[rebel-builders] It flies.........
Post by Wayne G. O'Shea » Sun Feb 19, 2012 2:52 pm
Dang...what a goofy smile on your face Mike ! LOL
Glad all went well !! CONGATS!
The vibration may even be the exhaust system noise at full throttle, but if
it is the prop....many a vibration has been solved by simply rotating it 180
degrees. I'm also assuming that when you shut down it indexes properly and
stops in the "hand swing" postion.
Sent: Monday, February 19, 2007 6:01 PM
Subject: [rebel-builders] It flies.........
Well everyone, N771ME Elite flew today for the maiden voyage. This was the
first opportunity with out wind to make a flight. The rest of the week
looks bad, but have some adjustments to make in the mean time. All went
well. Outside temp at 35 F.
Climb out was around 2450, oil temp made 155, EGT 1400, CHT
highest seen was 375. Air speed indicator looks good.
I notice at full throttle the engine has some vibration, but at 2400 it is
smooth as glass. I think it is a rotation problem up front related to
balance and not an engine running condition.
2 problems, it flies out of trim right wing heavy. Almost looks like the
left aileron is drooped slightly when the other side is neutral, at least
it looks that way in flight, but it looks that way on the ground too, not
sure if that adjustment will correct this or not. Maybe droop a flap?
Second problem is flap lever won't hold detent. It looks like the detent
bolt isn't going to the bottom of the notch far enough. Going to have to
change something and try again.
Also planning on cutting the oil filter to make sure all is well before
going up again too.
Thanks for all the support this group gave me for 2 years. Hope I can help
someone else in the future.
Mike Betti
Mike Betti
Post by Mike Betti » Sun Feb 19, 2012 2:52 pm
Wayne,
You may have something there. The prop stops on a 45 degree angle. I was
shooting for parallel with the ground but hit it wrong I guess.
Sent: Monday, February 19, 2007 5:13 PM
Subject: Re: [rebel-builders] It flies.........
if
180
is
going up again too.
help
Mike Betti
No sounds like you have it right..it should stop with a blade at 10 o'clock
when looking at it from the front. Check your tracking, fly it some more to
get a handle on the noise/vib and then try switching it 180 Degrees and see
what happens.
Sent: Monday, February 19, 2007 6:25 PM
Wayne,
if
180
is
least
not
going up again too.
help
Mike Betti
Rich Dodson
Post by Rich Dodson » Sun Feb 19, 2012 2:52 pm
Congratulations Mike! A great day I am sure!
Rich
Rebel 806
Sent: Monday, February 19, 2007 6:01:48 PM
Well everyone, N771ME Elite flew today for the maiden voyage. This was the first opportunity with out wind to make a flight. The rest of the week looks bad, but have some adjustments to make in the mean time. All went well. Outside temp at 35 F.
Brad Hewlett
Post by Brad Hewlett » Sun Feb 19, 2012 2:52 pm
Congratulations Mike,
Must feel great............. Looking forward to that day.
Brad. (R195)
Sent: Monday, February 19, 2007 5:01 PM
going up again too.
Mike Betti
Post by Walter Klatt » Sun Feb 19, 2012 2:52 pm
Congrats Mike. A big step, and glad to hear it went well. The Rebel controls
are different, so this may not apply. However, I do know that with mine, at
the neutral flaperon setting, one wing is slightly heavy, but when I go into
reflex, it is in perfect balance for hands off flying, so I never did bother
adjusting anything. Also, I have my fin offset 3/4 inch which might have
some effect. But I have no trim tabs on any control surfaces on mine.
Enjoy, and good luck with the fine tuning.
Betti
Sent: Monday, February 19, 2007 3:02 PM
left aileron is drooped slightly when the other side is neutral, at least it
looks that way in flight, but it looks that way on the ground too, not sure
going up again too.
Mike Betti
NormIsler
Post by NormIsler » Sun Feb 19, 2012 2:52 pm
Mike-
Congrats on the first flight!
I'm sure the details will be worked out in short order.
Two years box to built! That's a fabulous achievement!
Norm Isler
Elite 702E
Robert Johnson
Post by Robert Johnson » Sun Feb 19, 2012 2:52 pm
Congrats Mike: I still smile when I think of my 1st Rebel flight 7 or 8
years ago. I am really looking forward to the one I am working on now. I do
not know how the Elite is set up for the flap lever, but if it is similar to
the Rebel, I have a simple lever design for you. Bob J Rebel 192/731
Mike Betti
Mike Betti
Wayne,
It's actually at 1:30.
Sent: Monday, February 19, 2007 5:36 PM
o'clock
see
what happens.
Wayne,
if
180
Mike Betti
I may take you up on it later, need to look it over some more.
Sent: Monday, February 19, 2007 6:07 PM
do
Mike Betti
Dave Ricker
Post by Dave Ricker » Sun Feb 19, 2012 2:52 pm
Good job Mike, congratulations!
Like Ralph said we (not so fast....) Eliteists will be keeping an eye on your progress so that we'll know what to expect when we get there. Keep the reports coming but take it one step at a time, no pressure......and enjoy it!
Dave R.
Francine D.
Elite 583
I notice at full throttle the engine has some vibration, but at 2400 it is smooth as glass. I think it is a rotation problem up front related to balance and not an engine running condition.
2 problems, it flies out of trim right wing heavy. Almost looks like the left aileron is drooped slightly when the other side is neutral, at least it looks that way in flight, but it looks that way on the ground too, not sure if that adjustment will correct this or not. Maybe droop a flap?
Second problem is flap lever won't hold detent. It looks like the detent bolt isn't going to the bottom of the notch far enough. Going to have to change something and try again.
Also planning on cutting the oil filter to make sure all is well before going up again too.
Thanks for all the support this group gave me for 2 years. Hope I can help someone else in the future.
Mike Betti
David A. Ricker
Fall River, Nova Scotia
Canada
Sounds like you need to back it up two holes. I've sent you a picture of how
it should sit/look after MOST shutdowns. Sometimes they stop somewhere
else..but 99% of the time this is it.
Sent: Monday, February 19, 2007 8:24 PM
Wayne,
o'clock
see
what happens.
Wayne,
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 2:52 pm
Wahoo! Way to go Mike! An inspiration to all of us.
Mike Betti
Mike Betti
Got it Wayne.
Sent: Monday, February 19, 2007 7:43 PM
how
Wayne,
o'clock
see
what happens.
Tim Hickey
Post by Tim Hickey » Sun Feb 19, 2012 2:52 pm
Congratulations!
Glad it went well!
Tim Hickey
2658 300th St
Montrose, Iowa 52639
Home 319 463-7047
Cell 319 795-2684
going up again too.
Mike Betti
