[rebel-builders] RE: Poor man's tach check
Post by Drew Dalgleish » Sun Feb 19, 2012 2:07 pm
I found that a bottle of rum at christmas to the owner of the local FBO
along with picking up a lunch tab once in a while and he's happy to lend me
his specialty tools like tach checker, differential pressure tester and
hose fitting mandrels. I just changed all my firewall forward hoses and all
it cost me was the price of the hose itself.
At 05:59 AM 8/29/2006 -0800, you wrote:
Or take the metronome off the piano, set it to 60 and blink your eyes in
sync
with the metronome ... too many engineer types on this thread!
On 8/28/2006 7:59 PM, mkimball@gci.net wrote to rebel-builders:
-> I know the "check the tach" comment was a joke but it reminded me of a
-> quick, easy, cheap way of checking the tach on my Piper Arrow ages
ago. My
-> tach was placarded as reading 100RPM low and I was curious. I put some
duct
-> tape on the back of one of the blades on my two blade prop, waited for
night
-> to fall, then put the airplane near a light on a building with the tail
-> facing the building. In the US AC power is supplied at 60HZ so if my tach
-> is accurate, the blade with the tape will appear to stop at multiples
of 60.
-> So I tried 1200, and 1800 RPM and discovered that, just as my tach was
-> placarded, my tach was off by 100 RPM. The prop appeared to stop at
1100
-> and 1700 RPM. If Canada is 50Hz then just use multiples of 50. Some
-> mechanic placarded my tach as reading 100RPM low and my test
confirmed it.
-> Mike
-> 044SR
-> -----Original Message-----
-> Rebflyer@aol.com
-> Sent: Monday, August 28, 2006 4:45 AM
-> Subject: [rebel-builders] New Prop
-> Hi all,
-> Well it's time to admit I have now purchased prop #3. I vowed in the
-> beginning that I would not do that, but here I am anyway.
-> Short history is this. When first certified I installed a McCauley 76".
-> Great prop on wheels. It spun at about 2300 rpm on initial roll. I felt it
-> was
-> to coarse a pitch for the floats and it could not be repitched any more.
-> Then
-> came the Warp drive 3 blade sq tip 72". I really enjoyed that prop. I
flew
-> that for almost 300 hrs prior to the cracks in the blade clamping area.
-> Pitched
-> for 2300 rpm on the initial roll it was a bit slow off the water for my
-> liking, but cruise ok. (as a side note, each 10 rpm change seemed to
relate
-> to 1
-> mph). Pitched for 2450 on the initial roll it smoked off the water,
-> especially light with cool temps( 60ish f) but 85mph for cruise.
-> I shipped the prop and hub back to Warp. For the cost of 1 blade they
-> sent
-> me a new hub and 4 blades. 70" sq tip. The performance from the 3 to
the 4
-> is the same as far as I could tell.
-> The rpm range on the Warps was about 600 rpm. More to come on this.
-> Well after waiting for 8 mo I now have a three blade 68" 46 pitch
Catto
-> prop. Very well known in the canard community for speed and
durability. I
-> figured if it can take nuts, bolts and exhaust systems going thru the
prop
-> without
-> catastrophic failure it should do fine on the front of a float plane.
-> After several conversations with Catto the numbers based on the engine
-> I'm
-> using and the hp it produces I decided on 2450 for the initial roll with
-> 125mph cruise at full throttle. 2750 rpm.
-> We hit those numbers right on the money. At 2450 it comes of the
water in
-> 90 deg f like the Warp did in 60 deg f !!! I can't wait till it gets
cool
-> again! Cruise at full throttle shows 2775. 300 rpm range. I think I
need to
-> check my tack(grin). Again in 90 deg f temps I'm indicating 115mph.
That's
-> the
-> fastest I've been on floats. At 2500 it is very close to 100mph. We also
-> shot
-> for that number and hit it right on!
-> Out of all the differences between the props the one that I cannot
put a
-> number to, but the seat of my pants and the size of the trees on the
-> shoreline
-> attest to, is when the floats break water this prop really keeps
pulling.
-> Hard!
-> And last but not least unlike the warps It looks like a real prop!
-> So at this time the only complaint I have is the wait I had for the
prop.
-> It is better than I hoped for in performance!
-> Cost? 1775.00
-> More to come, but I'm going flying, so see ya later!
-> Curt N97MR
-> List archives located at: https://www.dcsol.com/login
David Ricker
Post by David Ricker » Sun Feb 19, 2012 2:07 pm
Since Wayne is off-line depleting the Ontario fish population I'll have
to pipe
up here with the smart comment.......LOL!
You should be warned that when you overfly Canada you have to fly on the left
lane of the airway and from the right seat ;-)
Yeah, like the last comment said, too many Engineer types around here.
SNIP!
-> If Canada is 50Hz then just use multiples of 50.
-> Mike
-> 044SR
-> Rebflyer@aol.com
-> Hi all,
-> was
-> Then
prop. I flew
-> Pitched
relate
-> to 1
-> sent
the 4
-> Well after waiting for 8 mo I now have a three blade 68" 46 pitch Catto
-> prop. Very well known in the canard community for speed and durability. I
the prop
-> without
-> I'm
water in
gets cool
I need to
115mph. That's
-> the
-> shot
-> Out of all the differences between the props the one that I cannot put a
-> shoreline
-> attest to, is when the floats break water this prop really keeps pulling.
-> Hard!
the prop.
-> Cost? 1775.00
-> Curt N97MR
