Long links in emails
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 8:07 pm
Sometimes the URL of a link is simply "long." In such cases, your email
reader (Outlook, Outlook Express, whatever) puts a line-feed in the midst of
the link. All one has to do is edit the email and remove the linefeed to
restore the full-length link. No way around this issue other than using the
utility at http://tinyurl.com to create an arbitrary short link.
Kimball
Sent: Saturday, January 03, 2009 3:26 PM
Subject: RE: [rebel-builders] RE: SR / Moose wing tip mod service bulletin
Not sure why the ".pdf" part of Ted's link isn't highlighted as part of the
link but it doesn't work without it. I'm reattaching it in this email to see
if the whole thing stays highlighted.
http://www.murphyair.com/murphyair/Airc ... NG_TIP_MOD.
pdf
Waltman
Sent: Saturday, January 03, 2009 8:35 AM
Hello Roger,
The service bulletin you refer to is now located at this link:
pdf
I did this mod on my Moose last year in a similar fashion to what Scott
describes below--just removing enough rivets to carefully insert the new
angle. I already had the end doubler in place. Note: This service bulletin
is probably more important for those folks who have the newer, wider,
aileron tip weights which of course place more stress on the outer aileron
hinge attach point. I have the older ailerons with the original style tip
width/weights.
Ted Waltman
rogerk@dcsol.com
Sent: Wednesday, December 31, 2008 6:01 PM
Subject: [rebel-builders] RE: SR / Moose wing tip mod service bulletin
I've noticed the same thing on mine. Did anyone ever have an answer to
this question? It looks like the specified doubler already exists.
Roger K
On 4/13/2005 11:31 AM, SA@MWUTAH.COM wrote to REBEL-BUILDERS:
-> I am looking at my fast build Moose wings and they already have a
-> large aluminum doubler in the aft tip rib position that the wing tip
-> service bulletin calls for W-1030. Looks like you could just remove
-> a couple of rivets to cut off the rib flange and slip in the
-> stainless steel angle W-1031, no need to completely remove the
-> existing doubler or add the new aluminum one.
-> Has anyone else done this mod or upgrade to fast build wings yet?
-> Scott
-> Moose 174
http://www.murphyair.com/SUPPORT/PDF%20 ... %20MOD.pdf
password "builder"
