would suspect any rear tilt on the swivel axis would be a problem as in
order to try and straighten out, the rear of the aircraft has to raise. A
forward tilt would be preferred , then the tailwheel would want to
straighten out or self center. This was the way mine was set up and was
never a control problem. What your experiencing as soon as the tail wheel
kicks, the tendency for the weight to fall causes the tail wheel to turn
sharper. Bob J Rebel 192/731
To: "Rebel Builder's List" <rebel-builders@dcsol.com>
Sent: Thursday, August 17, 2006 4:37 PM
Subject: [rebel-builders] Taxiing my Super Rebel
Man, taxiing was harder than I thought it would be. I wonder if it's more
trouble with the standard MAM tailwheel. Whenever the radius of turn got
little to tight the tailwheel would break loose and start turning me even
more sharply. I'd then come to a stop to keep out of the weeds or to
prevent running into a $200,000 airplane. Then I would not be able to get
going again without continuing the turn. I could not get the tailwheel to
straighten back out. Granted, I was unwilling to add gobs of power. I
had
to be very careful not to turn too sharply or add too much brake in a turn
because the tailwheel would kick out as described. I eventually got the
hang of taxiing while being careful in turns to keep the tailwheel under
my
control. Is this normal for the stock tailwheel? It's only slightly
better
than a completely freewheeling tailwheel. Is there an adjustment to
increase the amount of pressure needed to break the tailwheel loose? I
also
noticed two things about the tailwheel that might be contributing to the
problem.
1. The swivel axis is not vertical. It angles back. I need to move to
lowest hole for the forward attach point of the stinger. I don't know if
that will be enough though. I'm already on the second lowest hole.
2. I didn't do a good job of mounting the tailwheel to the stinger. It's
not straight up and down. There is a very small tilt to one side. Hard
notice unless you are looking for it. I wouldn't think that would make
much
difference unless it was off by a lot. Uneven tire wear is a given.
Perhaps I should go for the tailwheel fix after all. I wasn't planning to
right away. (Anxious to get flying before winter!) Figured I'd do the
fix
next summer.
