[rebel-builders] Taxi test
Charlie Starr
Post by Charlie Starr » Sun Feb 19, 2012 2:42 pm
Mike,
Most new brakes need a "wear-in" period to become effective, and are not
real effective at first. I taxied with brakes partially applied for first
few (slow) taxi tests on my SR. I also had back-filled the reservoir
(single reservoir for both brakes) and lines; no soft pedal and excellent
brakes. Taxi and ground steering is very easy and smooth with rudder alone,
and tail wheel kicks out with only slight brake application. My tail wheel
chains have practically no slack, with steering loads dampened by springs.
Don't know how much difference there might be between Elite brakes and SR
brakes, however.
Charlie Starr - SR N96CS
Sent: Saturday, February 10, 2007 3:24 PM
Subject: [rebel-builders] Taxi test
Hi all,
Still waiting for my DAR to do inspection of N771ME Elite. He is coming
next saturday now. FAA dragged their feet with my paper work last couple
weeks, but all is a go now. Today only -10F but warmed up to 15F. I took
out my airplane to do some run ups and taxi testing for the first time to
get the feel of it. Good temps in this weather, 140 max oil with plugged
off cooler, and 300 max CHT no matter what I did on the ground.
Raised the tail at about 30mph down the runway, the airplane is a little
squirrelly but manageable, that is until I ground loop it. There was a 6
knot cross wind, which I really dodn't need at this stage of the game, but
ok.
I uploaded a picture in the files section, Elite, finished.....
Everything is checking out good except for the brakes. They are very poor
for some reason. The pedals are solid with not much movement of the
masters when applying them, so I don't think air is an issue. I did
pressure fill them from the bottom up through the bleeder. I tried
dragging them around the ramp, they got warm, but not much improvement.
During a run up I have a hard time holding the brakes over 1400 rpm. I did
manage a static full throttle, with 76X58 Sensenich prop, I got 2300. I
also don't have enough brake to kick out the tailwheel. I also run the
8.50 tires if that is any handicap.
Any thought?
Mike Betti
Robert Johnson
Post by Robert Johnson » Sun Feb 19, 2012 2:42 pm
Nice looking Elite Mike - As they say down under "she's a beauty mate" and
that's fair dinkam. I had no problem with the new brakes on a Rebel and I
dragged them for a bit to seat them as recommended by Bob P. In fact I had
to watch the run up or I could put it on her nose - sometimes they held to
good. Best regards Bob J - Looking forward to that stage again.
Sent: Saturday, February 10, 2007 4:24 PM
Post by Wayne G. O'Shea » Sun Feb 19, 2012 2:42 pm
Sorry to hear of your "GL" Mike. Both Bob P. and myself try to tell everyone
DO NOT do high speed taxi tests in an airplane that will fly at 30 or less
in ground effect. Slow speed to get a feel and go flying. nothing in
between.
New brakes need to be taxied at about 1500 RPM dragging the brakes to keep
the speed slow.... for a few thousand feet. Let cool and do it again 'till
they hold well.
Hi all,
ok.
Any thought?
Mike Betti
Rich Dodson
Post by Rich Dodson » Sun Feb 19, 2012 2:42 pm
Mike,
First off, congrats!
Second, on the brakes issue, Charlie is right. Most brakes that are new, or used very seldom, hold poorly. Think of a new bike's brakes (at least that is how I remember it). There is a Cleveland bulletin, which probably applies across the board, which describes how to "break in" the brakes. Essentially it involves taxi-ing slowly with brakes applied for several minutes, followed by a cool down, then repeat.
You can probably find the bulletin on the Internet.
Best Wishes,
Rich
Sent: Saturday, February 10, 2007 4:24:48 PM
Hi all,
Still waiting for my DAR to do inspection of N771ME Elite. He is coming next saturday now. FAA dragged their feet with my paper work last couple weeks, but all is a go now. Today only -10F but warmed up to 15F. I took out my airplane to do some run ups and taxi testing for the first time to get the feel of it. Good temps in this weather, 140 max oil with plugged off cooler, and 300 max CHT no matter what I did on the ground.
Raised the tail at about 30mph down the runway, the airplane is a little squirrelly but manageable, that is until I ground loop it. There was a 6 knot cross wind, which I really dodn't need at this stage of the game, but ok.
Everything is checking out good except for the brakes. They are very poor for some reason. The pedals are solid with not much movement of the masters when applying them, so I don't think air is an issue. I did pressure fill them from the bottom up through the bleeder. I tried dragging them around the ramp, they got warm, but not much improvement. During a run up I have a hard time holding the brakes over 1400 rpm. I did manage a static full throttle, with 76X58 Sensenich prop, I got 2300. I also don't have enough brake to kick out the tailwheel. I also run the 8.50 tires if that is any handicap.
Any thought?
Mike Betti
Mike Betti
Post by Mike Betti » Sun Feb 19, 2012 2:42 pm
No GL here yet Wayne. But it is easy for me to say that I can handle the
airplane on the ground that is until the day I GL it, then I won't be saying
much.:(
Sent: Saturday, February 10, 2007 4:40 PM
Subject: Re: [rebel-builders] Taxi test
everyone
between.
they hold well.
Hi all,
but
ok.
did
Any thought?
