[rebel-builders] SG 14
Post by Wayne G. O'Shea » Sun Feb 19, 2012 7:05 pm
If you don't mind the extra weight...no reason not. I hole saw the holes and
then use my air shear to cut the fingers out.
Sent: Monday, November 12, 2007 6:12 PM
Subject: [rebel-builders] SG 14
Well I'm at the point of installing the famed spring gear.
The manual says to lighten the SG 14, this is where you cut a 2 1/8
hole between the ribs and then cut them out on an angle
O
this shows a little what it looks like?
My question then is can I leave the SG14 as a whole plate rather than cut
them this way? On the inside of the cabin where the seat rails will go, I
just don't like the way it will look!
Any help out there?
Dave T.
Rebel 009
Climb to the top of the charts! Play Star Shuffle: the word scramble
challenge with star power.
http://club.live.com/star_shuffle.aspx? ... xtlink_oct
