Probably not worth worrying about .... The installation is
pretty straight forward, and usually done on completed Rebels.
Depending on your projected timing, though - might be good
to get an order in for those amphibs. Could be a long wait -
only a few in the pipeline at the moment ...
( Â Â MurphySales@gmail.com ) ;-)
bobp@prosumers.ca
http://www.prosumers.ca/Ramble08
On Tuesday 26 August 2008 13:14, David Jackson wrote:
My intent is to initially get the airplane flying on wheels and then
install a set of amphib floats. Other than the obvious float
reinforcement are there any changes I should make during construction to
make it easier when the time comes to install the floats. For example,
what is normally done for the water rudders? Should I cut holes now to
run cables later? How about mounting the hydraulics and running the
lines? Should I install lines now and just cap them off?
Any suggestions would be appreciated.
Dave Jackson
Rebel 414
Find hidden words, unscramble celebrity names, or try the ultimate
crossword puzzle with Live Search Games. Play now!
http://g.msn.ca/ca55/212
