[rebel-builders] metal cowling for rebel
Joe Ronco
Post by Joe Ronco » Sun Feb 19, 2012 8:16 pm
WALLACE: One place you can look at some pictures of building a metal cowl is
Roger Hoffman's website at:
http://tincantimes.dcsol.com/ContentsPage.htm
Scroll down to the second from the bottom. Roger is using a Continental
IO-240 engine.
If you need to contact Roger with any questions his e-mail address is:
rognal@dcsol.com
Hope this helps.
Joe Ronco 279R
Wallace Wogenstahl
Sent: Thursday, March 05, 2009 6:31 PM
Subject: [rebel-builders] metal cowling for rebel
I currently have a cowling made of fiberglass.looks OK but I do not like it
because it makes access very difficult. Being an old supercub pilot I
believe you should be abel to access the engine quickly and easly. So if any
one knows of a good metal cowling for my rebelI could sure use some ideas.
Post by Bob Patterson » Sun Feb 19, 2012 8:16 pm
Hi Wally !
I'm with you ! I have had 4 door cowls on my last 2 Rebels ...
They are pretty easy to do, and you can use different fiberglass
nosebowls. The factory sells a Piper-style one - I used a Thorp T-18
nosebowl from Aircraft Spruce -- there's a pic or 2 in the Files section.
If you get up to Brampton for a Builders Meeting, you can see
a bunch of them ! :-)
bobp@prosumers.ca
it because it makes access very difficult. Being an old supercub pilot I
any one knows of a good metal cowling for my rebelI could sure use some
ideas.
