[rebel-builders] PROSEAL
Posted: Sun Feb 19, 2012 1:39 pm
by Robert and Olga Johnson
Hi Eric, I am no expert (Wayne pipe in any time) but from my personal
experience, it sounds more like an improper mix originally. Once proseal has
cured, I have not found anything to dissolve it. As far as finding the leak,
I use a mild dish detergent diluted with water and use a soft brush to go
over the suspected areas, while blowing gently thru one of the site gauge
fittings with a length of tubing. Of course the other openings have to be
plugged first. I just finished two wings and on the 2nd wing I had 6 tank
rivets leaking thru the stem hole ???? Go figure. Bob J (Formerly Rebel 652
& 725 assist)
Sent: Wednesday, April 12, 2006 10:58 AM
Subject: [rebel-builders] PROSEAL
O.K., I need some info from a guru. I am working on finding a small leak
in a
pro-sealed tank ... pro sealed many many years ago (20). The exterior of
tank at the inside rib had a lot of "gooey" pro seal under the primer, and
obviously fuel residue ... a very small leak for a while.
What makes the proseal revert to an uncured condition? Seems impossible to
me! The inside of the tank shows NO Signs of a break or softening of the
pro
seal! I'm confused, and I think this repair is great practice before I
work on
the Real Airplane (790R) tanks!!
I have removerd the affected proseal on the exterior rib, and I am going
start probing with a sharp object on the interior proseal ... Next I'll
scuff and
start putting on new ... Any ideas
I'm not expert either Bob! I just make it up as I go along!! ;O)
If it was inside the tank it would sound like sloshing compound to me! But
since it's on the outside...sounds like someone used some "miracle"
substance and hid it with primer! 20 years ago??..guess we're not talking a
Murphy metal product are we!?
Gotta get back to the shop....
From: "Robert and Olga Johnson" <rjohnson18@cogeco.ca>
Sent: Wednesday, April 12, 2006 12:07 PM
Subject: Re: [rebel-builders] PROSEAL
has
leak,
652
& 725 assist)
in a
pro
work on
scuff and
by eric.r
Nope, not a Murphy Metal plane, but great practice for doing my tanks soon.
It is a Grumman Tiger, and the Grumman guru says it happens a lot, and has
no plausible explanation as to why. I think it was just a mix with no catalyst!
And it lasted a long long time! When I get it done, I'll have a real working
knowledge of what not to do on the Murphy tanks.
On 4/12/2006 11:02 AM, oifa@irishfield.on.ca wrote to rebel-builders:
-> I'm not expert either Bob! I just make it up as I go along!! ;O)
-> If it was inside the tank it would sound like sloshing compound to me! But
-> since it's on the outside...sounds like someone used some "miracle"
-> substance and hid it with primer! 20 years ago??..guess we're not talking a
-> Murphy metal product are we!?
-> Gotta get back to the shop....
-> Wayne
-> From: "Robert and Olga Johnson" <rjohnson18@cogeco.ca>
-> Sent: Wednesday, April 12, 2006 12:07 PM
-> Subject: Re: [rebel-builders] PROSEAL
-> > Hi Eric, I am no expert (Wayne pipe in any time) but from my personal
-> > experience, it sounds more like an improper mix originally. Once proseal
-> has
-> > cured, I have not found anything to dissolve it. As far as finding the
-> leak,
-> > I use a mild dish detergent diluted with water and use a soft brush to go
-> > over the suspected areas, while blowing gently thru one of the site
gauge
-> > fittings with a length of tubing. Of course the other openings have to be
-> > plugged first. I just finished two wings and on the 2nd wing I had 6 tank
-> > rivets leaking thru the stem hole ???? Go figure. Bob J (Formerly Rebel
-> 652
-> > & 725 assist)
-> > From: <eric.r@dcsol.com>
-> > To: <rebel-builders@dcsol.com>
-> > Sent: Wednesday, April 12, 2006 10:58 AM
-> > Subject: [rebel-builders] PROSEAL
-> > > O.K., I need some info from a guru. I am working on finding a small leak
-> > > in a
-> > > pro-sealed tank ... pro sealed many many years ago (20). The exterior
-> > > the
-> > > tank at the inside rib had a lot of "gooey" pro seal under the primer,
-> and
-> > > obviously fuel residue ... a very small leak for a while.
-> > > What makes the proseal revert to an uncured condition? Seems
impossible
-> to
-> > > me! The inside of the tank shows NO Signs of a break or softening of
-> > > pro
-> > > seal! I'm confused, and I think this repair is great practice before I
-> > > work on
-> > > the Real Airplane (790R) tanks!!
-> > > I have removerd the affected proseal on the exterior rib, and I am
going
-> > > to
-> > > start probing with a sharp object on the interior proseal ... Next I'll
-> > > scuff and
-> > > start putting on new ... Any ideas
-> > > List archives located at: https://www.dcsol.com/login
-> > > username "rebel" password "builder"
-> > > Unsubscribe: rebel-builders-unsubscribe@dcsol.com
-> > > List administrator: mike.davis@dcsol.com
by Ken
All the unmixed pro seal that I've come across is white or creamy coloured.
The mixed stuff was dark brown or black.
[rebel-builders] ProSeal
by Gary Gustafson
From an email posted 6/20/2010 - Should answer your questions
This website has an interesting article regarding tank sealants (think Pro
Seal, etc), It should answer some of the questions that were recently asked
by a Rebel Builder. Serves as a good reference also.
http://www.rivetbangers.com/documents/tank_sealant.pdf
Answer is use toluene, however some use MEK or a 50/50 mix
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Andrew
Burr
Sent: Saturday, August 21, 2010 8:25 PM
To: Rebel owners
Subject: [rebel-builders] ProSeal
Has any one ever thinned ProSeal with MEK to make it easier to brush on. I
have been told this is standard practice.
Andrew E Burr XIV
Vertical performance LLc
Po Box 213
Cassville MO 65625
VPHelo, LLc has paid for the design and engineering for every component and
holds ownership of all intellectual property for each component.
by Ken
I'm skeptical. The PRC manufacturer told me that thinning cancels the
Milspec and was not recommended. No big surprise I guess as they also
sell a brushable grade. But what he said made sense to me as as this is
a two part hardening compound not a drying compound like paint. And he
seemed very knowledgeable and much more concerned with successful
results than with sales. Anybody here use this stuff in a large milspec
application?
I bought a couple of semkits of brushable stuff to paint all rivets and
seams after assembly. No leaks at 4 years and almost 400 hours.
Burr
To: Rebel owners
Andrew E Burr XIV
by Dick Wampach
Yes I have
Burr
Sent: Saturday, August 21, 2010 5:25 PM
To: Rebel owners
Andrew E Burr XIV
Po Box 213
Cassville MO 65625
by Jeff Micheal
Sealant can be thinned with up to 15% Toluene, by weight, without affecting
the properties of the sealant. While other solvents, such as MEK, may thin
tank sealant, they may also affect its properties with potential adverse
results, so it is recommended to use Toluene if you must thin the sealant.
Note, thinning up to 15 % is MAX using TOLUENE.......... Not MEK. (take a
look at the label, toluene is one of the "ingredients" in the sealant)
Also, use a scale when mixing for best and accurate ratio (as we all do when
mixing).............
application?
Pro
asked
Andrew
Burr
To: Rebel owners
Andrew E Burr XIV