Mike Betti
Guess I added a 'ed to loop while I read it. The sentence structure works
perfect for that! LOL
Sent: Saturday, February 10, 2007 9:07 PM
saying
much.:(
everyone
less
between.
keep
'till
they hold well.
Hi all,
but
ok.
poor
did
Any thought?
Mike Betti
Mike Betti
Wayne or Bob,
I know it's been mentioned before about this high speed taxi stuff from you
guys. An older pilot I fly with a lot and also I have learned much from,
wants me to get comfortable with doing this kind of taxi, but me on the
other hand want to get this engine in the air under full throttle before I
glaze it up.
What is it that you don't like about doing this kind of manuver? Maybe I can
change my buddys reasoning on this.
I know I have read books on taildragging and the author mentions don't taxi
on the mains for practice. But I do it anyway in a C140 from time to time.
Its good practice but can get you in trouble pretty fast.
Mike Betti
Sent: Saturday, February 10, 2007 8:36 PM
saying
much.:(
everyone
less
between.
keep
'till
they hold well.
Post by Ken » Sun Feb 19, 2012 2:42 pm
Exactly trouble comes quickly.
Closing the throttle and putting the tail down is way more squirrelly
than just landing with the throttle closed or almost closed. The
throttle closing adds yaw components (removing P factor) that you are
not used to and it happens at lower airspeed than on a landing with less
rudder control/
Mike Betti wrote:
Wayne or Bob,
glaze it up.
Post by Mike Kimball » Sun Feb 19, 2012 2:42 pm
I'll add my two cents worth on high speed taxi. I did it twice in my Super
Rebel before first flight. After having done three takeoffs and landings in
the Super Rebel now I can easily attest to the fact that I was in the most
danger of bending my airplane during the high speed taxi tests. Getting the
tail up and not flying was hard. Constantly balancing just enough power to
get the tail up with speed increasing, yet not taking flight. And the
runway wasn't all that long. About the time I got the tail up dancing on
all the controls trying to stay in control it was time to get the tail back
down and apply brakes before I ran out of runway. I was probably in the
most danger of groundlooping right after I finished accellerating and
reached my maximum speed, without taking flight, then powered off and
lowered the tail. It would be a much worse ground loop than a low speed
ground loop during the decellerating ground roll after landing. I agree
with Ken about the forces changing rapidly. Left turning tendencies are
there and increased by raising the tail, then you remove power and lower the
tail reducing and reversing those tendencies. You don't encounter those
rapid changes during a normal takeoff or landing. I would not recommend
high speed taxiing. Much safer to go fly and get the feel of the airplane,
then bring it in for your first landing on a nice long stabilized final
approach for a three pointer.
044SR
Betti
Sent: Saturday, February 10, 2007 6:17 PM
Wayne or Bob,
glaze it up.
Mike Betti
saying
much.:(
everyone
less
between.
keep
'till
they hold well.
Mike Betti
Thanks to all for the replies. I will try dragging them.............
Mike Betti
Sent: Saturday, February 10, 2007 3:50 PM
Mike,
alone,
wheel
brakes, however.
Hi all,
but
ok.
did
Any thought?
Mike Betti
Mike Betti
Thanks for the description, I think you hit on the head. Next weekend after
the inspection, I am going to drag the brakes down the runway, go back for a
cool down, then blast off! I'm thinking one trip around the patch, land,
check over. Then take off for a 30 minute flight around the patch at 75%
power.
Mike Betti
Sent: Sunday, February 11, 2007 5:23 PM
Subject: RE: [rebel-builders] Taxi test
Super
in
back
airplane,
044SR
Betti
Wayne or Bob,
you
glaze it up.
can
taxi
Mike Betti
saying
much.:(
Sounds like a plan.
Betti
Sent: Sunday, February 11, 2007 3:08 PM
power.
Mike Betti
Super
in
back
airplane,
044SR
Betti
Wayne or Bob,
you
glaze it up.
can
taxi
Mike Betti
saying
much.:(
Eddie Moran
Post by Eddie Moran » Sun Feb 19, 2012 2:42 pm
Bottom line, filter what your hear both here on this forum and at your local airport.
Read the EAA information on testing the engine and aircraft.
I have tested both a new aircraft engine and a new airframe at the same time. I had to divide tasks and lived.
I would however, not advise taking off with a never flown engine and a never flown airframe on the same flight............................
Eddie
To:
saying
much.:(
To:
everyone
less
between.
keep
'till
they hold well.
To:
Hi all,
but
ok.
poor
did
Any thought?
Mike Betti
Expecting? Get great news right away with email Auto-Check.
Try the Yahoo! Mail Beta.
I'll trust a "never flown" engine, from either of my two overhaulers, over a
"as removed" that go into most homebuilts anyday!
Sent: Monday, February 12, 2007 8:40 PM
local airport.
Eddie
To:
saying
much.:(
To:
everyone
less
between.
keep
'till
they hold well.
To:
Eddie Moran
Wayne, what is as removed engine?
Do you know what a "never flown" engine is?
How about an engine that has NEVER been flown. Or an engine that has NEVER been run under extreem pressures.
Let me know if you know what I am talking about. If you don't then that is ok too.
Let me know if you have ever ejected when an engine failed.
Eddie Moran
To:
local airport.
Eddie
To:
saying
much.:(
To:
everyone
less
between.
keep
'till
they hold well.
To:
