[rebel-builders] Rebel Instrument Panel - Dynon D180
Post by Drew Dalgleish » Sun Feb 19, 2012 8:02 pm
At 07:26 PM 11/17/2008 -0900, you wrote:
I have posted a picture of my instrument panel under the Rebel Instrument
Panel section of files if anyone is interested in what the Dynon D180 would
look like in a Rebel. I am using the D180 which is the combined EFIS and
EMS
system. Also have panel mounted Garmin 196/496 series GPS and Terra Com
and Transponder. Decided against backup ASI and Altimeter although there
is room to add 2 1/4 gauges under the Dynon at a later date if desired. The
garmin, radios and Throttle are deadcenter of the panel. Now that the rough
cut is finished, we'll take apart to prime, paint and label. Panel will
be a light
gray interior color.
Anyway, just my take on a lightweight, new age panel.
James Smith
Rebel 424R
Sweet that's my dream panel. You might find that's a long reach to your
trim switch though. Where did you get those nice looking vents and how are
they going to get hooked up?
james.smith
Post by james.smith » Sun Feb 19, 2012 8:02 pm
Drew,
The vents are a kit I bought from Vans for about $65 USD. Includes both
eyeball vents, 2 NACA ducts and a length of scat tubing. We have them
installed in the panel of my dad's Rebel (Si Smith) and they work great and
are a vast upgrade from those that come with the kit.
James
-------- Forwarded Message ---------
Original: DATE..... 11/17/2008 8:17 PM
Original: FROM..... drewjan@cabletv.on.ca
At 07:14 PM 11/18/2008 -0900, you wrote:
Drew,
James
Thanks James My kit didn't come with any vents so I fly with the window
open or closed. Not the most comfortable solution. I've considered putting
in cessna style wing root vents but those look like they'd be even nicer.
Post by Walter Klatt » Sun Feb 19, 2012 8:03 pm
Drew, I just have the plastic snap vents in my windows, cheap and easy to
install, and they work great. Can't imagine flying in hot summer weather
without them.
Dalgleish
Sent: November 18, 2008 9:08 PM
Subject: Re: [rebel-builders] Rebel Instrument Panel - Dynon D180
Drew,
James
Post by Drew Dalgleish » Sun Feb 19, 2012 8:03 pm
Hi walter the snap vents I looked at spin around to either face the
airstream or away from it but they never close. Is that what you have?I
don't want an open vent in the winter time. I still haven't gotten around
to installing a heater yet.
without them.
Dalgleish
Drew,
James
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 8:03 pm
Drew,
See http://www.aircraftspruce.com/catalog/a ... pvents.php The CC3251
is what you want and if not, at $14.35 a set, they won't break the bank. If
you have std. drop down windows, they will even push in automagically when
the window hits the door when you forget to retract them first.
Ron
On Wed, Nov 19, 2008 at 9:01 AM, Drew Dalgleish <drewjan@cabletv.on.ca>wrote:
No, mine close flush, so no interference when the window is down, and you
can rotate them for direction. I think you are talking about the smaller
ones. Mine are the larger 3+ inch ones.
Dalgleish
Sent: November 19, 2008 9:02 AM
Subject: RE: [rebel-builders] Rebel Instrument Panel - Dynon D180
without them.
Dalgleish
Drew,
James
Jim Cole
Post by Jim Cole » Sun Feb 19, 2012 8:03 pm
I put the same ones in my window and like the simplicity - the only thing I
will caution you on, is to make sure when you cut the window that you don't
cut it too big. The first one is a little sloppy and so it vibrates out or
open while the second one I sanded the opening to the right size to get just
the right amount of friction.
Jim R333
Dalgleish
without them.
Dalgleish
Drew,
James
Eric Fogelin
Post by Eric Fogelin » Sun Feb 19, 2012 8:07 pm
I posted pictures of my Elite amphib panel in the Elite Instrument Panel
section. Also shows the center console for the hydraulic selector, etc.
We have similar layouts. I went for the separate Dynon D100 and D120 as
there are 2 pilots in the household and you can switch EFIS and EMS screens
between the units. Flying pilot just switches the screens to have full
flying display in front of them.
