than .020 and keep that in mind throughout the build Won't be a problem once
you have all the channels in and the top hat over the cables etc. If you
find you really need to be in and out numerous times with heavy tools.... a
strip of plywood a few inches wide is all you need to throw in to move
around on. Haven't seen it be an issue for annual inspections, battery
removal, ELT service etc. My back floor still looks like new after 11 years
in the air.
Sent: Wednesday, March 29, 2006 2:35 PM
Subject: [rebel-builders] Rebel baggage floor thickness
thickerI am working on the floor aft of bulkhead A. I was considering using
Imaterial from A to B, And the same forward of A when I get to that point.
was thinking .025 or .032. I don't want to add unnecessary weight, but the
.020 seems like it would dent very easily when you are crawling around on
your knees back there.
Does this seem to be an issue with heavily used airplanes?
Jesse
