[rebel-builders] Rebel Questions: engine fit , W&B
Post by Bob Patterson » Sun Feb 19, 2012 2:38 pm
Hi Paul !
The floats shouldn't change the C of G tooooo much, maybe
1" one way or the other ... for several, it has moved back.
If the firewall is moved back, I think this definitely rules out
the possibility of using the 912, or any of the lighter engines.
I wouldn't be too wild about having to extend the engine
mount 6" or more forward - that's a big cantilever !!!
I guess "too far back" is relative .... it can still be within limits,
but too far aft to allow much baggage. We flew the original 80 hp.
912 Rebel on Murphy 1500 straight floats with full fuel (small tanks)
& 2 pilots, with no problems, but you couldn't put more than
maybe 10 lb. of baggage in without going out the aft limit....
Even on wheels, we had to put heavier baggage - like the
tent for Oshkosh - up front, often vertically, between the seats,
or on the floor, to keep the weight forward.
If Jim's Rebel with the 912-S works out, with the 3" longer
engine mount, I'm pretty sure that will become the "new standard"
setup for 912 Rebels ! ;-) :-) By moving the engine forward
and using the heavier "S" intake & exhaust, plus a larger Odyssey
battery on the firewall, and the ELT mounted on the front sidewall,
the 912 Rebel should be more easily able to carry the full 1,650 lb.
with a normal distribution of baggage, while staying within limits.
The slightly longer cowl should look very sleek too. With that setup,
even with a very light pilot, solo, and low fuel, it should be a
looong way from the forward limit.
Of course, those who choose to register it as an LSA-compliant
Experimental in the USA will be legally limited to 1,320 lb gross.
And they will have the safety & security of knowing that it <could>
carry 1,650 ..... not that anyone would ever do that ! ;-) :-)
If one is planning on using the 912, or similar engines, it is
a good idea to reduce the size of the fuel tanks to 2 bays per side,
still leaving over 30 gallons of fuel -- there's NO point in carrying
an extra 100 lb or so of fuel ! And larger, partially-filled tanks can
invite condensation and sloshing fuel - potential flow problems !
Reducing the tanks will save you a pound or two of weight too.
There are other ways to extend the range with extra fuel if
necessary .... although 32 gallons should give about 6 hours range !!!
(The 912 fuel pump is quite capable of pulling fuel from a
plastic gas can (or 2 !) in the baggage area ....) ;-)
http://www.prosumers.ca
On Saturday 27 January 2007 05:49, C&P Kucera wrote:
Hi Bob,
does the C of G remain too far back with the 912 on floats?
Paul
Reb453
Sent: Friday, January 26, 2007 6:10 PM
Subject: Re: [rebel-builders] Rebel Questions: tail wrap; engine fit;
riveter modification, W&B
Hi Ken !
I did say "or similar" - what I meant was - there's virtually
NO CHANCE of installing a Rotax 912, or one of the new, light,
more fuel-efficient engines. I base this on over 12 years of
flying 912 Rebels with the firewall in the standard position,
and the battery up front. (and sometimes 10 lb. of lead too ...)
Moving it back 3" would make it very unpleasant to fly ...
In standard configuration, the C of G is too far back to allow even
1500 lb gross in a normal passenger/baggage setup - although
the 912 Rebel <could> certainly carry 1,650. It will be interesting
to see how the latest Rebel comes out, with the Rotax mount
extended 3" forward .... I suspect even there, it will not be
possible to carry the usual baggage load, but it should be a
lot more versatile.
You are correct, of course - there are lots of choices in
the 'heavy' engine range - the Subarus are great, as are the
Lyc. clones (XP, etc.), and now a few radial contenders -
and I've heard of a new diesel that will appear at Sun 'n Fun ....
On Friday 26 January 2007 20:15, Ken wrote:
snip
snip
Based only on my aircraft, I don't think I'd agree that a moved FW
dictates an 0-320.
300 lbs of engine x 3" = 900 inch lbs. And the seats go back 3" as well
so say another 500 inch lbs when solo.
However keeping a 20+ lb battery on the FW vs back in the tail has as
much or more effect on the W&B.
Even the PC680 battery will be 20+ lbs with mounting brackets and wiring.
