[rebel-builders] 0-200 MOTOR MOUNT
Jean Poirier
Hello
As I know, it should fit. May be the IO-240 had some mod for the
accessories... but the "mount" should be the same (as per Franklin 0-240
too).
I do not understand that Murphy tech don't know that... THEY should know or
at least find the answer for you!
Jean
Rebel 747R
Jean Poirier
Pr
too).
Jean
Rebel 747R
Jean Poirier
Pr
Jean Poirier
Another thing...
The IO-240 is about the same price as the O-320... With 25-35 hp less...
The O-235 L2C could also be "pump" to 125 hp... The Jabiru 6 cylinders also
show 120 hp
Jean
Rebel 747R
Jean Poirier
Pr
show 120 hp
Jean
Rebel 747R
Jean Poirier
Pr
Keith Leitch
Sorry, I don't mean to get off track on your post. If you have an O-200 I can understand your question. But as far as the others, I personnally don't see much sense in using the O-235/IO-240 unless you have access to one for cheap. I have an O-235 L2C I had thought about installing in my Rebel (whenever I get to that point) but after looking at the weight vs. the O-320 it is sensless to me. May as well use the O-320 and if you are worried about fuel....that little thing called the throttle can easily be pulled back. I recently was on a 5+ hour tour with a bunch of Super Cubs and I was flying my O-300 powered 172. Flying at their speeds I burn a little over 5 gph. I guess what I am trying to say is it is nice to have the HP when you need it....just don't have to use it all the time if you are concerned with fuel prices.
I am waiting for Ron to get his Jabiru powered Rebel flying so I can get a report. :)
Eric Johnson
Does the 0-235 L2C have enough power to get a Rebel off the water on 1800 amphibs. or is that asking to much of it?
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Keith Leitch
Sent: Friday, November 14, 2008 8:43 AM
Subject: RE: [rebel-builders] 0-200 MOTOR MOUNT
Karen McCaffery
Yes, I do have a Cont. 0-200 that I am considering using on my Rebel. There are several reasons. I am trying to keep it light enough to qualify as LSA, 1320 lb. gross. I am using the std. bungee gear setup and have cut my fuel bays back to "two" bays per wing. I am located in the Southeastern USA and my field elevation is 500 feet above sea level. I never intend on putting the aircraft on floats. Additionally, my weight is 150 lbs. and fly alone 99% of the time. This is why I think 100 hp "might" do the job. Cris 719R
I am waiting for Ron to get his Jabiru powered Rebel flying so I can get a report. :)? The power to weight ratio may be an option for me since I will be on floats/skis the majority of the time.
Keith R661
Date: Friday, November 14, 2008, 8:30 AM
Another thing...
cylinders also
show 120 hp
Jean
Rebel 747R
Jean Poirier
Pr?sident
Oxyg?ne Portneuf Inc.
-----Message d'origine-----
De?: Jean Poirier [mailto:jean.poirier@oxyportneuf.com]
Envoy?: 14 novembre, 2008 09:26
??: 'rebel-builders@dcsol.com'
Objet?: RE: [rebel-builders] 0-200 MOTOR MOUNT
Hello
0-240
too).
or
Jean
Rebel 747R
Jean Poirier
Pr?sident
De?: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] De la part de Karen
McCaffery
Envoy?: 14 novembre, 2008 09:13
??: rebel-builders@dcsol.com
Objet?: [rebel-builders] 0-200 MOTOR MOUNT
Rebel Builders, I contacted Murphy and inquired about a motor mount for
a Continental 0-200. Murphy replied that they do now have a motor mount
for the Cont. IO-240. Would the IO-240 mount work for the 0-200? Do any
builders know the answer to this question?
Thanks, Cris 719R
Sent: Thursday, November 13, 2008 8:50 PM
Subject: [rebel-builders] Spruce Panel Builder
Hi all !
This might be useful to those who are about to start on
laying out their instrument panels .....
http://www.aircraftspruce.com/panelIntro.html
You do have to register, but it should be a help !
bobp@prosumers.ca
__________ Information NOD32 3613 (20081114) __________
Ce message a ete verifie par NOD32 Antivirus System.
http://www.nod32.com
Keith R661
Another thing...
cylinders also
show 120 hp
Jean
Rebel 747R
Jean Poirier
Pr?sident
Hello
0-240
too).
or
Jean
Rebel 747R
Jean Poirier
Pr?sident
McCaffery
Thanks, Cris 719R
Hi all !
bobp@prosumers.ca
Jean Poirier
Hello
A buddy was flying a Canadian advanced ultralight Rebel (+/- a LSA) with a
65hp Continental! Was flying good! My Cessna 150 fly very well behind a
0-200 (very often 100 pounds over max gross weight) on a 2200 ft grass strip
without any problem...
Jean
Rebel 747R
Jean Poirier
Pr
Jean
Rebel 747R
Jean Poirier
Pr
Eric Johnson
I have looked for insurance for a Rebel and found it to be very expensive. Does anyone have a avenue for insurance that is affordable? AOPA was no help. Thanks
Eric J.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jean Poirier
Sent: Friday, November 14, 2008 10:07 AM
Hello
Jean
Rebel 747R
Jean Poirier
Pr
Eric J.
Hello
Jean
Rebel 747R
Jean Poirier
Pr
Ron Shannon
Eric,
I have full coverage through EAA's program agency, Falcon Insurance, without
a problem. The carrier is AIG (though it could also have been Global) which
causes some concern, though Falcon opines that the insurance division, and
assets backing it, are secure at this point.
Ron
http://2544mr.com
Ron
http://2544mr.com
help. Thanks
Eric J.
Ron Shannon
Oops, forgot to address affordability. It is not cheap. $1M liability (the
cheap part) and $75K hull was about $2K/yr.
Eric,
without a problem. The carrier is AIG (though it could also have been
Global) which causes some concern, though Falcon opines that the insurance
division, and assets backing it, are secure at this point.
Ron
http://2544mr.com
Eric Johnson
AOpa quoted $1600.00 a year fro $35,000 hull and the standard $1M and
medical. I thought that was pretty high...I pay $900.00 per year for a
C182 now with the same coverage and get twice the hull coverage!
Ron Shannon
Sent: Friday, November 14, 2008 12:23 PM
Subject: Re: [rebel-builders] 0-200 MOTOR MOUNT
(the
Ron Shannon
(the
wrote:
insuranceEric,
Jean Poirier
1- It is a Homebuilt...
2- It is a tailwheel...
Jean
Rebel 747R
Jean Poirier
Pr
Jean
Rebel 747R
Jean Poirier
Pr
Eric Johnson
I realize that but just wondered what others were having to pay.
EJ
Sent: Friday, November 14, 2008 12:48 PM
Jean
Rebel 747R
Jean Poirier
Pr
EJ
Jean
Rebel 747R
Jean Poirier
Pr
I've heard guys say this many times and it is no doubt true in some
circumstances. The other side seems to be that the same guys rarely
seem to cruise at such low power. I think it is a combination of
roughness from one cylinder going lean first, plug fouling from low
temperatures, or maybe they just like to go fast?? My neighbor's 0-320
just won't run smoothly below 8+ gph. Anyway I wouldn't count on being
able to do it with a carb, standard intake system, and magnetos. I
believe that matched injectors, one or two electronic ignitions with
advance, and mogas will all help at low power.
concerned with fuel prices. I am waiting for Ron to get his Jabiru
powered Rebel flying so I can get a report. :) The power to weight
majority of the time. Keith R661
Jim Cole
I have mine insured - $50,000 and $1M - and it's $1900 CAN.
Jim R333
On 11/14/2008 1:51 PM, "Eric Johnson" <ej@cooksonhills.com> wrote:
[quote]I realize that but just wondered what others were having to pay.
EJ
Poirier
Jean
Rebel 747R
Jean Poirier
Pr
Jim R333
EJ
Poirier
Jean
Rebel 747R
Jean Poirier
Pr
Keith Leitch
Ken,
Thanks for that info. I hadn't realized the O-320 had an issue when running slower.I have next to zero time in anything with the Lyc O-320.
