[rebel-builders] Soundproofing
Posted: Sun Feb 19, 2012 7:51 pm
David:
As you say you want it corrosion resistant. Does it hold water (like a
sponge), I hope not. If it does don't use it. Moisture from hi
humidity, rain etc would not be a good combination, especially if you
are in the far north where it freezes. I would lean towards no cement,
it can then be removed for inspection, maintenance etc.
Dick Wampach SR-108
From[mailto:mike.davis@dcsol.com] On Behalf of David L. Tuck
I'm about to close the inside floor area under the seat rails and I have
placed some 1/4" soundproofing purchased at Wicks, It is smooth on one
side and fire retardant, Should help with noise and some insulation too.
The manufacture says to glue with waterproof cement? I have just placed
it in between the ribs without glue, I don't want to promote corrosion?
Should I glue or leave it friction fit?
Any comments?
Dave T
Rebel 009
Dick Wampach SR-108
Any comments?
Dave T
Rebel 009
