Warp Drive prop cracks
Legeorgen
Post by Legeorgen » Fri Feb 17, 2012 11:27 pm
Brian,
I was to understand the blade failures had more to do with the high
compression pistons and not the HP rating. I helped remove a cracked prop
from an IO 240 at a fly in three weeks ago and that engine rates only a 125
HP.
Bruce G 357R
rebelair
Post by rebelair » Fri Feb 17, 2012 11:27 pm
Hi Bruce
Thanks for your thought. I think I can see how that makes sense.
Regards
Brian #328R
Sent: Thursday, October 12, 2000 12:37 AM
Subject: Re: Warp Drive prop cracks
Brian,
HP.
Bruce G 357R
