[rebel-builders] Windshield
Post by Bob Patterson » Sun Feb 19, 2012 10:47 am
Hi Mike !
The rubber U channel on the bottom of the windshield is a good idea -
not only stops wear on the aluminum, but mainly cushions the plexiglass
from shocks that could crack it ! Also eases movement from expansion.
I like the Bostick 1100 sealant that the windshield manufacturers
recommend - comes in different colours, at most hardware stores, in
a caulking gun cartridge. It's good for skylights & side windows too !
One builder made an aluminum bottom retainer for the windshield -
looks sharp. Cut up pieces of bristol board to get fit, taping them
together. When complete, traced onto fresh bristol board - and had
a pattern for aluminum. Took some rolling & bending, but it does
look great..... Of course, NO screws through the Plexi - it just
floats in the frame, on the sealant, as size can change well over 1/4"
in summer !
On Friday 19 May 2006 02:29 am, Mike Betti wrote:
Builders,
The manual calls out a rubber strip to put on the bottom of the windshield
to protect the fuselage. I don't have any such part in my kit. Did others
find something? Is it necessary?
Also, I remember reading in some past posts from Wayne that he uses a
certain sealing material for the windshield, what is it and where can I get
it?
Mike Betti
771E
Robert Andrews
Post by Robert Andrews » Sun Feb 19, 2012 10:47 am
Bob,
This aluminum bottom retainer concept is what's on the Stinson 108-3 ... it
is a neat way to go. I'm considering making one for 612e. Windshild just
drops into this bottom piece with aluminum strips up the sides and along the
top.
Bob 612e
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Bob
Patterson
Sent: Friday, May 19, 2006 8:05 AM
Subject: Re: [rebel-builders] Windshield
Hi Mike !
in summer !
Builders,
get
it?
Mike Betti
771E
Mike Betti
Post by Mike Betti » Sun Feb 19, 2012 10:47 am
Thanks to all the replies, I should be able to come up with something now.
Sent: Friday, May 19, 2006 10:16 AM
Subject: RE: [rebel-builders] Windshield
Bob,
it
top.
Bob 612e
Patterson
Hi Mike !
in summer !
Builders,
windshield
get
it?
Mike Betti
771E
Mike Betti
Do you just push the tape sealant into the edge of the windshield or try to
get it under?
Mike Betti
771E
To: "rebel builders" <rebel-builders@dcsol.com>
Sent: Friday, May 19, 2006 8:49 AM
The sealing compound is butyl tape. Available from any windsheild or
auto supply shop. I used it on FOKM to restore the windshield in it.
There is no rubber strip in FOKM but she's pretty old - 1992. The butyl
is a treat to use. Windshield went in in a few minutes, no problem, the
first time. That's a bit of a first for me : ).
Garry
068R C-FOKM
On Thu, 2006-18-05 at 21:29 -0500, Mike Betti wrote:
Builders,
windshield
get
it?
Mike Betti
771E
Sent: Monday, April 17, 2006 9:25 PM
Dear Mike,
I used the aluminum retainer strip on the sides and top and just
glassed
bottom. It seems to have worked out great, and I don't think that the
windshield will be going anywhere!
Jeffrey
Sent: Monday, April 17, 2006 7:34 PM
Post by Ken » Sun Feb 19, 2012 10:52 am
I used large head rivets on the lower fiberglass piece and #6 stainless
truss head bolts with thin nyloc nuts everywhere else. On the roof I put
thin rubber washers under the bolt heads to hopefully keep out water
same as I did on the skylight bolts. I also used nylon washers under
everything non structural that was already painted (except where the
rubber washers were). On the door windows I used aluminum mandrel pop
rivets that do not squeeze near as hard as avex rivets.
Mike Betti wrote:
Hi All,
Mounting the windshield retainers on 3 sides. MAM calls out rivets, I see some have used screws. I was thinking the rivets would crease the heck out of the strap. Is there a better answer here?
Mike Betti
771E
Post by Wayne G. O'Shea » Sun Feb 19, 2012 10:52 am
Mike...MAM calls out rivets everywhere...tips/inspection covers/you name
it...they're cheap and proper hardware is not.
Bolt those on with AN526-832 machine screws and nuts. Just snugged enough to
take the weather stripping foam against the windshield.
