David:
As you say you want it corrosion resistant. Does it hold water (like a
sponge), I hope not. If it does don't use it. Moisture from hi
humidity, rain etc would not be a good combination, especially if you
are in the far north where it freezes. I would lean towards no cement,
it can then be removed for inspection, maintenance etc.
Dick Wampach SR-108
From[mailto:mike.davis@dcsol.com] On Behalf of David L. Tuck
I'm about to close the inside floor area under the seat rails and I have
placed some 1/4" soundproofing purchased at Wicks, It is smooth on one
side and fire retardant, Should help with noise and some insulation too.
The manufacture says to glue with waterproof cement? I have just placed
it in between the ribs without glue, I don't want to promote corrosion?
Should I glue or leave it friction fit?
Any comments?
Dave T
Rebel 009
[rebel-builders] Soundproofing
I also elected not to add insulation inside closed panels. However if
you do I'd recommend gluing it to the top surface (bottom of inside
floor) so it tends to stay drier and where any corrosion is less
dangerous. Water will get inside the enclosed floor.
David:
Dick Wampach SR-108
Any comments?
Dave T
Rebel 009
Dave Ricker
Just a thought, the sound insulation will probably perform better if it is attached to the panel. If it is a material that depends on its mass to damp the sound transmission of a panel (changing the sound transmission
impedance) it needs to "modify" the movement of the panel as the sound travels through it. I'd look at something like the 3M upholstry spray adhesives as an option. They can be had through automotive body supply
jobbers.
Another source of materials is Dynamat. http://www.dynamat.com/technical_technical.html They claim their Tacmat is used in aircraft.
"David L. Tuck" wrote:
David A. Ricker
Fall River, Nova Scotia
Canada
jobbers.
--I'm about to close the inside floor area under the seat rails and I have placed some 1/4" soundproofing purchased at Wicks, It is smooth on one side and fire retardant, Should help with noise and some insulation too.
The manufacture says to glue with waterproof cement? I have just placed it in between the ribs without glue, I don't want to promote corrosion? Should I glue or leave it friction fit?
Any comments?
Dave T
Rebel 009
Your PC, mobile phone, and online services work together like never before.
http://clk.atdmt.com/MRT/go/108587394/direct/01/
David A. Ricker
Canada
John W
I recieved a box of airtex insulating material from a friend and did my Elite. It is fireproof aviation approved and works extremely well, its thin and preglued.
Unfortunately, I ran out and had to buy one 24 x 24 sheet Ouch its expensive (38 a piece) but you can talk in my Elite at idle no headsets no more oil can rattly noises got to easier on the riveting too.
John W 752E
John W 752E
Subject: Re: [rebel-builders] Soundproofing
Date: Saturday, August 9, 2008, 8:32 PM
jobbers.
seat rails and I have placed some 1/4" soundproofingI'm about to close the inside floor area under the
retardant, Should help with noise and some insulation too.have just placed it in between the ribs without glue, IThe manufacture says to glue with waterproof cement? I
it friction fit?_________________________________________________________________Any comments?
Dave T
Rebel 009
together like never before.Your PC, mobile phone, and online services work-----------------------------------------------------------------https://mail.dcsol.com/loginList archives located at:"builder"username "rebel" password-----------------------------------------------------------------
David A. Ricker
Canada
Gary Gustafson
Several questions
1) How much of your plane did you insulate? Firewall? Area forward of
the doors? Or more. From what I read most of the noise comes from the
area forward of the doors.
2) I can not find the particular insulation in 24 x 24 sheets on the
Airtex website at: http://www.airtexinteriors.com/catalogue/misc.htm
3) What was the weight of the material you used or do you have more
information on the particular product?
4) Has anyone tried the SoundEx Products (www.soundedproducts.com)?
I have been impressed with their products as displayed at Sun n'Fun
and they appear to be light in weight and provide good soundproofing
Gary 242R
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of John W
Sent: Wednesday, August 13, 2008 8:01 AM
and preglued.
John W 752E
Gary 242R
and preglued.
John W 752E
jobbers.
Dave T
Rebel 009
David A. Ricker
Canada
That website should be http://www.soundexproducts.com.
044SR
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Gary
Gustafson
Sent: Friday, August 15, 2008 4:36 AM
Subject: RE: [rebel-builders] Soundproofing
Several questions
Gary 242R
and preglued.
John W 752E
044SR
Gustafson
Several questions
Gary 242R
and preglued.
John W 752E
jobbers.
Dave T
Rebel 009
David A. Ricker
Canada
