[rebel-builders] Masking Tape Glue
steve whitenect
Anyone got a good remedy for removing masking tape off of gelcoat after 10 years? Have tried just about everything and nothing will soften it up.
Steve W 637R
R U Ready for Windows Live Messenger Beta 8.5? Try it today!
http://entertainment.sympatico.msn.ca/W ... eMessenger
Steve W 637R
Garry Wright
I've used varsol successfully on old duct tape residue but not sure
about masking tape residue.
Garry
Garry
Steve W 637R
David Jackson
Try spraying it with wd-40, let it sit for 20 minutes then wipe it off.
Dave J
-------------------------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: mike.davis@dcsol.com> -----------------------------------------------------------------> > >
Dave J
> > > > > > > > > > ---Date: Thu, 22 Nov 2007 12:37:33 -0700> From: wrightdg@davincibb.net> To: rebel-builders@dcsol.com> Subject: Re: [rebel-builders] Masking Tape Glue> > I've used varsol successfully on old duct tape residue but not sure > about masking tape residue.> > Garry> > steve whitenect wrote:> > Anyone got a good remedy for removing masking tape off of gelcoat after 10 years? Have tried just about everything and nothing will soften it up.> > > > Steve W 637R> > _________________________________________________________________> > R U Ready for Windows Live Messenger Beta 8.5? Try it today!> > http://entertainment.sympatico.msn.ca/W ... eMessenger> > > > > > > > -----------------------------------------------------------------> > List archives located at: https://mail.dcsol.com/login> > username "rebel" password "builder"> > Unsubscribe: rebel-builders-unsubscribe@dcsol.com> > List administrator: mike.davis@dcsol.com> > -----------------------------------------------------------------> > > >
Reducer
Sent: Thursday, November 22, 2007 2:04 PM
Subject: RE: [rebel-builders] Masking Tape Glue
Steve W 637R
Robert & Olga Johnson
Hi Steve: If lacquer thinner will not work (which I am sure it would) then
the gel type paint stripper ( Lepages Poly Super Strippa) definitely will.
Just clean it off with varsol or equivalent afterwards. Bob J
steve whitenect
Have tried the lacuer thinner/reducer but not the WD 40 or paint stripper. Heading in the bush and will try it when I get back. Thanks to all that replied
Steve W > From: bestofbo@cogeco.ca> To: rebel-builders@dcsol.com> Subject: Re: [rebel-builders] Masking Tape Glue> Date: Thu, 22 Nov 2007 14:54:18 -0500> > Hi Steve: If lacquer thinner will not work (which I am sure it would) then > the gel type paint stripper ( Lepages Poly Super Strippa) definitely will. > Just clean it off with varsol or equivalent afterwards. Bob J> ----- Original Message ----- > From: "steve whitenect" <srwhitenect@hotmail.com>> To: <rebel-builders@dcsol.com>> Sent: Thursday, November 22, 2007 2:04 PM> Subject: RE: [rebel-builders] Masking Tape Glue> > > >> > Anyone got a good remedy for removing masking tape off of gelcoat after 10 > > years? Have tried just about everything and nothing will soften it up.> >> > > > > > -----------------------------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: mike.davis@dcsol.
Have fun while connecting on Messenger! Click here to learn more.
One more. I have had great luck on duct tape simply using AVGAS.
044SR
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of steve
whitenect
Sent: Thursday, November 22, 2007 12:48 PM
replied
044SR
whitenect
replied
One thing that might help is GooGone sold for removing stickers and tape
at hardware stores etc. Kind of oily and slow to evaporate so that it
soaks in.
Another might be lighter fluid. At Wayne's suggestion, that was the only
thing that helped much for removing the protective coating from my
windshield. As always try solvents first where you can't see the result
just in case...
soaks in.
just in case...
Steve W 637R
I've never tried it but somewhere I read that baby oil will soften masking
tape glue.
tape glue.
DrewAnyone got a good remedy for removing masking tape off of gelcoat after 10
Steve W 637R
kpierson
I have used a heat gun and it works very well it will soften
the glue and it can be scraped off, then cleaned with a solvent
However I would use caution not to get the plastic to hot
On 11/22/2007 10:04 AM, srwhitenect@hotmail.com wrote to rebel-builders:
-> Anyone got a good remedy for removing masking tape off of gelcoat after
-> Steve W 637R
-> R U Ready for Windows Live Messenger Beta 8.5? Try it today!
-> http://entertainment.sympatico.msn.ca/W ... eMessenger
-> Steve W 637R
steve whitenect
Thanks to those that responded about the masking tape. The problem is that there is no glue left- just the tape welded to the gelcoat! Will be trying some of the suggestions....................
Steve
Are you ready for Windows Live Messenger Beta 8.5 ? Get the latest for free today!
Steve
Jean Poirier
If it is really dry, use a scotch brite!
Jean
Rebel 747R
Jean Poirier
Pr
Jean
Rebel 747R
Jean Poirier
Pr
steve whitenect
Thanks Jean but it will probably scratch the gelcoat and there is alot on the fuselage!!
Steve> From: jean.poirier@oxyportneuf.com> To: rebel-builders@dcsol.com> Subject: RE: [rebel-builders] Masking Tape Glue> Date: Mon, 26 Nov 2007 16:56:07 -0500> > If it is really dry, use a scotch brite!> > Jean > Rebel 747R> > Jean Poirier> Pr
bransom
I would try sandpaper to slightly roughen (open) the top surface of the
masking tape, then put Goof-off on that and let it soak. It should come
off easily with a plastic scraper (or even a paper towel) after soaking
awhile -- maybe 30 minutes but up to an hour. I live and die by that stuff
for the plastic coatings that have hardened onto aluminum.
-Ben/ 496R
-Ben/ 496R
bransom
I meant to say up to 12 hours soaking with the Goof-off.
-Ben
-Ben