Sent: Monday, May 29, 2006 1:38 PM
Subject: [rebel-builders] Windshield
Hi All,
Mike Betti
771E
Mike Betti
Post by Mike Betti » Sun Feb 19, 2012 10:52 am
Hey Wayne,
Weather stripping foam? I take it you are using something to prevent the
metal retainers from rubbing on the glass? Please explain.
Mike Betti
771E
Sent: Monday, May 29, 2006 5:47 PM
Hi All,
Mike Betti
771E
I'm pretty sure this has been laid out many times...but here goes again.
There retainer strip works best with the wide brake edge used as the bolting
side and the narrow braked edge as the windshield side.
When drilling the side strips you drill into the strip (5 per side is
plenty - top strip about every 3 to 4 inches) and every so slightly angle
the holes towards the nose as you are going thru the Fus-9 (assume it's this
number on the Elite as well - The triangle between the door post and
windshield). Doing this (angled holes) will help pull the strip down tight
against the windshield without making the AN526 head sitting cocked against
the strip. On final assembly take some 1/4" to 3/8" wide x 3/16 thick open
cell weather stripping or what ever you can get and stick it to the inside
face of the retainer strips along the small brake edge section. That way
when the strip is tightened down the foam will compress and hold the
windshield prior to the strips edge making contact with the Acrylic.
The top strip generally gets bolted right thru the cabin roof bulkhead
flange or just behind it. Works well that the windshield stops right in
front of the rivet row on the roof. The retainer will hold the windshield
and is just large enough that the holes end up just behind or on the flange.
If on you have to space them between existing rivets and the trailing edge
of the retainer will sit down on the roof just behind the rivet row for a
clean transition.
Sent: Monday, May 29, 2006 8:04 PM
Hey Wayne,
Mike Betti
771E
enough
Hi All,
see
out
Mike Betti
771E
Mike Betti
First time I seen that Wayne, great help. Hope to have it installed by the
end of the week.
Mike Betti
771E
Sent: Monday, May 29, 2006 7:24 PM
bolting
this
against
flange.
clean transition.
Hey Wayne,
Mike Betti
771E
name
enough
see
out
Mike Betti
Thanks Ken, good info.
Mike Betti
771E
Sent: Monday, May 29, 2006 3:24 PM
Mike Betti wrote:
Hi All,
Mike Betti
771E
Good to see you making headway Mike!
Wayne's "helpline" goes into hybernation in about 2 weeks ! :O)))))
Sent: Monday, May 29, 2006 9:07 PM
end of the week.
Mike Betti
771E
bolting
angle
this
tight
against
open
inside
windshield
flange.
edge
clean transition.
Hey Wayne,
Mike Betti
771E
enough
see
heck
out
Joel Jacobs
Post by Joel Jacobs » Sun Feb 19, 2012 10:52 am
This came through at a great time Wayne. I'm getting ready to start my
windshield very soon. Thanks much for reposting. I had not seen this
either. Do you also put the foam weatherstripping on the top piece?
Thanks again..
Joel
Sent: Monday, May 29, 2006 8:24 PM
bolting
this
against
flange.
clean transition.
Hey Wayne,
Mike Betti
771E
name
enough
see
out
Yes..of course Joel.
I also find with the top one to be sure to run a strip of the buytlene (sp)
tape across where the bolt holes are before putting the strip down. Then
when you push the bolts thru they will seal in the holes. Messy to put the
washers/nuts on...but at least the washer will stay in place while you start
the nuts!
Sent: Tuesday, May 30, 2006 7:00 PM
Thanks again..
Joel
bolting
angle
this
tight
against
open
inside
windshield
flange.
edge
clean transition.
Hey Wayne,
Mike Betti
771E
enough
see
heck
out
Mike Betti
Wayne,
Thousand questions............
Do you put the Butyl between the glass and the airframe?
Sent: Tuesday, May 30, 2006 6:03 PM
(sp)
start
the nuts!
Thanks again..
Joel
again.
bolting
angle
this
tight
against
open
inside
way
windshield
flange.
edge
clean transition.
enough
see
heck
out
Yes Mike of course. It's how you keep the water out!
Sent: Tuesday, May 30, 2006 9:06 PM
Wayne,
(sp)
start
the nuts!
Thanks again..
Joel
angle
it's
tight
open
inside
bulkhead
in
windshield
edge
for
covers/you
rivets,
heck