The archives have a recurrent theme of more up elevator, ballast, light
prop, light accessories, etc.,etc. The only Rebel owners that I've
heard say they needed weight in the nose had a rotax 912 or similarly
light engine.
And of course one can always make a custom longer engine mount.
PS. Ignore the following or read it critically including the disclaimer
These comments are with the Mackenzie leading edge cuff and the Fife
wingtips.
The subaru engine has a more rearward engine c of g than a Lyc. but
similar weight and my FW is moved back. I generally cruise with lower
power than an 0-320 would. The Mackenzie leading edge cuff extends the
leading edge forward (and I think the center of lift) and it effectively
reduces the angle of wing incidence by drooping the leading edge. My wee
batteries are under 20 lb but they are on the floor between the rudder
pedals. I have 20+ lbs of fuel pumps and 2 gallon header tank back
behind the float attach points (behind the baggage area).
Disclaimer - the leading edge cuff may be a major factor here so I'd
definately pay more attention to what MAM and other folks are saying
about this and I haven't done any spin testing although it takes a lot
of back pressure to stall my airplane and it doesn't seem inclined to
enter a spin unintentionally. More power than I have would mean a faster
cruise and probably less up elevator in cruise. I followed Wayne's post
and did not raise the nose of the stab as much as the manual said. Think
I set 0.8 degrees rather than the 1 degree in the manual. However if
doing it again I would not even raise the nose of the stab that much
because I still always have some up elevator. Even at gross weight the
tail generally will come up immediately on the takeoff and it certainly
is easier to land 3 point with an aft c of g. An aft c of g does
generally reduce pitch stability in cruise but my Rebel is amazingly
stable in cruise.
Keith Leitch
Post by Keith Leitch » Sun Feb 19, 2012 2:38 pm
Bob,
I would definitely like to hear more about this 912-S
and how it works out. I am a long way from being near
completion and currently working on the wings. I agree
that one should limit fuel capacity if going with that
engine but I have no idea which engine I will be using
yet. My intention is to use a Lyc 0-320 but as I get
older and a medical problem that I know will
eventually make me ineligible for a medical leaves me
to think I may have to go with the Rotax. So, I guess
I may end up with a heavy Rebel that may be a little
underpowered. I would hate to put all this work in my
dream plane and have to sell it to buy something LSA
legal. I guess I can just do what a couple of friendly
IA's have told me......keep flying and don't worry
about it. In the boonies where I will be living I
don't think I have to worry about much..YET!
Keith
R661
--- Bob Patterson <beep@sympatico.ca> wrote:
Hi Paul !
much, maybe
moved back.
lighter engines.
engine
original 80 hp.
fuel (small tanks)
more than
limit....
like the
between the seats,
the 3" longer
"new standard"
the engine forward
larger Odyssey
front sidewall,
the full 1,650 lb.
within limits.
With that setup,
should be a
LSA-compliant
1,320 lb gross.
that it <could>
that ! ;-) :-)
engines, it is
2 bays per side,
point in carrying
flow problems !
weight too.
fuel if
from a
wrote:
Hi Bob,
on floats?
Paul
Reb453
Hi Ken !
there's virtually
the new, light,
over 12 years of
standard position,
of lead too ...)
to fly ...
setup - although
Rotax mount
it will not be
should be a
lot more versatile.
of choices in
great, as are the
contenders -
at Sun 'n Fun ....
wasn't moved - most builders
engine. This gives a much
was moved, you are stuck
=== message truncated ===
____________________________________________________________________________________
No need to miss a message. Get email on-the-go
with Yahoo! Mail for Mobile. Get started.
http://mobile.yahoo.com/mail
Hi Keith !
It's not unusual to cut the left wing tank down to 2 bays, even
with the larger engines .... still a lot more fuel than a C-172 !
I've been wondering what one could stuff into the outboard end
of a tank to reduce capacity -- a beachball ??? or a fuel bladder
full of air ??? ;-)
As long as you don't move the firewall back, and use the
bungee gear, you don't have to worry about anything right
up until you are ready to hang the engine. The big concern
is that you CAN'T register it EVER at more than 1,320 gross,
or it can NEVER be LSA legal .... I don't know if they'd let
you register a 320 Rebel at 1,319 lb -- have to be a
single-seater.... ;-)
If you think you might have medical problems when
you are close to engine time, it might be best just to go
with the Rotax 912-S. Don't worry about being underpowered -
the standard Rebel flies just great, even with the 80 hp 912,
and the 100 hp. 912-S should be just fine !!
