[rebel-builders] 2-1/4 Inspection holes
Rick Muller
Post by Rick Muller » Sun Feb 19, 2012 3:08 pm
I used a hole saw that has a single spinning blade. I think I got it at
home depot. This version allows you to change the radius of the blade and
thus the diameter of the whole. I have also used regular hole saws as well.
Rick Muller
(303) 664 9219 Home
(303) 641 6623 Cell
rickhm@comcast.net
Charlie Eubanks
Sent: Tuesday, June 05, 2007 5:17 AM
Subject: [rebel-builders] 2-1/4 Inspection holes
Hello Builders
I am sure this has been discussed before but my search of the archives found
no match. My question is;
Having installed # 10 plate nuts in the rear spars to mount the aileron
hinge bolts, is it still a good idea (necessary) to drill the 2-1/4 Dia
inspections holes in the bottom wing skins?
Charlie E. 802R
Post by Wayne G. O'Shea » Sun Feb 19, 2012 3:08 pm
Don't see a reason to cut perfectly good aluminum...and then add 50 or more
screws to hold the covers on. They are only there so you can adjust your
hanger brackets.
Sent: Tuesday, June 05, 2007 8:16 AM
Hello Builders
found
Charlie E. 802R
Post by Bob Patterson » Sun Feb 19, 2012 3:08 pm
Hi Charlie !
If you have fixed nut plates, no need for extra holes !
Save the time & "Get it flying !!"(tm) !!! ;-) :-)
http://www.prosumers.ca
On Tuesday 05 June 2007 12:16, Charlie Eubanks wrote:
Hello Builders
found no match. My question is;
Charlie E. 802R
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 3:08 pm
I know better then to expect this all the time but it sure could spoil a
guy. You ash a question on this "Builder list" and you almost get an
emediate response. Thanks Wayne, Bob and Rick
Charlie E. 802R
Sent: Tuesday, June 05, 2007 7:16 AM
Hello Builders
found
Charlie E. 802R
