Do after market tips exist for the Elite ?
Keith B. Oliver
Fisher
Sent: Sunday, December 03, 2006 9:18 AM
Subject: Re: [rebel-builders] Elite wing tips
hi all just a little information update re; wingtips
last week I removed my stock MAM round tips and replaced them with Fife tips
that I got from Jim Cole
I am very pleased (I had the benifit of checking speeds just before the
change, so the info is relatively accurate and at the same outside
temperature)
stall speed dropped from 50 mph to 47 at slow flight attitude and cruise at
2400 increased from 108 to 111mph using the gps two directions parallel to
the runway
climb is more difficult to determine because it is so weight sensitive but I
was seeing 1800fpm steady
control near the ground is excellent
So that 2 extra ft of wing certainly has some effect bob fisher
rebel 342 on wheels at this moment
Sent: Saturday, December 02, 2006 5:04 PM
Subject: [rebel-builders] Elite wing tips
fit your tps to the end ribs. Our (std) tips were so poor that I had toMike, I don't remember any plywood detail for 611E. Be careful to
trial
make a rib to fit the right tip. Our tip strobe power packs are mounted on
the end of the main spar and we made the tips screw removable for access. I
wouldn't do that again! Rather drill the rivets and retouch the paint if
required. Be sure you mount the tips symmetrically so that the tip chord
lines are parallel.
"rebel" password "builder"
password "builder"
