[rebel-builders] Windshield
mbetti
Post by mbetti » Sun Feb 19, 2012 10:52 am
Thanks Wayne......
On Tue, 30 May 2006 23:16:27 -0400, rebel-builders@dcsol.com said:
Yes Mike of course. It's how you keep the water out!
Sent: Tuesday, May 30, 2006 9:06 PM
Subject: Re: [rebel-builders] Windshield
Wayne,
Thousand questions............
Do you put the Butyl between the glass and the airframe?
Sent: Tuesday, May 30, 2006 6:03 PM
Yes..of course Joel.
I also find with the top one to be sure to run a strip of the buytlene
(sp)
tape across where the bolt holes are before putting the strip down. Then
when you push the bolts thru they will seal in the holes. Messy to put
washers/nuts on...but at least the washer will stay in place while you
start
the nuts!
Sent: Tuesday, May 30, 2006 7:00 PM
angle
it's
tight open inside
bulkhead
in
windshield edge
for
a the
covers/you
rivets,
I heck
Joel Jacobs
Post by Joel Jacobs » Sun Feb 19, 2012 10:52 am
Okay. Thanks Wayne.
I've been looking around for the Butyl tape and I see it comes in various
shapes/diameters. I've seen 1/4" and 3/8" round beads (on Ebay) and then
came across this:
http://www.pplmotorhomes.com/parts/caul ... /48463.htm
I think this is the right stuff if anyone is looking for it..
Joel
Sent: Tuesday, May 30, 2006 7:03 PM
(sp)
when you push the bolts thru they will seal in the holes. Messy to put the
start
the nuts!
This came through at a great time Wayne. I'm getting ready to start my
windshield very soon. Thanks much for reposting. I had not seen this
either. Do you also put the foam weatherstripping on the top piece?
Thanks again..
Joel
Sent: Monday, May 29, 2006 8:24 PM
I'm pretty sure this has been laid out many times...but here goes
again.
There retainer strip works best with the wide brake edge used as the
bolting
side and the narrow braked edge as the windshield side.
When drilling the side strips you drill into the strip (5 per side is
plenty - top strip about every 3 to 4 inches) and every so slightly
angle
the holes towards the nose as you are going thru the Fus-9 (assume it's
this
number on the Elite as well - The triangle between the door post and
windshield). Doing this (angled holes) will help pull the strip down
tight
against the windshield without making the AN526 head sitting cocked
against
the strip. On final assembly take some 1/4" to 3/8" wide x 3/16 thick
open
cell weather stripping or what ever you can get and stick it to the
inside
face of the retainer strips along the small brake edge section. That
way
when the strip is tightened down the foam will compress and hold the
windshield prior to the strips edge making contact with the Acrylic.
The top strip generally gets bolted right thru the cabin roof bulkhead
flange or just behind it. Works well that the windshield stops right in
front of the rivet row on the roof. The retainer will hold the
windshield
and is just large enough that the holes end up just behind or on the
flange.
If on you have to space them between existing rivets and the trailing
edge
of the retainer will sit down on the roof just behind the rivet row for
clean transition.
Sent: Monday, May 29, 2006 8:04 PM
enough
see
heck
out
Post by Wayne G. O'Shea » Sun Feb 19, 2012 10:52 am
The tape I use comes in about 30 foot rolls and is about 3/32 to 1/8 think x
1" wide. I use it full width on the bottom retainer...keeping it about 3/16
back from the edge (as it will grow in the sun) and I cut it in half to make
1/2" wide strips for the sides and top of the window. Rolling it up in a
roll works well for sealing the gap around the front wing attach area where
the window sits out off the fuselage.
Source for the tape....I just walk into Huronia Auto Glass her i Midland,
that does car windshields and boat windows, hand Norm $10 and he gives me a
couple rolls!
Sent: Wednesday, May 31, 2006 7:24 PM
Okay. Thanks Wayne.
came across this:
Joel
(sp)
start
the nuts!
Thanks again..
Joel
angle
it's
tight
open
inside
bulkhead
in
windshield
edge
for
covers/you
rivets,
heck
Post by Ken » Sun Feb 19, 2012 10:52 am
Aircraft Spruce sells it as "strip caulk"
Joel Jacobs wrote:
Okay. Thanks Wayne.
came across this:
Joel
Post by Bob Patterson » Sun Feb 19, 2012 5:33 pm
Sorry Craig ...