The lighter engine offsets a lot of horses - on a lot less fuel !!!!
On Saturday 27 January 2007 23:08, Keith Leitch wrote:
Bob,
Keith
R661
Hi Paul !
much, maybe
moved back.
lighter engines.
engine
original 80 hp.
fuel (small tanks)
more than
limit....
like the
between the seats,
the 3" longer
"new standard"
the engine forward
larger Odyssey
front sidewall,
the full 1,650 lb.
within limits.
With that setup,
should be a
LSA-compliant
1,320 lb gross.
that it <could>
that ! ;-) :-)
engines, it is
2 bays per side,
point in carrying
flow problems !
weight too.
fuel if
from a
wrote:
Hi Bob,
on floats?
Paul
Reb453
Keith Leitch
Bob,
Unfortunately I ordered my kit with the spring gear. I
ordered it in 1999 and it was before I had gotten on
his builders site and figured out that the bungee gear
was better. I had thought that the spring gear looked
nicer and at the time wasn't worried about medical
problems. I had gotten in a car accident (went under a
semi) and was layed up for a couple of years so things
have changed a bit. Still trying to build even though
I am slow due to not being able to work at one time
for very long.
I guess I could check and see if I could return the
gear to MAM and get a refund. But its been quite a few
years so not sure what they would say. I also have the
1800 Amphibs and should have waited and gotten the
1500's if I were going LSA.
Lots of changes in life to see that far ahead.
Also, I have been thinking of doing a small leg of the
Ramble this summer. The route that you have through MN
goes very close to my place. Anyone is welcome to stop
in for a beverage on the way by. The strip is 1000 ft.
Keith
R661
Hi Keith !
to 2 bays, even
than a C-172 !
outboard end
a fuel bladder
full of air ??? ;-)
and use the
right
concern
1,320 gross,
they'd let
to be a
when
to go
underpowered -
80 hp 912,
lot less fuel !!!!
wrote:
Bob,
912-S
near
agree
that
using
get
me
guess
little
my
LSA
friendly
Keith
R661
Hi Paul !
tooooo
much, maybe
has
moved back.
lighter engines.
engine
cantilever
can
original 80 hp.
full
fuel (small tanks)
put
more than
aft
limit....
baggage -
like the
between the seats,
with
the 3" longer
"new standard"
moving
the engine forward
larger Odyssey
front sidewall,
carry
the full 1,650 lb.
staying
within limits.
too.
With that setup,
fuel, it
should be a
as an
LSA-compliant
1,320 lb gross.
knowing
that it <could>
do
that ! ;-) :-)
similar
engines, it is
2 bays per side,
NO
point in carrying
potential
flow problems !
weight too.
extra
fuel if
fuel
from a
Bored stiff? Loosen up...
Download and play hundreds of games for free on Yahoo! Games.
http://games.yahoo.com/games/front
Hi Keith !
Wellllll, guess the gear's only a few more pounds - if it's
already on. Not much chance of returning it - there are
already several guys on the list with theirs for sale ....
....and you could likely trade the 1800's for 1500's later,
if you need to - there's a big demand for 1800's !
(Who knows - as LSA takes off, there might be new 1400's !) :-)
None of us have crystal balls .... thank goodness ! ;-)
It would be great if you can meet up with the Ramblers
for one of our Rambling parties (every night ! ;-) )
Ashland, WI (just east of Duluth) is always a good party,
and the steak house in Thief River Falls also gives a
good evening ! Give us a location for your strip, & we'll
fly by if we can -- such a wide variety of airplanes, landing
on 1,000 ft. is out for most of them ..... :-(
Although, if you're offering drinks ....... ;-)
On Sunday 28 January 2007 19:38, Keith Leitch wrote:
Bob,
for very long.
Keith
R661
Hi Keith !
to 2 bays, even
than a C-172 !
outboard end
a fuel bladder
full of air ??? ;-)
and use the
right
concern
1,320 gross,
they'd let
to be a
when
to go
underpowered -
80 hp 912,
lot less fuel !!!!
C&P Kucera
Post by C&P Kucera » Sun Feb 19, 2012 2:38 pm
Thanks for your comments Bob,
Im just starting the double floor in the fuse cone and your comment about
the C of G with the 912 being too far back worried me a bit. I may just put
in the c31 channels and leave the 2nd floor skin and corner wraps out to
keep the weight down. Im still thinking about the 912 S or the 914 and going
with straight floats. My tanks have 3 bays in ea wing, an overkill.
paul
Sent: Saturday, January 27, 2007 1:59 PM
Subject: Re: [rebel-builders] Rebel Questions: engine fit , W&B
Hi Paul !
Hi Bob,
Paul
Reb453
Hi Ken !
lot more versatile.
Keith Leitch
Bob,
Heck, I haven't even started the fuselage. So, I can
still build it for the bungee gear. I don't have the
coordinates right here at the moment but I am listed
on the frapper site. The picture was taken if the fall
and it looks a little dead from no leaves on the
trees.
I may try and meet up in WI if I can make it. Just got
a lot going on. Trying to get a house finished before
my wife retires.
Keith
Hi Keith !
pounds - if it's
there are
sale ....
1500's later,
1400's !) :-)
goodness ! ;-)
Ramblers
party,
& we'll
airplanes, landing
wrote:
Bob,
gear. I
on
gear
looked
under a
things
though
time
for very long.
few
through MN
stop
ft.
Keith
R661
Hi Keith !
down
to 2 bays, even
fuel
than a C-172 !
outboard end
or
a fuel bladder
full of air ??? ;-)
back,
and use the
anything
right
big
concern
1,320 gross,
if
they'd let
have
to be a
problems
when
just
to go
underpowered -
80 hp 912,
lot less fuel !!!!
Don't get soaked. Take a quick peak at the forecast
with the Yahoo! Search weather shortcut.
http://tools.search.yahoo.com/shortcuts/#loc_weather
Keith Leitch
Bob,
Forgot to ask....I hope your not talking about any of
the Rebels making it into my strip!! That is what I am
building it for.
Keith
Hi Keith !
pounds - if it's
there are
sale ....
1500's later,
1400's !) :-)
goodness ! ;-)
Ramblers
party,
& we'll
airplanes, landing
wrote:
Bob,
gear. I
on
gear
looked
under a
things
though
time
for very long.
few
through MN
stop
ft.
Keith
R661
Hi Keith !
down
to 2 bays, even
fuel
than a C-172 !
outboard end
or
a fuel bladder
full of air ??? ;-)
back,
and use the
anything
right
big
concern
1,320 gross,
if
they'd let
have
to be a
problems
when
just
to go
underpowered -
80 hp 912,
lot less fuel !!!!
Need a quick answer? Get one in minutes from people who know.
Ask your question on www.Answers.yahoo.com
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 2:38 pm
Sent: Saturday, January 27, 2007 12:59 PM
Hi Paul !
Hi Bob,
Paul
Reb453
Hi Ken !
lot more versatile.
Charlie Eubanks
I live in Missouri so am not planning on putting my Rebel on floats but I
will install the float fittings. As was previously suggested I will only
have two fuel bays per side (30+ Gals.). The aircraft will be certified as
Experimental Armature Built. I plan to build it light enough to fly it under
the LSA Pilot Rules if necessary. Right now the Engine of choice is the 100
HP Rotax. I have never flown behind one so I will be very interested in
hearing how Jim's Rebel works out. By "new standard" Do you mean Murphy will
make the extended engine mount available? What about the prop and the engine
cowl or are we on I own there?
Charlie E. 802R
Hi Paul !
Hi Bob,
Paul
Reb453
Hi Ken !
lot more versatile.
Hi Keith !
If you have a choice, and want it light, I'd definitely
go with the bungee gear (and maybe use Wayne's die spring
legs, if you want a nicer ride ...).
Will check frapper - just wanted a general idea of location....
The Ramble route is on the Ramble Flyer - you can d/l it at:
http://www.prosumers.ca/Ramble07
Hope you can meet up with us !
Not too worried about Rebels getting into 1,000 ft.,
but we've had Bonanzas, lots of Zeniths, and C-712's
that could have problems, especially considering the loads we
usually carry ! ;-)
On Sunday 28 January 2007 22:21, Keith Leitch wrote:
Bob,
trees.
my wife retires.
Keith
Hi Keith !
pounds - if it's
there are
sale ....
1500's later,
1400's !) :-)
goodness ! ;-)
Ramblers
party,
& we'll
airplanes, landing
Dale Fultz
Post by Dale Fultz » Sun Feb 19, 2012 2:38 pm
Bob,, If you have extra power maybe you can tow them you were into gliders
at one time weren't you? Dale SR-033 Just kidding,,,
Hi Charlie !
I think you'll love flying the 912-S ! Like you, I had flown a lot of
different engines over the years, and was quite sceptical of this
new, high-revving geared engine. I flew the Rebel, and was very
impressed with the safety of the airplane - I knew I would be safe,
no matter what happened ! Just point it into wind, put down full
flapperons, and I'll walk away for sure, even if I have to put it into the
trees (heck, impact would only be 25 mph tops ... ;-) )
Knowing that, I wasn't too worried about engine failure -
and, for the first while, it wasn't MY airplane, and it WAS
fully insured ..... so, we went flying !! We flew that 912 Rebel
to Florida, from Oshkosh to Toronto, across Canada, to Quebec,
and all over North America !! After about 160 hours, I began
to think maybe this engine might last .... Fifteen years and about
1,000 hours later, it's still ticking - and has only needed regular
oil changes and spark plugs. It did get new carb floats, and finally,
new exhaust pipes & mufflers ... This is absolutely THE lowest
maintenance engine i've ever flown behind !!
We flew on floats and wheels, winter and summer - it has been
up to 16,000 feet, on mogas and 100 LL ..... and at times, the
fuel burn was as low as 2 1/2 gph ... and it carries a heck of a load !
I have videos of the 912 Rebel taking off in 129 feet, and landing in
about 138 feet on wheels... pretty impressive ! And - Solo, light,
6 seconds off the water, on Murphy 1500 straight floats !
That was the 80 hp. 912 -- the extra ponies should make the 912-S
an even better performer, even with a slightly heavier stock 1,650
Rebel.
By 'new standard', I meant - that's the way most folks will build
the Rebel. I wouldn't be surprised if the factory offered a mount
like that, and a cowl. For now, there is a source, and 4 door metal
cowls are pretty well documented here. As always, we all benefit
from the sharing of experience that Mike makes possible with this
site !! Thanks again, Mike !!
Guess the only thing you have to watch, is not ever to register at
a gross weight over 1320 lb ...... you can't go down, ever, and be
LSA legal !
You're going to have FUN !!!! :-)
On Sunday 28 January 2007 22:54, Charlie Eubanks wrote:
Charlie E. 802R
Hi Paul !
Hi Bob,
Paul
Reb453
Hi Paul !
Please put that floor in !!! You will virtually double the strength of
the fuselage, and it's only about 5 lb. !!!
There's documented testing, and field results of damage, showing
that the rear double floor is definitely "A Good Thing"(tm). :-)
If you want to see some comments, i can send them offline, but
it really IS worth installing !! Remember, we had the floor, and
upholstery, and carpeting all the way back, in FINR, and others,
and they flew great !! Believe me, the difference rearward is not
as much of a problem as the forward C of G with O-320's, etc....
and they all fly OK toooooo ......
I think the 912-S is likely a better bet than the 914 - there have
been reliability issues with the 914 - a couple of broken crankshafts
on aircraft out of Brampton .... Should be great on straight floats.
My ideal 'retirement Rebel' will be a 912-S on amphibs ... :-)
Can't wait !
paul
Hi Paul !
Hi Bob,
Paul
Reb453
C&P Kucera
Thanks again Bob, I will continue working on the floor.
The only reliability issues I heard re Rotax 914 were the possibility of a
vapour lock in the fuel system, and re both the 912 and 914, the possibility
of oil starvation due to slow oil return to the oil reservoir and some issue
with the oil pump. Apparently these have all been addressed by Rotax ADs.
I wonder if the Brampton 914 crank failures were related to the oil
problems.
Paul
Sent: Sunday, January 28, 2007 11:04 PM
Hi Paul !
Can't wait !
put
going
paul
Hi Paul !
limits,
can