Less expensive to go with the D180 and a bit less weight. But, the Dynon
units weigh so little, it doesn't really matter. One Dynon unit weighs about
the same or less than a turn and bank, but includes every flight instrument
imaginable.
I also have not installed a backup ASI or Altimeter and I certified my
amphib for VFR and IFR. Unlike a certified aircraft which must meet the
requirements of Part 23 (in the US), homebuilts need only comply with
91.205. It is up to the builder to decide what they feel is safe.
I plan on using mine to pop through the thin West Coast marine layers that
we have so that I can fly to/from beautiful sunny and warm lakes inland.
Right now, I'm still in my 40 hour test phase and learning to become friends
with a glass cockpit. I've gotten mighty used to old steam gauges and the
transition to speed and altitude tapes is a bit of work. Engine gauges with
digital numbers are not intuitive like needles. The Dynon units include
needles and numbers, but I still have to think when I look at the screens.
And I'm a computer geek.
Lots of fun.
Elite Amphib 645E
james.smith@dcsol.com
Sent: Monday, November 17, 2008 8:27 PM
Subject: [rebel-builders] Rebel Instrument Panel - Dynon D180
EMS
cut is finished, we'll take apart to prime, paint and label. Panel will be
a light
James Smith
Rebel 424R
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:07 pm
Eric.. I was just looking at your panel pics. Looks great!!
One thing though.. I suggest that you drill a small hole thru the lower
edges of your ELT switch side guards and install a pin... before you trim IT
one too many times! lol
Sent: Saturday, November 29, 2008 8:02 PM
screens
about
instrument
imaginable.
friends
with
Lots of fun.
Elite Amphib 645E
would
EMS
The
rough
be
a light
James Smith
Rebel 424R
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 8:07 pm
Eric,
I like your panel a lot. I am thinking of doing something very similar, and the center console for gear lever, hydraulic gauge, and fuel selector as well. Have your Dynons been reliable so far? Can I ask what the total cost of the panel was, including all the extra stuff to make the Dynons work? How hard was the wiring?
Jesse
Date: Sat, 29 Nov 2008 17:02:04 -0800
imaginable.
Lots of fun.
Elite Amphib 645E
EMS
a light
James Smith
Rebel 424R
Get more done, have more fun, and stay more connected with Windows Mobile
james.smith
Post by james.smith » Sun Feb 19, 2012 8:07 pm
Eric,
Your panel looks great. I'm going to use the clear tape labels just like yours
except I am thinking of black ink instead of white, although now I have a
good example of the the alternative option.
Hopefully there will be two pilots in the family in the future as well, my wife
started her primary instruction a few years ago but quit when she got
pregnant with our first child. Hopefully she'll start up again once the Rebel is
airborn and the fact that we installed a 3rd seat for our now 3 year old
daughter.
I sure do like the simplicty of the Garmin stack but the only way it would work
in an Rebel panel would be to add the drop down center console like you did.
James
On 11/29/2008 4:02 PM, elist@whidbey.com wrote to rebel-builders:
-> I posted pictures of my Elite amphib panel in the Elite Instrument Panel
-> section. Also shows the center console for the hydraulic selector, etc.
-> We have similar layouts. I went for the separate Dynon D100 and D120 as
-> there are 2 pilots in the household and you can switch EFIS and EMS
screens
-> between the units. Flying pilot just switches the screens to have full
-> flying display in front of them.
-> Less expensive to go with the D180 and a bit less weight. But, the Dynon
-> units weigh so little, it doesn't really matter. One Dynon unit weighs about
-> the same or less than a turn and bank, but includes every flight instrument
-> imaginable.
-> I also have not installed a backup ASI or Altimeter and I certified my
-> amphib for VFR and IFR. Unlike a certified aircraft which must meet the
-> requirements of Part 23 (in the US), homebuilts need only comply with
-> 91.205. It is up to the builder to decide what they feel is safe.
-> I plan on using mine to pop through the thin West Coast marine layers that
-> we have so that I can fly to/from beautiful sunny and warm lakes inland.
-> Right now, I'm still in my 40 hour test phase and learning to become friends
-> with a glass cockpit. I've gotten mighty used to old steam gauges and the
-> transition to speed and altitude tapes is a bit of work. Engine gauges with
-> digital numbers are not intuitive like needles. The Dynon units include
-> needles and numbers, but I still have to think when I look at the screens.
-> And I'm a computer geek.
-> Lots of fun.
-> Eric
-> Elite Amphib 645E
-> -----Original Message-----
-> james.smith@dcsol.com
-> Sent: Monday, November 17, 2008 8:27 PM
-> Subject: [rebel-builders] Rebel Instrument Panel - Dynon D180
-> I have posted a picture of my instrument panel under the Rebel Instrument
-> Panel section of files if anyone is interested in what the Dynon D180 would
-> look like in a Rebel. I am using the D180 which is the combined EFIS and
-> EMS
-> system. Also have panel mounted Garmin 196/496 series GPS and Terra
Com
-> and Transponder. Decided against backup ASI and Altimeter although
there
-> is room to add 2 1/4 gauges under the Dynon at a later date if desired.
The
-> garmin, radios and Throttle are deadcenter of the panel. Now that the
rough
-> cut is finished, we'll take apart to prime, paint and label. Panel will be
-> a light
-> gray interior color.
-> Anyway, just my take on a lightweight, new age panel.
-> James Smith
-> Rebel 424R
-> List archives located at: https://mail.dcsol.com/login
Eric Fogelin
Okay, I confess, I've set it off once so far...but it wasn't at the switch.
I was plugging in the switch connector cable back in the tail and...off it
went. These new 406Mhz ELTs have horns (it went off), and I could hear the
whoop, whoop, whoop on the nearby FM radio. Damn.
Luck was with me and it happened within the normal 5 minutes after the hour
test period. No SAR dropped in to save me from myself.
Actually, since the first test flight, I have never had to adjust the trim
in 20 flights. I've had weights up near gross (2000lbs), but have not
explored aft gross weight limits yet, just forward to mid CG. So far it has
been set-it-and-forget-it at all airspeeds, wheels up, down and various
flaps. The elevator stays where you put it, feet on the floor and let go of
the stick.
I placed the trim switch right over the throttle so that it would be easy to
use during power setting changes. I have not wired it into a coolie hat on
the stick. I wanted to see how much trim I needed.
I'm hoping the ELT switch guards will work ok. I'll put a pin in as you
suggest after the first time I've been "rescued"!
G. O'Shea
Sent: Saturday, November 29, 2008 6:15 PM
screens
about
instrument
imaginable.
friends
with
Lots of fun.
Elite Amphib 645E
would
EMS
The
rough
be
a light
James Smith
Rebel 424R
Eric Fogelin
The center console has worked out well. I was worried that it was going to
be cramped or a knee-knocker. It isn't. I am 6'2" and my wife 5'11" and we
fit fine.
I did taper it deliberately to give more room. The edges of the console have
3/4" flanges to give it strength and no sharp edges. I am able to "hide" all
of the mostly aluminum hydraulic lines behind this console. There are many
other solutions in the archives that also look good.
I left room under the Dynon screens for analog gauges. The units have worked
well in their brief 15 hours of use. Dynon is a local company for me (near
Seattle, WA) and they have been around for a while. No guarantees, but...
I also made the entire panel removable via nutplates and screws. Riveting it
in place is faster and lighter and drilling out the rivets is easy, but I
used screws anyway. By the time you wire everything together, the panel is
pretty much in permanent anyway. So, you stick your head up under the panel
just like everyone else. And that is no fun.
But, because I made the panel installable, the entire panel was fabricated
and tested outside of the plane before installation. I did all of the wiring
and, no, I have never built a plane or wired one either. I did get a partial
wiring harness for the D100 and D120 that consisted of a bundle of wires
coming out of two connectors. I had to connect all of the other ends of the
wires between units, to the other avionics, and to all the engine sensors.
Most of the wiring is on the engine monitoring side, but the D100 still has
its share. I also installed all of the antennas and fabricated all of the
coax cables.
It took me two weeks to get all of the avionics and power lines hooked up.
It probably took another two weeks to get all of the sensors installed and
wired up. Add a week for antenna work. Add 2 more weeks for other wiring
work: trim, ELT, etc. You need a few specialized tools, but not too many. A
good coax stripper, coax crimper, wire stripper and DB (computer) pin
crimper, regular wire crimper and small screw driver set, almost nothing is
soldered. It also takes some time to go into the magic software
configuration for every avionics unit to configure them to talk to each of
the other boxes. This is something that you are never told about as a pilot.
This is the magic world of the avionics technician. There are special ways
to turn on the radio and transponder to get them into config mode.
Fortunately, these avionics tech manuals are provided or on the internet.
I enjoyed this part of the project. It was very different than everything
else. I'll post a wiring-at-work picture in the Elite Instrument Panel
section.
Bottom line for me: US$15,000.
Probably more with the tools and extra wires. But this was for an IFR
avionics suite, with HSI (Dynon HS-34). If you are VFR-only, you could have
an identical looking panel for $5,000 less. Use the SL-40 instead of the IFR
SL-30. Use a 495 instead of the 496 if you don't want XM Weather. Get a
cheaper transponder. You won't need all of the antennas. I got the extra
cost bright Dynon screens (probably necessary). Here is the equipment list,
don't have the price breakdown handy, but it was all ordered from Pacific
Coast Avionics:
Avionics
EFIS Dynon Avionics EFIS-D100
EMS Dynon Avionics EMS-D120
HSI Dynon Avionics HS34
GPS Primary Garmin 496
GPS (Optional Backup) Garmin 296
NavComm Garmin SL-30
Transponder Garmin GTX-327
Audio Panel PS-Engineering PMA4000
ELT Artex ME406
Sensors (oil temp, oil press., man. press., rpm, amps, volts, EGT (4), CHT
(4), OAT, carb. temp.) Dynon Avionics
Main power distribution board Control Vision Exp2Bus
Pitot with AOA Dynon Avionics Unheated Pitot/AOA
Stick grip with PTT Ray Allen G101
Antennas
Comm Comant CI 121
Nav (VOR/LOC/GS) Comant CI 158C
ELT Comant CI 314-1
GPS (2) Garmin GA 56
Transponder Pacific Coast Avionics AV-22
It is all electrical, no vacuum pump, no vacuum plumbing. The EFIS and GPSs
have built-in battery backup. More than you need for VFR, good to get on the
ground IFR.
645E
Jenks
Sent: Saturday, November 29, 2008 7:03 PM
To: Builders list
Eric,
Jesse
screens
about
instrument
imaginable.
friends
with
Lots of fun.
Elite Amphib 645E
would
EMS
The
rough
be
a light
James Smith
Rebel 424R
Get more done, have more fun, and stay more connected with Windows MobileR.
http://clk.atdmt.com/MRT/go/119642556/direct/01/
Eric Fogelin
I went back and forth on white text or black. With a grey panel, you can go
either way. I used vinyl labels which should stand up to wear and tear. If
you knew that you would never change your panel, you could get it powder
coated and labels silk screened.
But, the fun of building your own plane is that you can change your panel in
the future. I know and knew I would. Right now there is a temporary label
marked GRUMP. Not only does it describe my personality, this also helps
remind me to put the water rudders and landing gear in the correct place. It
is a variation of the standard takeoff and landing GUMP:
G - Gas
R - Water "R"udders
U - Undercarriage
M - Mixture
P - Prop
In the future I may modify the panel and add lights, horns, mirrors, more
labels, or just never get distracted during landing.
Before you decide on a center console, do a mockup with cardboard or scrap
aluminum. I went through a couple of design ideas before I found one that
would work and was sturdy.
I plan a 3rd seat in the future. Plenty of room in the back and CG is not a
problem. An adult would be comfortable for a $100 hamburger ride, a child or
teenager, no problem.
Sent: Saturday, November 29, 2008 8:27 PM
Eric,
yours
wife
Rebel is
daughter.
work
James
screens
about
instrument
-> imaginable.
that
friends
with
screens.
-> Lots of fun.
-> Eric
would
-> EMS
Com
there
The
rough
be
-> a light
-> James Smith
-> Rebel 424R