Email to: Shipping@murphyair.com
No parts orders here .... yet. Maybe sooooon ....
bobp@prosumers.ca
responsibility of the reader.
On Thursday 24 September 2009 18:27, snowyrvr@mtaonline.net wrote:
Hey Bob,
Do I order a windshield through you or MAM. I sure hope you say you. :)
Craig W
Original Message:
Date: Thu, 24 Sep 2009 02:42:30 +0000
Subject: Re: [rebel-builders] Rebel Flapperon/Aileron settings
Thanks Craig !
The important measurements are - the center of the middle hole
to the center of each of the outer holes.... especially the forward
one. Does anyone have those to post ??? Charlie ???
Jeff Micheal
Post by Jeff Micheal » Sun Feb 19, 2012 5:33 pm
Hey Craig,
I could put your order in direct........... but that would be like budding
in line. LOL.
Jeff
On Thu, Sep 24, 2009 at 1:32 PM, Bob Patterson <bobp@prosumers.ca> wrote:
Sorry Craig ...
bobp@prosumers.ca
Hey Bob,
Craig W
Original Message:
Thanks Craig !
Keith Oliver
Post by Keith Oliver » Sun Feb 19, 2012 5:45 pm
So who is ordering the windshield from AeroLP you or MAM ?
craig
Sent: Thursday, November 05, 2009 10:05 PM
Subject: [rebel-builders] Windshield
I received and email from MAM yesterday with instructions to contact AeroLP.
I did that today and am the proud owner-to-be of a new windshield. The
$315 freight quote reminds me of the very few reasons not to live in Alaska.
Nice to have that one checked off! Now, back to those damn fairing boxes!
CW
Checked by AVG - www.avg.com
Version: 9.0.698 / Virus Database: 270.14.51/2482 - Release Date: 11/05/09
14:52:00
craig
Post by craig » Sun Feb 19, 2012 5:45 pm
I had to call and I guess they already had a PO from MAM. Nice folks,
though, at Aero.
Keith Oliver
Would you mind telling me what the cost of the windshield was ?
craig
Sent: Friday, November 06, 2009 1:33 AM
though, at Aero.
Version: 9.0.698 / Virus Database: 270.14.52/2483 - Release Date: 11/05/09
14:52:00
jbcressman
Post by jbcressman » Sun Feb 19, 2012 5:45 pm
Keith....Was told to expect $600 by the time all costs were rolled in (exchange, shipping, taxes etc.) Bob 331R
Sent: Fri, Nov 6, 2009 11:50 am
Subject: RE: [rebel-builders] Windshield
craig
though, at Aero.
14:52:00
Keith Oliver
Sorry I meant the windshield alone
I don't mean to be a pain but am possibly going to be neat the factory and
thought I might get a spare
would save on the shipping
jbcressman@aol.com
Sent: Friday, November 06, 2009 12:25 PM
craig
though, at Aero.
14:52:00
Version: 9.0.698 / Virus Database: 270.14.52/2483 - Release Date: 11/06/09
02:38:00
Post by Wayne G. O'Shea » Sun Feb 19, 2012 5:45 pm
Windshields are being drop shipped directly to customers. They won't see the
factory... to the best of my knowledge.
Sent: Friday, November 06, 2009 1:04 PM
jbcressman@aol.com
craig
though, at Aero.
14:52:00
02:38:00
Jeff Micheal
Post by Jeff Micheal » Sun Feb 19, 2012 5:45 pm
From what I remember with LP Aero is that they will drop ship within the
USA, but when it came to shipping across the US/Canada Border they wouldn't
ship unless you had someone to clear customs (broker) prior to the shipment
leaving LP. Just what I recall from dealing with them in the past. The
alternative is to have it drop shipped to a border crossing near your
location, pick up the item in the US and clear customs yourself.
Jeff
On Fri, Nov 6, 2009 at 10:26 AM, Wayne G. O'Shea <oifa@irishfield.on.ca>wrote:
jbcressman@aol.com
craig
though, at Aero.
11/05/09
14:52:00
11/06/09
02:38:00
That damn imaginary line eh....
;O)
From: "Jeff Micheal" <westcoastkitplanes@gmail.com>
Sent: Friday, November 06, 2009 2:40 PM
wouldn't
shipment
Jeff
jbcressman@aol.com
craig
though, at Aero.
11/05/09
14:52:00
11/06/09
02:38:00
craig
$542
