[rebel-builders] Building a 4 door cowl ?
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 8:07 pm
Wayne,
Do you know if the starter bump is needed with a Skytec starter?
Subject: [rebel-builders] Building a 4 door cowl ?
Date: Sat, 10 Jan 2009 11:19:20 -0500
Here's a start
http://cgi.ebay.com/ebaymotors/Parts-Ac ... 240%3A1318
Windows Live
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:07 pm
With no prop spacer and the skytec with the end bearing'd case I'm pretty
sure you need part of the indent. I removed some of it on mine, in an arc,
to clear my 10" spinner in tight to the nose bowl.
If I get a minute I'll peak up inside mine to see if you really need the
bump. If you go with the cantilever style skytec.. you definitely don't need
the bump.
To: "Builders list" <rebel-builders@dcsol.com>
Sent: Saturday, January 10, 2009 12:14 PM
Subject: RE: [rebel-builders] Building a 4 door cowl ?
Wayne,
Here's a start
Windows LiveT Hotmail
Post by Drew Dalgleish » Sun Feb 19, 2012 8:07 pm
I think it's only needed with the lycoming boat anchor starter but the bump
won't be in the way. On my nosebowl I had a hole for the starter to stick
through that I glassed over.
At 09:14 AM 10/01/2009 -0800, you wrote:
Wayne,
Here's a start
http://cgi.ebay.com/ebaymotors/Parts-Ac ... ar__Fiberg
lass-Cowl-experimental-aircraft_W0QQitemZ150320358498QQddnZPartsQ20Q26Q20Acc
essoriesQQadiZ2877QQddiZ2811QQadnZAviationQ20PartsQ20Q26Q20GearQQcmdZViewIte
mQQptZMotors_Aviation_Parts_Gear?hash=item150320358498&_trksid=p4506.c0.m245
&_trkparms=65%3A10%7C39%3A1%7C240%3A1318
Jesse Jenks
Thanks guys. I have the one with an end bearing, but it sounds like I might still get away with no bump.
Subject: Re: [rebel-builders] Building a 4 door cowl ?
Date: Sat, 10 Jan 2009 12:49:05 -0500
the bump.
Wayne,
Here's a start
