished something. If you keep this up you won't get all that
experience from doing it twice....or thrice....or...
As for the bolts through the tail B Head, check your lengths; you might be
trying to use some that are too long. :) Craig
